SS510C
SS510C
    LJ(朗捷)
    DO-214AB(SMC)
SS510C 数据手册
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER VOLTAGE RANGE SS52 THRU SS520 20 to 200 Volts CURRENT 5.0 Ampere Features  The plastic package carries Underwriters Laboratory Flammability Classification 94V-0  For surface mounted applications  Metal silicon junction,majority carrier conduction  Low power loss,high efficiency  Built-in strain relief,ideal for automated placement  High forward surge current capability  High temperature soldering guaranteed: 260 C/10 seconds at terminals Mechanical Data  Case: Transfer molded plastic  Epoxy: UL 94V-0 rate flame retardant  Lead :Solder plated, solderable per MIL-STD-750 method 2026  Polarity: Color band denotes cathode end  Weight: 0.007 ounce, 0.21 gram Maximum Ratings and Electrical Characteristics  Ratings at 25℃ ambient temperature unless otherwise specified  Single phase, half wave, 60Hz, resistive or inductive load  For capacitive load derate current by 20% SYMBOLS SS 52 SS 54 SS 55 SS 56 SS 58 SS 510 SS 515 SS 520 UNIT Maximum Repetitive Peak Reverse Voltage VRRM 20 40 50 60 80 100 150 200 Volts Maximum RMS Voltage VRMS 14 28 35 42 56 70 105 140 Volts Maximum DC Blocking Voltage VDC 20 40 50 60 80 100 150 200 Volts TYPE NUMBER Maximum Average Forward Rectified Current at TLsee figure 1 TL =100℃ Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rated load (JEDEC method) Maximum Instantaneous Forward Voltage @ 5.0A Maximum DC Reverse Current at rated DC Blocking Voltage per element Typical Thermal Resistance (Note 1) I(AV) 5.0 Amps IFSM 125 Amps VF TA = 25℃ TA = 125℃ 0.70 0.85 0.1 IR 20.0 10.0 46 RθJL 12 CJ Operating Junction Temperature TJ TSTG 0.90 0.01 RθJA Diode junction capacitance (Note 2) Storage Temperature Range 0.55 300 2.0 Volts mA ℃/W 200 -55 to +150 -55 to +150 pF -65to+175 ℃ ℃ Notes: 1. Thermal resistance from Junction to ambient and from junction to lead mounted on PCB. with 0.3×0.3″(8.0 × 8.0mm)copper pad areas. 2. f=1MHz and applied 4V DC reverse voltage. Sep-03, Rev A CHANGZHOU LANGJIE ELECTRONICS CO.,LTD SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER VOLTAGE RANGE SS52 THRU SS520 20 to 200 Volts CURRENT 5.0 Ampere Ratings and Characteristic Curves (T =25℃ unless otherwise noted) 4.5 4.0 3.5 3.0 S S52-SS510 S S515-SS520 2.5 2.0 1.5 1.0 0.5 0 50 P .C.B .M O UNTED 0.20X 0.20″(5.0X 5.0m m ) COP PE R PA D AREAS 60 70 80 90 100 110 120 130 140 150 160 F1G .2-M AXIM UM N O N -R EPETITIVE PEAK FO R W ARD SUR G E C URRENT 200 T L =100℃ 8.3m s S ingle Half Sine-W ave (JE DE C M ethod) 180 160 140 AMPERES 5.0 AMPERES AVERAGE FORWARD CURRENT F1G .1-FO R W ARD C UR RENT D ER ATIN G CURVE PEAK FORWARD SURGE CURRENT, A 120 100 80 60 40 20 0 1 F1G .3-TYPIC AL INSTANTANEO US FO R W ARD C HARACTER ISTICS 100 1.0 0.1 S S52-SS54 S S55-SS56 S S58-SS515 SS520 100 T J =100℃ 10 MICROAMPERES INSTANTANEOUS REVERSE CURRENT, F1G .4-TYPIC AL R EVER SE C HARACTERISTICS 10 AMPERES INSTANTANEOUS FORWARD CURRENT, 10 N UM BER O F C YC LES AT 60 Hz LEAD TEM PER ATUR E,(℃ ) 1.0 T J =75℃ 0.1 T J =25℃ 0.01 0.001 0 0.01 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 INSTANTAN EO US FO R W ARD VO