RS2AForward
THRU
RS2M
Current - 2.0 Ampere
Reverse Voltage - 50 to 1000 Volts
PINNING
PIN
DESCRIPTION
1
Cathode
2
Anode
FEATURES
DO-214AA/SMB
2
1
For surface mounted applications
Low profile package
G lass Passivated Chip Junction
Easy to pick and place
Fast reverse recovery time
Lead free in comply with EU RoHS 2011/65/EU directives
MECHANICAL DATA
Case : SMB
Terminals: Solderable per MIL-STD-750, Method 2026
A pprox. Weight: 0.091g / 0.003oz
Unipolar
Absolute Maximum Ratings and Characteristics
Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
Symbols
RS2A
RS2B
RS2D
RS2G
RS2J
RS2K
RS2M
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified Current
I F(AV)
2
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
60
A
Maximum Forward Voltage at 2 A
VF
1.3
V
IR
5
100
μA
Cj
28
pF
Parameter
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance
at V R =4V, f=1MHz
Maximum Reverse Recovery Time
(1)
Typical Thermal Resistance (2)
Operating and Storage Temperature Range
t rr
150
500
ns
RθJA
RθJC
60
°C/W
T j , T stg
-55 ~ +150
°C
(1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
www.tw-gmc.com
250
1
RS2AForward
THRU
RS2M
Typical Characterisitics
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current(μ A)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
3.0
2.5
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
175
100
T J =125°C
10
1.0
T J =25°C
0.1
00
T J =25°C
1.0
0.1
pulse with 300μs
1% duty cycle
0.01
0.0
1.0
1.5
2.0
2.5
Peak Forward Surage Current (A)
70
50
40
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
10
100
Number of Cycles
www.tw-gmc.com
100
120
140
T J =25°C
10
T J=25°C
f = 1.0MHz
V sig = 50mV p-p
1.0
10
Reverse Voltage (V)
60
1
80
100
0.1
Fig.5 Maximum Non-Repetitive Peak
00
60
1
0.5
Instaneous Forward Voltage (V)
10
40
Fig.4 Typical Junction Capacitance
Junction Capacitance ( pF)
Instaneous Forward Current (A)
Fig.3 Typical Instaneous Forward
Characteristics
10
percent of Rated Peak Reverse Voltage (%)
Case Temperature (°C)
2
100
RS2AForward
THRU
RS2M
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SMB
L
A
A1
C
A
b
D
E
E1
VM
A
SMB mechanical data
UNIT
mm
mil
A
E
D
max
2.44
4.70
3.94
min
2.13
4.06
3.3
A1
L
C
b
5.59
0.20
1.5
0.305
2.2
5.08
0.05
0.8
0.152
1.9
59
12
87
32
6
75
E1
max
96
185
155
220
7.9
min
84
160
130
200
2.0
The recommended mounting pad size
2.4
(94)
2.4
(94)
2.8
(110)
2.2
(86)
mm
Unit :
(mil)
www.tw-gmc.com
3
很抱歉,暂时无法提供与“RS2J(SMB)”相匹配的价格&库存,您可以联系我们找货
