RS5MC
RS5MC
    HONGJIACHENG(宏嘉诚)
    DO-214AB(SMC)
RS5MC 数据手册
� �D� 宏迦橙 RS5AC THRU RS5MC SURFACE MOUNT FAST RECOVERY RECTIFIER www.ichjc.com Features DO-214AB(SMC) •Low profile package •Ideal for automated placement •Glass passivated pallet chip junction •Fast reverse recovery time •Fast switching for high efficiency •High forward surge capability Applications For use in fast switching rectification of power supplies,inverters, converters, and free wheeling diodes forconsumer, and telecommunication. Mechanical Data •Case: DO-214AB(SMC) Molding compound meets UL 94V-0 flammability rating, RoHS-compliant, halogen-free •Terminals: Solder plated, solderable per MIL-STD-750,Method 2026 •Polarity: Cathode line denotes the cathode end Maximum Ratings (Ta=25℃ Unless otherwise specified) PARAMETER SYMBOL UNIT RS5AC RS5BC RS5DC RS5GC RS5JC RS5KC RS5MC Maximum RMS Voltage VRMS V 35 70 140 280 420 560 700 Maximum repetitive peak reverse voltage VRRM Maximum DC blocking Voltage V VDC Maximum Average Forward Rectified Current  @60Hz sinewave, Resistance load,TL (Fig.1) Non-repetitive Peak Forward Surge Current @ t=8.3ms Half-sine wave V 200 100 400 200 400 A Tstg ℃ -55 ~+150 RθJ-A(1) ℃ /W 47 Storage temperature A Tj Typical Thermal Resistance 50 100 IF(AV) IFSM Junction temperature 50 600 800 800 1000 1000 150 ℃ RθJ-L(1) 5.0 600 -55 ~+150 ℃ /W 13 Note : (1)Thermal resistance from junction to ambient and from junction tolead mounted on P.C.B.with 0.2"× 0.2"(5.0mm x5.0 mm) copper pad areas Electrical Characteristics (Ta=25℃ Unless otherwise specified) PARAMETER TEST CONDITIONS Maximum instantaneous IF=5.0A forward voltage Maxinum reverse recovery IF=0.5A,IR=1.0A,Irr=0.25A time Maximum DC reverse currentat rated DC blocking voltage Typical junction capacitance Revision:FRD-May.2023-A0 VRM=VRRM Ta=25℃ Ta=125℃ 4.0V DC,1MHz SYMBOL UNIT Trr ns IR μA CJ pF VF V 1 of 3 RS5AC RS5BC RS5DC 150 Zhuhai Hongjiacheng Technology co., Ltd RS5GC 1.3 2.0 RS5JC RS5KC RS5MC 250 500 200 70 www.ichjc.com � �D� 宏迦橙 RS5AC THRU RS5MC SURFACE MOUNT FAST RECOVERY RECTIFIER www.ichjc.com Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified) 210 7 6 150 5 120 4 3 2 0 20 40 60 80 100 LEADTEMPERATURE(℃) 120 140 60 0 160 Fig. 1 Forward Current Derating Curve 100 10 NUMBEROFCYCLES Fig.2 Maximum Non-Repetitive Peak Forward Surge Current ��� Tj=25℃ Pulsewidth=300us 1%DutyCycle �� 1 Tj=125℃ �.� 0.1 0.01 0.2 1 INSTANTANEOUSREVERSECURRENT(μA) 10  INSTANTANEOUSFORWARDCURRENT(A) 90 30 1 0 8.3msSingleHalfSineWave (JEDECMethod) 180 PEAKFORWARDSURGECURRENT(A) AVERAGEFORWARDOUTPUTCURRENT(A) 8 Tj=25℃ �.� 0.4 0.6 0.8 1.0 1.2 INSTANTANEOUSFORWARDVOLTAGE(V) 1.4 �.�� 1.6 Fig.3 Typical Forward Voltage Revision:FRD-May.2023-A0 ��� PERCENTOFRATEDPEAKREVERSEVOLTAGE(%) ��� Fig.4 Typical Reverse Characteristics 2 of 3 Zhuhai Hongjiacheng Technology co., Ltd www.ichjc.com � �D� 宏迦橙 RS5AC THRU RS5MC SURFACE MOUNT FAST RECOVERY RECTIFIER www.ichjc.com Ordering Information PACKAGE PACKAGE CODE UNIT WEIGHT(g) REEL(pcs) BOX(pcs) CARTON(pcs) DELIVERY MODE SMC R3 0.257 3000 6000 48000 13'' Package Outline Dimensions (SMC/DO-214AB) Symbol A C A B B C H D E D E F F G G H Suggested Pad Layout J K J Symbol M M J K Revision:FRD-May.2023-A0 3 of 3 Dimensions Millimeters Min. Max. 6.60 7.11 2.85 5.59 1.99 0.76 - 7.75 0.15 0.112 0.129 6.22 0.221 0.246 2.61 1.52 0.20 8.13 0.31 Max. 3.03 - Zhuhai Hongjiacheng Technology co., Ltd 0.261 0.281 0.078 0.103 0.030 0.060 - 0.008 0.306 0.321 0.006 Dimensions Min. - Max. 3.27 Millimeters 3.82 Min. Inches Min. - 0.151 3.84 - 0.120 0.012 Inches Max. - 0.152 www.ichjc.com
RS5MC 价格&库存
很抱歉,暂时无法提供与“RS5MC”相匹配的价格&库存,您可以联系我们找货
RS5MC
    • 1+0.36332
    • 10+0.29420
    • 30+0.25964
    • 100+0.23372
    • 500+0.21298
    • 1000+0.20261
    库存:5122
