ES2A THRU ES2J
Reverse Voltage - 50 to 600 Volts
Forward Current - 2.0 Ampere
PINNING
PIN
DESCRIPTION
1
Cathode
2
Anode
FEATURES
DO-214AA/SMB
2
1
For surface mounted applications
Low profile package
Glass Passivated Chip Junction
Superfast reverse recovery time
Lead free in comply with EU RoHS 2011/65/EU directives
MECHANICAL DATA
Case : SMB
Terminals: Solderable per MIL-STD-750, Method 2026
A pprox. Weight : 0.095g / 0.003oz
Unipolar
Absolute Maximum Ratings and Characteristics
Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
Symbols
ES2A
ES2B
ES2C
ES2D
ES2E
ES2G
E S2J
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
150
200
300
400
600
V
Maximum RMS voltage
V RMS
35
70
105
140
210
280
420
V
Maximum DC Blocking Voltage
V DC
50
100
150
200
300
400
600
V
Maximum Average Forward Rectified Current
at T c = 125 °C
I F(AV)
2
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
60
A
Maximum Forward Voltage at 2 A
VF
Parameter
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance
at V R =4V, f=1MHz
Maximum Reverse Recovery Time
(1)
Typical Thermal Resistance (2)
Operating and Storage Temperature Range
1.68
V
IR
5
100
μA
Cj
40
pF
t rr
35
ns
RθJA
RθJC
60
°C/W
T j , T stg
-55 ~ +150
°C
(1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
www.tw-gmc.com
1.25
1
1
ES2A THRU ES2J
Typical Characterisitics
Fig.1 Reverse Recovery Time Characteristic And Test Circuit Diagram
50 ohm
Noninductive
t rr
10 ohm
Noninductive
+0.5
D.U.T
PULSE
GENERATOR
Note 2
25Vdc
approx
1 ohm
NonInductive
OSCILLOSCOPE
Note 1
-1.0
Note:1.Rise Time = 7ns, max.
Input Impedance = 1megohm,22pF.
2. Ries Time =10ns, max.
Source Impedance = 50 ohms.
10ns/div
Set time Base for 10ns/div
Fig.3 Typical Reverse Characteristics
3.5
300
3.0
100
I R - Reverse Current ( μ A)
Average Forward Current (A)
Fig.2 Maximum Average Forward Current Rating
2.5
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz
T J =125°C
10
T J =75°C
1.0
T J =25°C
0.1
0.0
25
50
75
100
125
150
Case Temperature (°C)
10
T J =25°C
1.0
ES2A~ES2D
ES2E ~ ES2G
ES2J
0.01
0.5
1.5
1.0
2.0
2.5
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
80
70
60
50
40
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
www.tw-gmc.com
T J =25°C
10
T J=25°C
f = 1.0MHz
V sig = 50mV p-p
1.0
10
Reverse Voltage (V)
Fig.6 Maximum Non-Repetitive Peak
10
100
100
1
0.1
0.001
Fig.5 Typical Junction Capacitance
Junction Capacitance ( pF)
Instaneous Forward Current (A)
Fig.4 Typical Forward Characteristics
0.1
60
% of PIV.VOLTS
2
100
ES2A THRU ES2J
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SMB
L
A
A1
C
A
b
D
E
E1
VM
A
SMB mechanical data
UNIT
mm
mil
A
E
D
max
2.44
4.70
3.94
min
2.13
4.06
3.3
A1
L
C
b
5.59
0.20
1.5
0.305
2.2
5.08
0.05
0.8
0.152
1.9
59
12
87
32
6
75
E1
max
96
185
155
220
7.9
min
84
160
130
200
2.0
The recommended mounting pad size
2.4
(94)
2.4
(94)
2.8
(110)
2.2
(86)
mm
Unit :
(mil)
www.tw-gmc.com
3
很抱歉,暂时无法提供与“ES2D(SMB)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.13952
- 200+0.11338
- 600+0.09885
- 3000+0.08554
- 9000+0.07794
- 21000+0.07385
