SS22B THRU SS220B
Surface Mount Schottky Barrier Rectifier
Reverse Voltage - 20 to 200V
Forward Current - 2.0A
PINNING
PIN
FEATURES
• Metal silicon junction, majority carrier conduction
• For surface mounted applications
• Low power loss, high efficiency
• High forward surge current capability
• For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
DESCRIPTION
1
Cathode
2
Anode
2
1
Top View
Simplified outline SMB and symbol
MECHANICAL DATA
• Case : SMB
• Terminals: Solderable per MIL-STD-750, Method 2026
• Approx. Weight : 0.055g / 0.002oz
Absolute Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,
for capacitive load, derate by 20 %
Parameter
Symbols
SS22B
SS24B
SS26B
SS28B
SS210B
SS212B
SS215B
SS220B
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
60
80
100
120
150
200
V
Maximum RMS voltage
V RMS
14
28
42
56
70
84
105
140
V
Maximum DC Blocking Voltage
V DC
60
80
100
120
150
200
V
Maximum Average Forward Rectified Current
I F(AV)
2.0
A
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
I FSM
50
A
Max Instantaneous Forward Voltage at 2 A
VF
Maximum DC Reverse Current T a = 25°C
T a =100°C
IR
0.5
5
0.3
3
mA
Typical Junction Capacitance(1)
Cj
220
110
pF
Typical Thermal Resistance (2)
RθJA
60
°C/W
Tj
-55 ~ +125
°C
T stg
-55 ~ +150
°C
at Rated DC Reverse Voltage
Operating Junction Temperature Range
Storage Temperature Range
0.55
0.70
0.85
0.95
V
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
Page 1 of 3
SS22B THRU SS220B
Fig.2 Typical Reverse Characteristics
Average Forward Current (A)
3.0
2.5
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
Instaneous Reverse Current ( μA)
F
Fiig . 1 F
Fo
or w a r d C
Cu
ur r e n t D
De
er a t i n g C
Cu
ur v e
10 4
T J =75°C
10 2
SS22B/SS26B
10
T J =25°C
10 0
80
Fig.4 Typical Junction Capacitance
T J =25°C
Junction Capacitance (pF)
T J =25°C
10
1.0
SS22B/SS24B
SS26B/SS28B
SS210B/SS212B
SS215B/SS220B
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
200
100
SS22B~SS 26B
SS28B~SS 220B
10
0.1
1
10
100
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.6- Typical Transient Thermal Impedance
SS22B-SS220B
50
40
30
8.3 ms Single Half Sine Wa ve
(JEDEC Method)
00
1
500
1.8
60
10
1000
Instaneous Forward Voltage (V)
10
Number of Cycles at 60Hz
100
Transient Thermal Impedance( °C /W)
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
Instaneous Forward Current (A)
SS28B-SS220B
1
Case Temperature (°C)
Peak Forward Surage Current (A)
T J =100°C
10 3
100
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
Page 2 of 3
SS22B THRU SS220B
PACKAGE OUTLINE
SMB
Plastic surface mounted package; 2 leads
L
A1
C
A
b
D
E
B
SMB mechanical data
A
E
D
B
A1
L
C
b
max
2.5
4.70
3.94
5.5
0.20
1.5
0.305
2.2
min
2.1
4.06
3.3
5.0
0.05
0.8
0.152
1.9
max
98
185
155
216
7.9
59
12
87
196
2.0
32
6
75
UNIT
mm
mil
min
82
130
160
The recommended mounting pad size
Marking
Type number
2.2
(86)
2.4
(94)
2.8
(110)
2.4
(94)
mm
Unit :
(mil)
Marking code
SS22B
SS22
SS24B
SS24
SS26B
SS26
SS28B
SS28
SS210B
SS210
SS212B
SS212
SS215B
SS215
SS220B
SS220
Page 3 of 3
很抱歉,暂时无法提供与“SS220B”相匹配的价格&库存,您可以联系我们找货
