RS3AES2J
THRU RS3M
ES2A THRU
Reverse Voltage - 50 to 1000 Volts Forward Current - 3.0 Amperes
SURFACE MOUNT FAST RECOVERY RECTIFIERS
PIN
DESCRIPTION
1
C a thode
2
Anode
Features
For surface mounted applications
Low profile package
Glass Passivated Chip Junction
Easy to pick and place
Fast reverse recovery time
Lead free in comply with EU RoHS 2011/65/EU directives
DO-214AA/SMB
2
1
Mechanical Data
Case: SMB
Terminals: Solderable per MIL-STD-750, Method 2026
A pprox. Weight: 0.098g / 0.003oz
Unipolar
Absolute Maximum Ratings and Characteristics
Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
Symbols
RS3A
RS3B
RS3D
RS3G
RS3J
RS3K
RS3M
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified Current
I F(AV)
3
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
90
A
Maximum Forward Voltage at 3 A
VF
1.3
V
IR
5
100
μA
Cj
40
pF
Parameter
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance
at V R =4V, f=1MHz
Maximum Reverse Recovery Time
(1)
Typical Thermal Resistance (2)
Operating and Storage Temperature Range
t rr
500
ns
RθJA
RθJC
48
16
°C/W
T j , T stg
-55 ~ +150
°C
(1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
(2)P.C.B. mounted with 2.0" X 2.0 " ( 5 X 5 cm ) c o pp e r p ad areas.
www.tw-gmc.com
250
150
1
RS3AES2J
THRU RS3M
ES2A THRU
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current(μ A)
Average Forward Current (A)
Fig.1 Maximum Average Forward Current Rating
4.0
3.5
3.0
2.5
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
175
100
T J =125°C
10
1.0
T J =25°C
0.1
00
Case Temperature (°C)
T J =25°C
1.0
0.1
pulse with 300μs
1% duty cycle
0.01
0.0
1.0
1.5
2.0
2.5
Peak Forward Surage Current (A)
100
120
140
100
10
T J=25°C
f = 1.0MHz
V sig = 50mV p-p
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
10
1.0
10
Reverse Voltage (V)
120
100
Number of Cycles
www.tw-gmc.com
80
T J =25°C
0.1
Fig.5 Maximum Non-Repetitive Peak
1
60
1
0.5
Instaneous Forward Voltage (V)
00
40
Fig.4 Typical Junction Capacitance
Junction Capacitance ( pF)
Instaneous Forward Current (A)
Fig.3 Typical Instaneous Forward
Characteristics
10
percent of Rated Peak Reverse Voltage (%)
2
100
RS3AES2J
THRU RS3M
ES2A THRU
PACKAGE OUTLINE
SMB
Plastic surface mounted package; 2 leads
L
A
A1
C
A
b
D
E
E1
VM
A
SMB mechanical data
UNIT
mm
mil
A1
L
C
b
5.59
0.20
1.5
0.305
2.2
3.3
5.08
0.05
0.8
0.152
1.9
155
220
7.9
59
12
87
200
2.0
32
6
75
A
E
D
max
2.44
4.70
3.94
min
2.13
4.06
max
96
185
min
84
E1
130
160
The recommended mounting pad size
2.4
(94)
2.2
(86)
2.8
(110)
2.4
(94)
mm
Unit :
(mil)
www.tw-gmc.com
3
很抱歉,暂时无法提供与“RS3A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.15570
- 100+0.12687
- 300+0.11090
- 3000+0.09199
- 6000+0.08364
- 9000+0.07923