LTAG E, VO LTS 20 40 60 80 100 PER CENT O F RATED PEAK R EVERSE VO LTAG E,(% ) F1G .5-TYPIC AL JUN CTIO N CAPACITANCE JUNCTION CAPACITANCE,(pF) 200 100 T J =25℃ f=1M Hz V sig=50m Vp-p 10 S S52-SS54 S S55-SS520 1.0 1.0 10 100 R EVR ESE VO LTAG E, VO LTS Sep-03, Rev A CHANGZHOU LANGJIE ELECTRONICS CO.,LTD SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER VOLTAGE RANGE SS52 THRU SS520 Package Outline Dimensions Sep-03, Rev A CURRENT 20 to 200 Volts 5.0 Ampere in inches (millimeters) CHANGZHOU LANGJIE ELECTRONICS CO.,LTD SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER VOLTAGE RANGE SS52 THRU SS520 20 to 200 Volts CURRENT 5.0 Ampere Package Reel Information Specifications Ao Bo Ko Po W t1 SMC 6.05±0.10 8.31±0.10 2.54±0.10 4.00±0.1 16.0±0.30 0.30±0.02 DEVICE TYPE SMC Sep-03, Rev A 13"Reel Tape Width Q'TY/REEL(pcs BOX/CARTOO Q'TY/CARTON Q'TY/REEL(pcs ) N (pcs) ) 16mm 3000 8 48000 800 07"Reel REEL/BOX 3 BOX/CARTOO Q'TY/CARTON N (pcs) 8 19200 CHANGZHOU LANGJIE ELECTRONICS CO.,LTD SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER SS52 THRU SS520 VOLTAGE RANGE CURRENT 20 to 200 Volts 5.0 Ampere Marking Code Part Number Code Sep-03, Rev A CHANGZHOU LANGJIE ELECTRONICS CO.,LTD SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER VOLTAGE RANGE SS52 THRU SS520 CURRENT 20 to 200 Volts 5.0 Ampere Reflow Profile Reflow Condition Pre Heat Temperature Min. +150°C Temperature Max. +200°C Time(Min to Max) 60-180 secs. Average ramp up rate(Liquidus Temp(TL) to peak) 3°C/sec. Max. TS(max) to TL - Ramp-up Rate 3°C/sec. Max. Reflow Sep-03, Rev A Pb-Free Assembly Temperature (TL)(Liquidus) +217°C Temperature (TL) 60-150 secs. Peak Temp (TP) +(260+0/-5 )°C Time within 5°C of actual Peak Temp (TP) 25 secs. Ramp-down Rate 6°C/sec. Max. Time 25°C to peak Temp (TP) 8 min. Max. Do not exceed +260°C CHANGZHOU LANGJIE ELECTRONICS CO.,LTD SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER SS52 THRU SS520 VOLTAGE RANGE CURRENT 20 to 200 Volts 5.0 Ampere Disclaimer The information presented in this document is for reference only. Chongqing changjie Electronic Technology Co., Ltd. reserves the right to make changes without notice for the specification of the products displayed herein to improve reliability, function or design or otherwise. The product listed herein is designed to be used with ordinary electronic equipment or devices, and not designed to be used with equipment or devices which require high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, transportation equipment, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), Changjie or anyone on its behalf, assumes no responsibility or liability for any damages resulting from such improper use of sale. This publication supersedes & replaces all information previously supplied. For additional information, please visit our website http:// www.czlangjie.com , or consult your nearest Langjie’s sales office for further assistance. Sep-03, Rev A CHANGZHOU LANGJIE ELECTRONICS CO.,LTD
SS510C 价格&库存
很抱歉,暂时无法提供与“SS510C”相匹配的价格&库存,您可以联系我们找货
SS510C
    • 10+0.33748
    • 100+0.27100
    • 300+0.23776
    • 3000+0.21277
    • 6000+0.19285
    • 9000+0.18284
    库存:1668
