B520C
B560C
THRU
5.0 AMP SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS
DO-214AB(SMC)
FEATURES
* Ideal for surface mount applications
* Easy pick and place
* Built-in strain relief
* Low forward voltage drop
.245(6.22)
.220(5.59)
.124(3.15)
.108(2.75)
.280(7.11)
.260(6.60)
MECHANICAL DATA
.012(0.31)
.006(0.15)
* Case: Molded plastic
* Epoxy: UL 94V-0 rate flame retardant
* Metallurgically bonded construction
* Polarity: Color band denotes cathode end
* Mounting position: Any
* Weight: 0.21 grams
.103(2.62)
.079(2.00)
.008
MAX.
(.203)
.320(8.13)
.305(7.75)
.050(1.27)
.030(0.76)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
@Ta = +25°C, unless otherwise specified
B520C
TYPE NUMBER
Maximum Recurrent Peak Reverse Voltage
Maximum RWS Voltag
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
B530C
B540C
B550C
B560C
UNITS
30
40
50
60
V
At TL=100 C
Peak Forward Surge Current, 8.3 ms single half sine-wave
superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage at 3.05
5.0
A
150
A
0.53
0.70
0.475(typ)
Maximum DC Reverse Current
Ta=25 C
at Rated DC Blocking Voltage
Ta=100 C
Typical Junction Capacitance (Note1)
Typical Thermal Resistance, Junction to Terminal (Note 2 ) RθJT
q
to Ambient (Note 2) RθJA
Operating Temperature Range TJ
Storage Temperature Range TSTG
V
0.6(typ)
mA
0.2 (typ 0.015)
10
300
mA
pF
10
°C/W
50
-65 +150
-65 +150
°C/W
C
C
NOTES:
1. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2
2.Thermal Resistance: Junction to ambient, unit mounted on PC board with 8.0 mm
(0.033 mm thick) copper pads as heat sink.
REV 1.0 2020 JAN
PAGE:1/2
RATING AND CHARACTERISTIC CURVES (B520C THRU B560C)
FIG.2-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
PEAK FORWAARD SURGE CURRENT,(A)
6.0
5.0
4.0
3.0
2.0
1.0
60
80
100
120
140
160
180
200
150
120
90
8.3ms Single Half
Tj=25 C
Sine Wave
60
JEDEC method
30
5
50
10
100
NUMBER OF CYCLES AT 60Hz
LEAD TEMPERATURE ( C)
10
TA = 125° C
TA = 75° C
TA = 25° C
1.0
B520C thru B540C
0.1
0.1
0.2
0.4
0.6
0.3
0.5
0.7
0.8
VF, INSTANTANEOUS FORWARD VOLTAGE (V)
FIG.4-TYPICAL JUNCTION CAPACITANCE
IF, INSTANTANEOUS FORWARD CURRENT (A)
FIG3.-TYPICAL FORWARD CHARACTERISTICS
10
TA = 125° C
TA = 75° C
TA = 25° C
1.0
B550C thru B560C
0.1
0.9
0.2
0.3
0.6
0.4
0.5
0.7
0.8
FIG5. - TYPICAL REVERSE CHARACTERISTICS
10
1000
f = 1MHz
Tj=125 C
800
REVERSE LEAKAGE CURRENT, (mA)
CT , TOTAL CAPACITANCE (pF)
AVERAGE FORWARD CURRENT,(A)
FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE
600
400
200
1
Tj=75 C
0.1
.01
Tj=25 C
10
RV , DC REVERSE VOLTAGE (V)
100
.001
60
80
100 120 140
PERCENTAGE RATED PEAK REVERSE VOLTAGE (%)
REV 1.0 2020 JAN
PAGE:2/2
很抱歉,暂时无法提供与“B540C-13”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.44426
- 100+0.36218
- 300+0.32114
- 3000+0.27805
- 6000+0.25343
- 12000+0.24111
