SS10100C
SS10100C
    SLKOR(萨科微)
    DO-214AB(SMC)
SS10100C 数据手册
SS1045C THRU SS10200C 10.0 AMP SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS FEATURES VOLTAGE RANGE * Ideal for surface mount applications * Easy pick and place * Built-in strain relief * Low forward voltage drop 45 to 200 Volts CURRENT 10.0Ampere DO-214AB(SMC) MECHANICAL DATA .245(6.22) .220(5.59) .124(3.15) .108(2.75) * Case: Molded plastic * Epoxy: UL 94V-0 rate flame retardant * Metallurgically bonded construction * Polarity: Color band denotes cathode end * Mounting position: Any * Weight: 0.21 grams .280(7.11) .260(6.60) .012(0.31) .006(0.15) .103(2.62) .079(2.00) .008 MAX. (.203) .320(8.13) .305(7.75) .050(1.27) .030(0.76) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER SS1045C 45 32 45 Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current SS1060C 60 42 60 See Fig. 1 Peak Forward Surge Current, 8.3 ms single half sine-wave SS10100C SS10150C SS10200C UNITS 200 100 150 V 70 105 140 V 100 150 200 V A 10.0 175 superimposed on rated load (JEDEC method) Maximum Instantaneous Forward Voltage at 10.0A Maximum DC Reverse Current Ta=25 C 0.55 0.7 0.02 0.70 0.85 2 0.1 0.70 0.85 5 at Rated DC Blocking Voltage Ta=125 C Typical Junction Capacitance (Note1) Typical Thermal Resistance R JA (Note 2) Operating Temperature Range TJ Storage Temperature Range TSTG 0.92 0.85 440 250 60 to10+150 -55 -55 to +150 A V A mA pF C/W C C NOTES: 1. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2. Thermal Resistance Junction to Lead. www.slkormicro.com 1 Rev.1 -- 13 May 2016 SS1045C THRU SS10200C RATING AND CHARACTERISTIC CURVES (SS1045C THRU SS10200C) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL FORWARD 50 4 2 0 0 20 40 60 80 100 120 140 160 180 200 CASE TEMPERATURE,( C) FIG.3-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT 10 5.0 SS 101 50SS 102 00 6 SS 106 0 SS 101 00 8 SS 10 45 10 INSTANTANEOUS FORWARD CURRENT,(A) AVERAGE FORWARD CURRENT,(A) CHARACTERISTICS 12 1.0 Tj=25 C Pulse Width 300us 1% Duty Cycle 0.1 PEAK FORWARD SURGE CURRENT,(A) 250 .01 200 .1 .3 .5 .7 .9 1.1 1.3 1.5 FORWARD VOLTAGE,(V) 150 8.3ms Single Half Tj=25 C Sine Wave 100 JEDEC method 50 FIG.5 - TYPICAL REVERSE CHARACTERISTICS 0 1 5 50 10 100 100 NUMBER OF CYCLES AT 60Hz FIG.4-TYPICAL JUNCTION CAPACITANCE REVERSE LEAKAGE CURRENT, (mA) JUNCTION CAPACITANCE,(pF) 2800 2400 2000 1600 1200 800 400 0 10 Tj=100 C 1.0 Tj=75 C .1 Tj=25 C .01 .05 .1 .5 1 5 10 50 100 REVERSE VOLTAGE,(V) .01 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) www.slkormicro.com 2 Rev.1 -- 13 May 2016
SS10100C 价格&库存
很抱歉,暂时无法提供与“SS10100C”相匹配的价格&库存,您可以联系我们找货
SS10100C
    • 5+0.63656
    • 50+0.51560
    • 150+0.45512
    • 500+0.40976
    库存:2858
