SS520
SS520
    TWGMC(台湾迪嘉)
    DO-214AA(SMB)
    二极管配置:独立式 直流反向耐压(Vr):200V 平均整流电流(Io):5A 正向压降(Vf):550mV@5A
SS520 数据手册
SS52 Forward THRU SS520 Current - 5.0 Ampere Reverse Voltage - 20 to 200 Volts PINNING PIN Features DESCRIPTION 1 Cathode 2 Anode DO-214AA/SMB 2 1  Metal silicon junction, majority carrier conduction  For surface mounted applications  Low power loss, high efficiency  High forward surge current capability  For use in low voltage, high frequency inverters , free wheeling, and polarity protection applications MECHANICAL DATA  Case: SMB  Terminals: Solderable per MIL-STD-750, Method 2026  Approx. Weight: 0.055 g / 0 .002oz Unipolar Absolute Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load, for capacitive load, derate by 20 % Symbols Parameter SS52 SS54 SS56 SS58 SS510 SS512 SS5150 SS520 Units Maximum Repetitive Peak Reverse Voltage V RRM 20 40 60 80 100 120 150 200 V Maximum RMS voltage V RMS 14 28 42 56 70 84 105 140 V Maximum DC Blocking Voltage V DC 20 40 60 80 100 120 150 200 V Maximum Average Forward Rectified Current I F(AV) 5.0 A Peak Forward Surge Current,8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) I FSM 150 A Max Instantaneous Forward Voltage at 5 A Maximum DC Reverse Current T a = 25°C at Rated DC Reverse Voltage T a =100°C Typical Junction Capacitance (1) Typical Thermal Resistance (2) Operating Junction Temperature Range Storage Temperature Range VF 0.55 IR 1.0 50 0.3 25 mA Cj 500 300 pF 0.70 V RθJA 50 °C/W Tj -55 ~ +150 °C T stg -55 ~ +150 °C (1)Measured at 1MHz and applied reverse voltage of 4 V D.C. (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. www.tw-gmc.com 0.85 1 SS52 Forward THRU SS520 Current - 5.0 Ampere Reverse Voltage - 20 to 200 Volts Typical Characterisitics Fig.2 Typical Reverse Characteristics Instaneous Reverse Current ( μA) Fig.1 Forward Current Derating Curve Average Forward Current (A) 6.0 5.0 4.0 3.0 2.0 1.0 0.0 25 50 75 100 125 150 10 4 SS52~ SS56 SS510~ SS520 10 1 0 40 20 60 80 100 Percent of Rated Peak Reverse Voltage(%) Fig.4 Typical Junction Capacitance T J =25°C Junction Capacitance ( pF) 20 10 1 SS52~ SS54 SS56~ SS58 SS510~ SS520 0.1 0 0.5 1.0 1.5 100 SS52~SS54 SS56~SS520 20 10 0.1 10 1 100 Reverse Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Fig.6- Typical Transient Thermal Impedance 150 125 100 75 50 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 500 Instaneous Forward Voltage (V) 175 25 1000 2.0 Transient Thermal Impedance( °C /W) Instaneous Forward Current (A) T J =25°C 10 0 Fig.3 Typical Forward Characteristic Peak Forward Surage Current (A) T J =75°C 10 2 Case Temperature (°C) 10 100 Number of Cycles at 60Hz www.tw-gmc.com T J =100°C 10 3 100 10 1 0.01 0.1 1 10 t, Pulse Duration(sec) 2 100 SS52 Forward THRU SS520 Current - 5.0 Ampere Reverse Voltage - 20 to 200 Volts PACKAGE OUTLINE Plastic surface mounted package; 2 leads SMB L A A1 C A b D E E1 VM A SMB mechanical data UNIT mm mil A E D max 2.44 4.70 3.94 min 2.13 4.06 3.3 A1 L C b 5.59 0.20 1.5 0.305 2.2 5.08 0.05 0.8 0.152 1.9 59 12 87 32 6 75 E1 max 96 185 155 220 7.9 min 84 160 130 200 2.0 The recommended mounting pad size 2.4 (94) 2.4 (94) 2.8 (110) 2.2 (86) mm Unit : (mil) www.tw-gmc.com 3
SS520 价格&库存
很抱歉,暂时无法提供与“SS520”相匹配的价格&库存,您可以联系我们找货
SS520
  • 10+0.45393
  • 100+0.37163
  • 300+0.33048
  • 3000+0.25521
  • 6000+0.23048
  • 9000+0.21816
库存:1737
