MUR320S
MUR320S
    AM(安美)
    DO-214AB(SMC)
    晶片:FRED
MUR320S 数据手册
MUR305S THRU MUR360S Ultra-Fast Recovery Rectifier Diodes FRED Features ● ● ● ● ● ● Low profile package Ideal for automated placement Glass passivated chip junction Super fast reverse recovery time High forward surge capability Meets MSL level 1, per J-STD-020,LF maximum peak of 260 °C Typical Application For use in high frequency rectification of power supply, inverters, converters, and freewheeling diodes for consumer and telecommunication. Mechanical Data ● ● ● Package: DO-214AB(SMC) Molding compound meets UL 94 V-0 flammability rating,RoHS-compliant Terminals:Tin plated leads, solderable per J-STD-002 and JESD22-B102 Polarity: Cathode line denotes the cathode end ■ Maximum Ratings (Ta=25℃ Unless otherwise specified) 310 MURXXXS 315 320 340 360 50 100 150 400 600 340 360 Unit VRRM V Io A Surge(Nonrepetitive)Forward Current IFSM A Storage Temperature Tstg ℃ -55 ~ +175 Junction Temperature Tj ℃ -55 ~ +175 Repetitive Peak Reverse Voltage Average Forward Current Conditions 305 Symbol PARAMETER wave, Half-sine 60HZ Resistance load, Tc(Fig.1) 60HZ sine wave, 1 cycle, Ta=25℃ 200 3 120 Electrical Characteristics(Ta=25℃ Unless otherwise specified) PARAMETER Peak Forward Voltage Peak Reverse Current Maximum reverse recovery time Thermal Resistance Document Number:804012 Revision:21-Mar-20 Symbo l VFM IRRM1 Unit V Conditions 305 310 315 320 @Ta=25℃ 0.875 1.25 @Ta=150℃ 0.710 1.05 Ta=25℃ 5 10 Ta=125℃ 150 250 25 50 μA VRM=VRRM Trr ns IF=0.5A,IR=1.0A,Irr=0.25A RθJ-L ℃/W IRRM2 MURXXXS Between junction and Line An hui Anmei Semiconductor Co.,Ltd. 11 www.amsemi.com.cn ~1~ MUR305S THRU MUR360S Ultra-Fast Recovery Rectifier Diodes FRED ■ Characteristics(Typical) FIG1: Forward Current Derating Curve FIG2:Surge Forward Current Capability FIG3:Instantaneous Forward Voltage FIG4:Typical Reverse Characteristics FIG5:Diagram of circuit and Testing wave form of reverse recovery time Document Number:804012 Revision:21-Mar-20 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~2~ MUR305S THRU MUR360S Ultra-Fast Recovery Rectifier Diodes FRED ■ Ordering Information (Example) PREFERED MUR305S~MUR360S PACKAGE CODE DO-214AB(SMC) MINIMUM PACKAGE(pcs) 3000 INNER BOX OUTER CARTON QUANTITY(pcs) QUANTITY(pcs) 6000 42000 DELIVERY MODE 13” reel ■ Outline Dimensions Document Number:804012 Revision:21-Mar-20 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~3~ MUR305S THRU MUR360S Ultra-Fast Recovery Rectifier Diodes FRED IMPORTANT NOTICE AND DISCLAIMER AM RESERVES THE RIGHT TO MAKE CHANGES TO ALL PRODUCT, PRODUCT SPECIFICATIONS AND DATA WITHOUT NOTICE TO IMPROVE RELIABILITY, FUNCTION OR DESIGN OR OTHERWISE. CUSTOMERS SHOULD OBTAIN AND CONFIRM THE LATEST PRODUCT INFORMATION AND SPECIFICATIONS BEFORE FINAL DESIGN PURCHASE OR USE. AM disclaim any and all liability for any errors, inaccuracies or incompleteness contained in any datasheet or in any other disclosure relating to any product. All information are provided as-is, even it has qualified by the AEC-Q101 which satisfy industrial application requirement, except as expressly stated in this data sheet is applied for automotive grade, AM make no warranties, representation or guarantee, whether express, implied or statutory, including, without limitation, regarding any merchantability, satisfactory quality, or fitness for a particular purpose with respect to AM. Am does not assume any liability or compensation for any application assistance or customer product design, and make no warranty or accept any liability with products, which are purchased or used for any unintended or unauthorized application. Except as expressly indicated in writing, AM products are not designed for use in medical, life-saving, or lifesustaining applications or for any other application in which the failure of the AM product could result in personal injury or death. Customers using or selling AM products not expressly indicated for use in such applications do so at their own risk. Please contact authorized AM personnel to obtain written terms and conditions regarding products designed for such applications. No license, express or implied, by estoppel or otherwise, to any intellectual property rights is granted by this document or by any conduct of AM. Product names and markings noted herein may be trademarks of their respective owners. Document Number:804012 Revision:21-Mar-20 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~4~
MUR320S 价格&库存
很抱歉,暂时无法提供与“MUR320S”相匹配的价格&库存,您可以联系我们找货
MUR320S
    • 5+0.59886
    • 50+0.58493
    • 150+0.57554
    • 500+0.56625
    库存:2502
