SS10100C
SS10100C
    RS(容硕)
    DO-214AB(SMC)
SS10100C 数据手册
SS1045C SS10200C 10.0 AMP SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS VOLTAGE RANGE 45 to 200 Volts CURRENT 10.0Ampere FEATURES * * * * Ideal for surface mount applications Easy pick and place Built-in strain relief Low forward voltage drop MECHANICAL DATA * Case: Molded plastic * Epoxy: UL 94V-0 rate flame retardant * Metallurgically bonded construction * Polarity: Color band denotes cathode end * Mounting position: Any * Weight: 0.21 grams Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER Maximum Maximum Maximum Maximum Recurrent Peak Reverse Voltage RMS Voltage DC Blocking Voltage Average Forward Rectified Current SS1045C SS1060C 60 42 60 45 32 45 Peak Forward Surge Current, 8.3 ms single half sine-wave superimposed on rated load (JEDEC method) Typical Junction Capacitance (Note1) Typical Thermal Resistance R JA (Note 2) Operating Temperature Range TJ Storage Temperature Range TSTG 100 70 100 SS10150C SS10200C UNITS 150 105 150 200 140 200 175 0.55 0.1 0.7 0.85 0.02 2 5 440 60 55 to +150 55 to +150 V V V A 10.0 See Fig. 1 Maximum Instantaneous Forward Voltage at 10.0A Ta=25 C Maximum DC Reverse Current at Rated DC Blocking Voltage Ta=125 C SS10100C 0.92 A V A mA pF C/W C C NOTES: 1. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2. Thermal Resistance Junction to Lead. REV 1.0 2017 JAN PAGE:1/2 RATING AND CHARACTERISTIC CURVES (SS1045C THRU SS10200C) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL FORWARD CHARACTERISTICS 12 50 10 8 6 10 4 5.0 2 0 0 20 40 60 80 100 120 140 160 180 200 1.0 CASE TEMPERATURE,( C) Tj= 25 C Pulse Width 30 0u s 1% Duty Cycl e 0.1 FIG.3-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT 250 .01 200 .1 .3 .5 .7 .9 1.1 1.3 1.5 FORWARD VOLTAGE,(V) 150 s 100 50 FIG.5 - TYPICAL REVERSE 0 1 5 10 50 100 CHARACTERISTICS 100 NUMBER OF CYCLES AT 60Hz FIG.4-TYPICAL JUNCTION CAPACITANCE 10 2800 T j=100 C 2400 2000 1.0 1600 T 1200 C .1 800 400 0 j=75 Tj = .01 .05 .1 .5 1 REVERSE VOLTAGE,(V) 5 10 50 100 .01 0 20 40 25 C 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) REV 1.0 2017 JAN PAGE:2/2
SS10100C 价格&库存
很抱歉,暂时无法提供与“SS10100C”相匹配的价格&库存,您可以联系我们找货
SS10100C
    • 5+0.44262
    • 50+0.38865
    • 150+0.36166
    • 500+0.34135
    • 3000+0.32525
    • 6000+0.31714
    库存:9203
