Niu Hang
Electronic Co. Ltd
Specification
For Approval
ES8JH
SUPER FAST RECOVERY RECTIFIERS
VOLTAGE:
730
Volts
CURRENT: 8.0
Amperes
SMC(DO-214AB)
Marking and Polarity
FEATURES
Glass passivated chip junction
Super fast reveESe recovery time
FFYWW
Low Forward Voltage Drop for high efficiency
Low leakage current for high reliability
High forward surge capability for high reliability
ES8JH
MECHANICAL DATA
Terminals: Plated Leads Solderable per MIL-STD-202, Method 208
Mounting Position: Any
Lead Free: Lead Free Finish, RoHS Compliant
Remark:
Weight:App. 0.254 grams(0.009 ounce)
①. NH=niuhang trademark
②. FF=Product line,According to actual changes;
TYPICAL APPLICATIONS
For use in high frequency inverteES ,AC/DC converteES,
YWW=Periodic code,According to actual changes;
③. ES8JH=Modle
④. White band denotes cathode
DC/DC converteES,LED driver etc. applications
Maximum Ratings (Ratings at 25℃ ambient temperature unless otherwise specified.)
Parameter
Symbol
ES8JH
Unit
Maximum repetitive peak reverse voltage
V RRM
730
V
Maximum RMS voltage
V RMS
511
V
V DC
730
V
IF (AV)
5
A
Peak forward surge current 8.3ms single half sine-wave
superimposed on rated load (JEDEC method at rated TL)
I FSM
180
A
Maximum instantaneous forward voltage at 5.0 A (Note 1)
VF
1.7
V
Maximum DC blocking voltage
Maximum average forward rectified current(see fig.1)
Maximum instantaneous reversecurrent at rated DC
blockingvoltage (Note 2)
TA=25℃
5
I RRM
uA
TA=100℃
100
Maximum Reverse Recovery Time (Note 3)
T RR
35
nS
Typical junction capacitance (Note 4)
CJ
90
pF
Operating junction and Storage temperature range
TJ
-55 to +150
T STG
-55 to +150
Thermal Characteristcs (Ratings at 25℃ ambient temperature unless otherwise specified )
Parameter
Typical thermal resistance (Note 5)
Symbol
ES8JH
Unit
R θJA
105
℃/W
1.Pulse test: 300 μs pulse width,1% duty cycle
Note:
2.Pulse test: pulse width≤40ms
3. Reverse Recovery Time test condition: IF=0.5A, IR=1.0A, IRR=0.25A
4.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
5.Thermal resistance from junction to lead vertical P.C.B. mounted , 0.375"(9.5mm)lead length
Http://www.nh-semicon.com
Data:2014/10/20
Rev.:A/1
Page: 1 of 5
Niu Hang
Electronic Co. Ltd
Specification
For Approval
ES8JH
RATINGANDCHARACTERISTICCURVES
10
8
IF FORWARD CURRENT(A)
AVERAGE FORWARD CURRENT,(A)
10
6
Single phase half wave
60HZ Resistive or
inductive Load
4
2
50
75
100
125
150
0.1
0.01
175
0.4
0.8
1.2
1.6
2
Tc, Case Temp (℃)
VF,FORWARD VOLTAGE(A)
Fig.1-FORWARD CURRENT DERATING CURVE
Fig.2-TYPEICAL FORWARD CHARACTERISTICS
1000
10000
JUNCTION CAPACITANCE,(pF)
1000
IR,REVERSE CURRENT(uA)
1
100
10
1
0.1
0.01
60
80
100
10
100
1
25℃
0.1
100℃
1
10
100
PERCENT OF RATED PEAK REVERSE VOLTAGE%
REVERSE VOLTAGE,(V)
Fig.3- TYPICAL REVERSE CHARACTERISTICS
Fig.4- TYPICAL JUNCTION CAPACITANCE
PEAK FORWARD SURGE CURRENT (A)
200
TJ=TJMAX.
8.3ms SINGLE
HALF SINE-
160
120
80
40
10
100
NUMBER OF CYCLES AT 60HZ
Fig.5-MAX. NON-REPETITIVE SURGE CURRENT
Data:2014/10/20
Fig.6-REVERSE RECOVERY TIME CHARACTERISTIC AND TEST CIRCUIT
Rev.:A/1
Page: 2 of 5
Niu Hang
Electronic Co. Ltd
Specification
For Approval
ES8JH
OUTLINE DRAWINGS
SMC(DO-214AB)
OUTLINE DIMENSIONS
Milimeters
Inches
Dim.
