ES8A THRU ES8J SMC
Surface Mount Superfast Recovery Rectifier
Pinning
Reverse Voltage - 50 to 600 V
1.Cathode
Forward Current - 8 A
1
FEATURES
Glass Passivated Chip Junction
For surface mounted applications
Low profile package
Superfast reverse recovery time
2.Anode
2
DO-214AB/SMC
Lead free in comply with EU RoHS 2011/65/EU directives
MECHANICAL DATA
Case: DO-214AB/SMC
Terminals: Solderable per MIL-STD-750, Method 2026
Approx. Weight: 0.22g / 0.0077oz
Marking Code
ES8A
ES8A
ES8B
ES8B
ES8D
ES8D
ES8G
ES8G
ES8J
ES8J
Absolute Maximum Ratings and characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
ES8A
ES8B
ES8D
ES8G
ES8J
Units
Maximum Repetitive Peak Reverse Voltage
VRRM
50
100
200
400
600
V
Maximum RMS voltage
VRMS
35
70
140
280
420
V
Maximum DC Blocking Voltage
VDC
50
100
200
400
600
V
Maximum Average Forward Rectified Current
at Tc = 125 °C
IF(AV)
8
A
Peak Forward Surge Current 8.3 ms Single
Half Sine Wave Superimposed on Rated Load
IFSM
125
A
Maximum Instantaneous Forward Voltage at 8 A
VF
Parameter
Maximum DC Reverse Current Ta = 25 °C
0.95
1.25
1.65
V
IR
10
350
μA
Typical Junction Capacitance at VR=4V,f=1MHZ
Cj
90
pF
Maximum Reverse Recovery Time(1)
Trr
35
nS
RθJA/ RθJC
75/20
°C/W
Tj, Tstg
-55 ~ +150
°C
at Rated DC Blocking Voltage
Ta=125 °C
Typical Thermal Resistance (2)
Operating and Storage Temperature Range
(1)Measured with IF=0.5A,IR=1A,In=0.25A
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
www.yfwdiode.com
1/3
G uangDong YFW Electronics Co, Ltd.
ES8A THRU ES8J SMC
Fig.1 Reverse Recovery Time Characteristic And Test Circuit Diagram
50 ohm
Noninductive
t rr
10 ohm
Noninductive
+0.5
D.U.T
PULSE
GENERATOR
Note 2
25Vdc
approx
1 ohm
NonInductive
OSCILLOSCOPE
Note 1
-1.0
Note:1.Rise Time = 7ns, max.
Input Impedance = 1megohm,22pF.
2. Ries Time =10ns, max.
Source Impedance = 50 ohms.
10ns/div
Set time Base for 10ns/div
Fig.3 Typical Reverse Characteristics
11.2
300
9.6
100
I R - Reverse Current ( μ A)
Average Forward Current (A)
Fig.2 Maximum Average Forward Current Rating
8.0
6.4
4.8
3.2
1.6
T J =125°C
10
T J =75°C
1.0
T J =25°C
0.1
0.0
25
50
75
100
125
150
Case Temperature (°C)
Junction Capacitance ( pF)
Instaneous Forward Current (A)
T J =25°C
10
ES8AC~ES8DC
ES8EC/ES8GC
ES8JC
0.1
1.0
1.5
2.0
T J =25°C
100
10
T J=25°C
f = 1.0MHz
V sig = 50mV p-p
1
0.1
0.01
0.5
100
Fig.5 Typical Junction Capacitance
100
% of PIV.VOLTS
Fig.4 Typical Forward Characteristics
1.0
60
2.5
Instaneous Forward Voltage (V)
1.0
10
100
Reverse Voltage (V)
Peak Forward Surage Current (A)
Fig.6 Maximum Non-Repetitive Peak
126
105
84
63
42
21
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
www.yfwdiode.com
2/3
ES8A THRU ES8J SMC
DO-214AB SMC
Package Outline
Plastic surface mounted package; 2 leads
E
A
A1
A
C
b
D
L
E1
VM
A
A
E
D
E1
A1
C
L
b
max
2.62
7.0
6.2
8.0
0.21
0.31
1.6
3.25
min
2.00
6.5
5.6
7.6
0.05
0.15
0.9
2.75
max
103
276
244
315
8.3
12
63
128
min
79
256
220
299
2.0
5.9
35
108
UNIT
mm
mil
The recommended mounting pad size
4.1
(160)
3.8
(150)
4.3
(170)
4.1
(160)
mm
Unit :
(mil)
Summary of Packing Options
Package
DO-214AB SMC
www.yfwdiode.com
Packing Description
Packing Quantity
Industry Standard
Tape/Reel,13”reel
3000
EIA-481-1
3/3
很抱歉,暂时无法提供与“ES8J”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.76302
- 50+0.61701
- 150+0.54400
- 500+0.48924
- 3000+0.44540
- 6000+0.42347
