SS52C~SS520C
Rev. B Feb.-2021
DATA SHEET
描述 / Descriptions
表面贴装肖特基整流二极管,反向电压:20~200V,正向电流:5.0A,SMC 封装。
Surface Mount Schottky Barrier Rectifier, Reverse Voltage:20 to 200 V, Forward Current:5.0A ,SMC
package.
特征 / Features
低功耗,高效率,正向浪涌电流大,适用于低压高频逆变器和极性保护,适用于表面贴装,无卤产品。
Low power loss, high efficiency, High forward surge current capability, For use in low voltage, high
frequency inverters, and polarity protection applications,For surface mounted applications,Halogen
free product.
用途 /
Applications
一般用途.
General purpose.
内部等效电路 / Equivalent Circuit
引脚排列 / Pinning
印章代码 / Marking
见印章说明。See Marking Instructions.
http://www.fsbrec.com
1/7
SS52C~SS520C
Rev. B Feb.-2021
极限参数 /
DATA SHEET
Absolute Maximum Ratings(Ta=25℃)
参数
Parameter
符号
Symbol
Maximum Repetitive
Peak Reverse
Voltage
Maximum RMS
voltage
Maximum DC
Blocking Voltage
Maximum Average
Forward Rectified
Current
Peak Forward Surge
Current,8.3ms
Single Half
Sine-wave
Superimposed
on Rated Load
(JEDEC method)
Typical Junction
1)
Capacitance
Typical Thermal
2)
Resistance
Operating Junction
Temperature Range
Storage Temperature
Range
数值
Rating
SS52C SS54C SS56C SS58C SS510C SS512C
SS515C
SS520C
单位
Unit
VRRM
60
80
100
120
150
200
V
VRMS
14
28
42
56
70
84
105
140
V
VDC
60
80
100
120
150
200
V
IF(AV)
IFSM
Ci
A
5.0
175
150
600
400
A
pF
RθJA
35
℃/W
Tj
-55~+150
Tstg
-55~+150
Note:
1) Measured at 1MHz and applied reverse voltage of 4 V D.C.
2) P.C.B. mounted with 2.0 X 2.0" (5 X 5 cm) copper pad areas.
电性能参数 / Electrical Characteristics(Ta=25℃)
数值
Rating
测试条
参数
Parameter
Max
Instantaneo
us Forward
Voltage
Maximum DC
Reverse
Current
at Rated DC
Reverse
Voltage
符号
Symbol
VF
件
Test
SS52C SS54C
Conditions
IF=5.0A
0.55
SS56C SS58C SS510C SS512C SS515C SS520C
0.70
0.85
Ta=25℃
1.0
Ta=100℃
50
单位
Unit
V
mA
IR
2/7
SS52C~SS520C
Rev. B Feb.-2021
DATA SHEET
电参数曲线图 / Electrical Characteristic Curve
3/7
SS52C~SS520C
Rev. B Feb.-2021
DATA SHEET
外形尺寸图 / Package Dimensions
4/7
SS52C~SS520C
Rev. B Feb.-2021
DATA SHEET
印章说明 / Marking Instructions
5/7
SS52C~SS520C
Rev. B Feb.-2021
DATA SHEET
SS52
说明
SS52:
为型号代码
为生产批号追溯码,第 1 个*为年月代码,后面 3 个*为当月小批号代码
Note:
SS52:
Product Type Code
Lot No. Code,The 1st * means:YM Code,The last 3 * means:little Lot
No Code
6/7
SS52C~SS520C
Rev. B Feb.-2021
DATA SHEET
回流焊温度曲线图(无铅) / Temperature Profile for IR Reflow Soldering(Pb-Free)
说明:
Note:
1、预热温度 25~150℃,时间 60~90sec;
1.Preheating:25~150℃, Time:60~90sec.
2、峰值温度 245±5℃,时间持续为 5±0.5sec;
2.Peak Temp.:245±5℃, Duration:5±0.5sec.
3、焊接制程冷却速度为 2~10℃/sec.
3. Cooling Speed: 2~10℃/sec.
耐焊接热试验条件 /
Resistance to Soldering Heat Test Conditions
温度:260±5℃
时间:10±1 sec.
Temp.:260±5℃
Time:10±1 sec
包装规格 / Packaging SPEC.
卷盘包装 / REEL
Package Type
封装形式
SMC
Dimension 包装尺寸 (unit:mm3)
Units 包装数量
Units/Reel
只/卷盘
Reels/Inner Box
卷盘/盒
Units/Inner Box
只/盒
Inner Boxes/Outer Box
盒/箱
Units/Outer Box
只/箱
Reel
Inner Box 盒
Outer Box 箱
3000
2
6000
6
36000
13〞×16
337X337X49
380X335X366
使用说明 / Notices
7/7
很抱歉,暂时无法提供与“SS520C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.64476
- 50+0.56614
- 150+0.52683
- 500+0.49734