RECOMMEDNED LAYOUT DRAWINGS
Min.
Typ.
Max.
Min.
Typ.
Max.
A
6.600
7.110
0.260
0.280
B
7.750
8.130
0.305
0.320
C
5.590
6.220
0.220
0.245
D
2.000
2.620
0.079
0.103
E
2.750
3.250
0.108
0.128
F
0.760
1.520
0.030
0.060
G
0.051
0.203
0.002
0.008
H
0.152
0.305
0.006
0.012
SMC(DO-214AB)
RECOMMEDNED MOUNTING PAD DIMENSIONS
Milimeters
Inches
Dim.
PACKING INFORMATION
Min.
Typ.
Max.
Min.
Typ.
Max.
A
9.900
0.390
B
3.820
0.150
C
3.840
0.151
D
3.030
0.119
SMC(DO-214AB)
Package
Method
Reel Size
(mm)
Quantity
(pcs/reel)
Inner Box Size
L×W×H(mm)
Quantity
(pcs/Inner Box)
Carton Size
L×W×H(mm)
Quantity
(pcs/carton)
Tape Reel
Φ330
3000
340×340×45
6000
360×360×470
60000
Data:2014/10/20
Rev.:A/1
Page: 3 of 5
Niu Hang
Electronic Co. Ltd
Specification
For Approval
ES8JH
Recommended wave soldering condition
Product
Pb-free devices
Peak Temperature
260 +0/-5 °C
Soldering Time
5 +1/-1 seconds
Profile feature
Sn-Pb eutectic Assembly
Pb-free Assembly
Average ramp-up rate
(Tsmax to Tp)
3°C/second max.
3°C/second max.
Preheat
−Temperature Min(TS min)
−Temperature Max(TS max)
−Time(ts min to ts max)
100°C
150°C
60-120 seconds
150°C
200°C
60-180 seconds
Time maintained above:
−Temperature (TL)
− Time (tL)
183°C
60-150 seconds
217°C
60-150 seconds
Peak Temperature(TP)
240 +0/-5 °C
260 +0/-5 °C
Time within 5°C of actual peak
temperature(tp)
10-30 seconds
20-40 seconds
Ramp down rate
6°C/second max.
6°C/second max.
Recommended temperature profile for IR reflow
Time 25 °C to peak temperature
6 minutes max.
8 minutes max.
Note : All temperatures refer to topside of the package, measured on the package body surface.
Data:2014/10/20
Rev.:A/1
Page: 4 of 5
Niu Hang
Electronic Co. Ltd
Specification
For Approval
ES8JH
Disclaimer
Reproducing and modifying informatiom of the document is prohibited without permission
from niuhang Electronics co., LTD
Niuhang Electronics co., LTD. reserves the rights to make changes of the content herein
the document anytime without notification.
Niuhang Electronics co., LTD. disclaims any and all liability arising out of the application or
use of any product including damages incidentally and consequentially occurred.
Niuhang Electronics co., LTD. does not assume any and all implied warranties,
including warranties of fitness for particular purpose,non-infringement and merchantability.
Applications shown on the herein document are examples of standard use and operation.
Customers are responsible in comprehending the suitable use in particular applications.
Niuhang Electronics co., LTD.makes no representation or warranty that such applications will
be suitable for the specified use without further testing or modification.
The products shown herein are not designed and authorized for equipments requiring high
level of reliability or relating to human life and for any applications concerning life-saving or
life-sustaining,such as medical instruments.transportation equipment,aerospae machinery
et cetera.Customers usin or selling these products for use in such applications do so at their
own rish and agree to fully indemnify Niuhang Electronics co., LTD.for any damages resulting
resulting from such improper use or sale.
When the appearance of the product and chip size does not change, in order to product
the customer.
quality, change the internal structure and the production process Niuhang can not notify
Data:2014/10/20
Rev.:A/1
Page: 5 of 5
很抱歉,暂时无法提供与“ES8JH”相匹配的价格&库存,您可以联系我们找货
