SS32
SS32
    DOESHARE(德芯)
    DO-214AB(SMC)
SS32 数据手册
SS32 THUR SS310 SS32 THUR SS310 Schottky Barrier Rectifiers SMC/DO214AB General description 3.0Amp Surface Mounted Schottky Barrier Rectifiers FEATURES • Flammability Classification 94V-O • Plastic package has Underwriters Laboratory • For surface mounted applications • Built-in strain relief • High surge capacity MECHANICAL DATA • Case: JEDEC DO-214AB molded plastic • Terminals: Solder plated, solderable per MIL-STD-750 Method 2026 • Polarity: Color band denotes cathode • Weight: 0.007 ounce, 0.25 gram Unit: inch (mm) Maximum Ratings And Electrical Characteristics Characteristic Symbol SS32 SS33 SS34 SS35 SS36 SS38 SS39 SS310 Unit Marking Code Mark SS32 SS33 SS34 SS35 SS36 SS38 SS39 SS310 N/A Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage VRRM VRWM VR 20 30 40 50 60 80 90 100 V VR(RMS) 14 21 28 35 42 56 64 70 V RMS Reverse Voltage Average Rectified Output Current IO 3.0 A Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 100 A Forward Voltage V FM @IF = 5.0A 0.45 0.55 0.6 0.7 0.85 V Peak Reverse Current @TA = 25°C At Rated DC Blocking Voltage @TA = 100°C IRM 0.5 20 mA Typical Thermal Resistance Junction to Ambient (Note 1) RJA 55 K/W Typical junction capacitance CJ Operating Temperature Range Tj -55 to +150 °C TSTG -55 to +150 °C Storage Temperature Range 500 Note: 1.Measured at 1.0 MHz and applied reverse voltage of 4.0V DC 2.Thermal resistance junction to ambient www.doeshare.net 350 pF SS32 THUR SS310 Rating And Characteristic Curves www.doeshare.net SS32 THUR SS310 Important Notice and Disclaimer DOESHARE has used reasonable care in preparing the information included in this document, but DOESHARE does not warrant that such information is error free. DOESHARE assumes no liability whatsoever for any damages incurred by you resulting from errors in or omissions from the information included herein. DOESHARE no warranty, representation or guarantee regarding the documents, circuits and products specification, DOESHARE reservation rights to make changes for any documents, products, circuits and specifications at any time without notice. Purchasers are solely responsible for the choice, selection and use of the DOESHARE products and services described herein, and DOESHARE assumes no liability whatsoever relating to the choice, selection or use of the products and services described herein. No license, express or implied, by implication or otherwise under any intellectual property rights of DOESHARE. Resale of DOESHARE products with provisions different from the statements and/or technical features set forth in this document shall immediately void any warranty granted by DOESHARE for the DOESHARE product or service described herein and shall not create or extend in any manner whatsoever, any liability of DOESHARE. www.doeshare.net
很抱歉,暂时无法提供与“SS32”相匹配的价格&库存,您可以联系我们找货
SS32
    库存:24
