RS2M(SMB)
RS2M(SMB)
    TWGMC(台湾迪嘉)
    DO-214AA(SMB)
    二极管配置:独立式 直流反向耐压(Vr):1kV 平均整流电流(Io):2A 正向压降(Vf):1.3V@2A 反向恢复时间(trr):500ns
RS2M(SMB) 数据手册
RS2AForward THRU RS2M Current - 2.0 Ampere Reverse Voltage - 50 to 1000 Volts PINNING PIN DESCRIPTION 1 Cathode 2 Anode FEATURES DO-214AA/SMB 2 1  For surface mounted applications  Low profile package  G lass Passivated Chip Junction  Easy to pick and place  Fast reverse recovery time  Lead free in comply with EU RoHS 2011/65/EU directives MECHANICAL DATA  Case : SMB  Terminals: Solderable per MIL-STD-750, Method 2026  A pprox. Weight: 0.091g / 0.003oz Unipolar Absolute Maximum Ratings and Characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20%. Symbols RS2A RS2B RS2D RS2G RS2J RS2K RS2M Units Maximum Repetitive Peak Reverse Voltage V RRM 50 100 200 400 600 800 1000 V Maximum RMS voltage V RMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage V DC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current I F(AV) 2 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load I FSM 60 A Maximum Forward Voltage at 2 A VF 1.3 V IR 5 100 μA Cj 28 pF Parameter Maximum DC Reverse Current T a = 25 °C at Rated DC Blocking Voltage T a =125 °C Typical Junction Capacitance at V R =4V, f=1MHz Maximum Reverse Recovery Time (1) Typical Thermal Resistance (2) Operating and Storage Temperature Range t rr 150 500 ns RθJA RθJC 60 20 °C/W T j , T stg -55 ~ +150 °C (1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A . (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. www.tw-gmc.com 250 1 RS2AForward THRU RS2M Current - 2.0 Ampere Reverse Voltage - 50 to 1000 Volts Typical Characterisitics Fig.2 Typical Reverse Characteristics Instaneous Reverse Current(μ A) Average Forward Current (A) Fig.1 Forward Current Derating Curve 3.0 2.5 2.0 1.5 1.0 0.5 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 175 100 T J =125°C 10 1.0 T J =25°C 0.1 00 T J =25°C 1.0 0.1 pulse with 300μs 1% duty cycle 0.01 0.0 1.0 1.5 2.0 2.5 Peak Forward Surage Current (A) 70 50 40 30 20 8.3 ms Single Half Sine Wave (JEDEC Method) 10 100 Number of Cycles www.tw-gmc.com 100 120 140 T J =25°C 10 T J=25°C f = 1.0MHz V sig = 50mV p-p 1.0 10 Reverse Voltage (V) 60 1 80 100 0.1 Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 00 60 1 0.5 Instaneous Forward Voltage (V) 10 40 Fig.4 Typical Junction Capacitance Junction Capacitance ( pF) Instaneous Forward Current (A) Fig.3 Typical Instaneous Forward Characteristics 10 20 percent of Rated Peak Reverse Voltage (%) Case Temperature (°C) 2 100 RS2AForward THRU RS2M Current - 2.0 Ampere Reverse Voltage - 50 to 1000 Volts PACKAGE OUTLINE Plastic surface mounted package; 2 leads SMB L A A1 C A b D E E1 VM A SMB mechanical data UNIT mm mil A E D max 2.44 4.70 3.94 min 2.13 4.06 3.3 A1 L C b 5.59 0.20 1.5 0.305 2.2 5.08 0.05 0.8 0.152 1.9 59 12 87 32 6 75 E1 max 96 185 155 220 7.9 min 84 160 130 200 2.0 The recommended mounting pad size 2.4 (94) 2.4 (94) 2.8 (110) 2.2 (86) mm Unit : (mil) www.tw-gmc.com 3
RS2M(SMB) 价格&库存
很抱歉,暂时无法提供与“RS2M(SMB)”相匹配的价格&库存,您可以联系我们找货
RS2M(SMB)
库存:594
