SK22B
THRU
SK210B
Features
Lead Free Finish/Rohs Compliant (Note1) ("P"Suffix designates
Compliant. See ordering information)
Schottky Barrier Rectifier
Guard Ring Protection
Low Forward Voltage
Case Material: Molded Plastic. UL Flammability
Classification Rating 94V- and MSL rating1
Low Thermal Resistance
AEC -Q101 qualified.
2 Amp Schottky
Rectifier
20 to 100 Volts
Maximum Ratings
Operating Temperature: -55°C to +125°C
Storage Temperature: -55°C to +150°C
Maximum Thermal Resistance; 15 °C/W Junction To Lead
Catalog
Number
SK22B
SK23B
3
SK24B
SK25B
SK26B
SK28B
SK210B
Device
Marking
SK22
SK23
SK24
SK25
SK26
SK28
SK210
Maximum
Recurrent
Peak Reverse
Voltage
20V
30V
40V
50V
60V
80V
100V
Maximum
RMS
Voltage
DO-214AA
(SMB) (LEAD FRAME)
A
Maximum
DC
Blocking
Voltage
20V
30V
40V
50V
60V
80V
100V
14V
21V
28V
35V
42V
56V
70V
B
C
F
H
D
G
E
Electrical Characteristics @ 25°C Unless Otherwise Specified
Average Forward
Current
Peak Forward Surge
Current
Maximum
Instantaneous
Forward Voltage
SK22B-SK24B
SK25B-SK26B
SK28B-SK210B
Maximum DC Reverse
Current At Rated DC
Blocking Voltage
IF(AV)
2.0A
DIMENSIONS
TJ = 90°C
IFSM
50A
8.3ms, half sine
VF
0.55V
0.70V
0.85V
IFM = 2.0A;
TJ = 25°C*
DIM
A
B
C
D
E
F
G
H
INCHES
MIN
.160
.130
.006
.030
.200
.079
.075
.002
MM
MIN
4.06
3.30
0.15
0.76
5.08
2.00
1.91
0.05
MAX
.185
.155
.012
.060
.220
.096
.087
.008
MAX
4.70
3.94
0.31
1..52
5.59
2.44
2.21
0.203
NOTE
SUGGESTED SOLDER
PAD LAYOUT
0.106"
IR
TJ = 25°C
0.5 mA
Typical Junction
Capacitance
SK22B
SK23B-SK210B
0.083”
CJ
230pF
50pF
Measured at
1.0MHz, VR=4.0V
0.050”
*Pulse test: Pulse width 300 µsec, Duty cycle 2%
Note:
1. High Temperature Solder Exemptions Applied, see EU Directive Annex 7.
Rev : 01.06.2015
1/3
www.leiditech.com
SK22B
THRU
SK210B
Figure 1
Typical Forward Characteristics
Figure 3
Typical Junction Capacitance
100
10000
80
6000
60
4000
40
2000
pF
1000
600
10
8.0
200
6.0
100
0.
1.0
5.0
10
Volts
Junction Capacitance - pFversus
Reverse Voltage - Volts
Amps
4.0
125°C
0.5
50
100
25°C
2.0
1.0
.8
.6
Figure 4
New SMB Assembly
.4
.2
Round Lead
Process
.1
.2
.6
.8
1.0
1.2
1.4
Volts
Instantaneous Forward Current - Amperesversus
Instantaneous Forward Voltage - Volts
Figure 2
Typical Reverse Characteristics
1000
100
mA
125°C
10
1 75°C
.1
25°C
.001
10
15
30
35
40
45
50
Volts
Typical Reverse Current - mAversus
Rev : 01.06.2015
2/3
www.leiditech.com
SK22B
THRU
SK210B
Figure 1
Figure 3
100
1000
80
600
60
400
40
200
pF
100
60
10
8.0
125°C
25°C
10
6.0
Amps
4.0
1.0
5.0
10
Volts
0.
0.5
50
100
2.0
1.0
.8
Figure 4
New SMB Assembly
.6
.4
.2
Round Lead
Process
.1
.2
.6
.8
1.0
1.2
1.4
Volts
Figure 2
100
10
125°C
mA
1
.1 75°C
SK23B
SK24B
.01
25°C
.001
8
12
16
28
32
36
40
Volts
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev : 01.06.2015
3/3
www.leiditech.com
很抱歉,暂时无法提供与“SK26B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.43006
- 50+0.35023
- 150+0.31031
- 500+0.28037
- 3000+0.24853
- 6000+0.23656
