SS810
SS810
    DOESHARE(德芯)
    DO-214AB(SMC)
SS810 数据手册
SS82 THUR SS820 Schottky Barrier Rectifiers General description 8.0Amp Surface Mounted Schottky Barrier Rectifiers DO-214AB/SMC FEATURES • Flammability Classification 94V-0 • For surface mounted applications • Low reverse leakage • Built-in strain relief,ideal for automated placement • Low power loss,high efficiency • High forward surge current capability MECHANICAL DATA • Terminals:Solder plated, solderable per MIL-STD-750, Method 2026 • Polarity: Color band denotes positive end (cathode) • Case:Molded plastic body Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified.Single phase half-wave 60Hz,resistive or inductive load, for capacitive load current derate by 20%. Parameter SYMBOLS SS82 SS84 SS86 SS88 SS810 SS815 SS820 UNITS Maximum repetitive peak reverse voltage VRRM 20 40 60 80 100 150 200 V Maximum RMS voltage VRMS 14 28 42 56 70 105 140 V Maximum DC blocking voltage VDC 20 40 60 80 100 150 200 V Maximum average forward rectified current at TL =100℃ I(AV) 8.0 A Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load IFSM 150.0 A Maximum instantaneous forward voltage at 8.0A VF Maximum DC reverse current TA =25 ℃ at rated DC blocking voltage TA=125 ℃ Typical thermal resistance Operating junction temperature range Storage temperature range www.doeshare.net IR RqJA 0.70 0.55 0.85 0.5 50 0.95 0.05 10 47.0 V mA ℃/W TJ -55 to +150 ℃ TSTG -55 to +150 ℃ 1/4 SS82 THUR SS820 Rating And Characteristic Curves www.doeshare.net 2/4 SS82 THUR SS820 Suggested Pad Layout Symbol Unit (mm) Unit (inch) A 0.130 B 3.30 2.50 C 6.80 0.268 D 4.40 0.173 E 9.40 0.370 0.098 Suggested Soldering Temperature Profile www.doeshare.net 3/4 SS82 THUR SS820 Important Notice and Disclaimer DOESHARE has used reasonable care in preparing the information included in this document, but DOESHARE does not warrant that such information is error free. DOESHARE assumes no liability whatsoever for any damages incurred by you resulting from errors in or omissions from the information included herein. DOESHARE no warranty, representation or guarantee regarding the documents, circuits and products specification, DOESHARE reservation rights to make changes for any documents, products, circuits and specifications at any time without notice. Purchasers are solely responsible for the choice, selection and use of the DOESHARE products and services described herein, and DOESHARE assumes no liability whatsoever relating to the choice, selection or use of the products and services described herein. No license, express or implied, by implication or otherwise under any intellectual property rights of DOESHARE. Resale of DOESHARE products with provisions different from the statements and/or technical features set forth in this document shall immediately void any warranty granted by DOESHARE for the DOESHARE product or service described herein and shall not create or extend in any manner whatsoever, any liability of DOESHARE. www.doeshare.net 4/4
SS810 价格&库存
很抱歉,暂时无法提供与“SS810”相匹配的价格&库存,您可以联系我们找货
