SS515C THRU SS520C
5.0 AMP SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS
VOLTAGE RANGE
150 to 200 Volts
CURRENT
5.0 Amperes
FEATURES
DO-214AB(SMC)
* Ideal for surface mount applications
* Easy pick and place
* Built-in strain relief
* Low forward voltage drop
.245(6.22)
.220(5.59)
.124(3.15)
.108(2.75)
.280(7.11)
.260(6.60)
MECHANICAL DATA
.012(0.31)
.006(0.15)
* Case: Molded plastic
* Epoxy: UL 94V-0 rate flame retardant
* Metallurgically bonded construction
* Polarity: Color band denotes cathode end
* Mounting position: Any
* Weight: 0.21 grams
.103(2.62)
.079(2.00)
.008
MAX.
(.203)
.320(8.13)
.305(7.75)
.050(1.27)
.030(0.76)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
SS515C
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
SS520C
150
105
150
200
140
200
UNITS
V
V
V
at TL=100 C
Peak Forward Surge Current, 8.3 ms single half sine-wave
5.0
A
superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage at 5.0A
Maximum DC Reverse Current
Ta=25 C
175
A
V
mA
at Rated DC Blocking Voltage
Typical Junction Capacitance (Note1)
Typical Thermal Resistance R JL(Note 2)
Operating Temperature Range TJ
Storage Temperature Range TSTG
2
380
0.92
0.02
Ta=100 C
-65
-65
12
+175
+175
mA
PF
C/W
C
C
NOTES:
1. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2. Thermal Resistance Junction to Lead Vertical PC Board Mounting 0.375"(9.5mm) Lead Length.
www.slkormicro.com
1
Rev.1 -- 19 July 2017
SS515C THRU SS520C
RATING AND CHARACTERISTIC CURVES (SS515C THRU SS520C)
FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE
FIG.2-TYPICAL FORWARD
50
5.0
4.0
3.0
2.0
1.0
60
80
100
120
140
160
180
200
LEAD TEMPERATURE,( C)
FIG.3-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
INSTANTANEOUS FORWARD CURRENT,(A)
AVERAGE FORWARD CURRENT,(A)
CHARACTERISTICS
6.0
10
3.0
1.0
Tj=25 C
Pulse Width 300us
1% Duty Cycle
0.1
PEAK FORWARD SURGE CURRENT,(A)
150
.01
120
.1
.3
.5
.7
.9
1.1
1.3
1.5
FORWARD VOLTAGE,(V)
90
8.3ms Single Half
Tj=25 C
Sine Wave
60
JEDEC method
30
FIG.5 - TYPICAL REVERSE
CHARACTERISTICS
5
50
10
100
100
NUMBER OF CYCLES AT 60Hz
REVERSE LEAKAGE CURRENT, (mA)
FIG.4-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE,(pF)
1400
1200
1000
800
600
400
10
Tj=100 C
1.0
.1
Tj=25 C
200
.05
.1
.5
1
5
10
50
100
60
80
100 120 140
PERCENTAGE RATED PEAK REVERSE VOLTAGE,(%)
REVERSE VOLTAGE,(V)
www.slkormicro.com
.01
很抱歉,暂时无法提供与“SS520C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.39334
- 100+0.31860
- 300+0.28124
