US3MC
US3MC
    HONGJIACHENG(宏嘉诚)
    DO-214AB(SMC)
US3MC 数据手册
� �D� 宏迦橙 US3AC THRU US3MC SURFACE MOUNT HIGH EFFICIENT RECTIFIER www.ichjc.com Features DO-214AB(SMC) •Low profile package •Ideal for automated placement •Glass passivated pallet chip junction •Super fast reverse recovery time •Low switching losses, high efficiency •High forward surge capability Applications For use in high frequency rectification and freewheeling application in switching mode converters and inverters for consumer, computer, automotive, and telecommunication Mechanical Data •Case: DO-214AB(SMC) Molding compound meets UL 94V-0 flammability rating, RoHS-compliant, halogen-free •Terminals: Solder plated, solderable per MIL-STD-750,Method 2026 •Polarity: Cathode line denotes the cathode end Maximum Ratings (Ta=25℃ Unless otherwise specified) PARAMETER SYMBOL UNIT US3AC US3BC US3DC US3GC US3JC US3KC US3MC Maximum repetitive peak reverse voltage VRRM V 50 100 200 400 600 800 1000 Maximum DC blocking Voltage VDC V 50 100 200 400 600 800 1000 Maximum RMS Voltage VRMS Maximum Average Forward Rectified Current  @60Hz sinewave, Resistance load,TL (Fig.1) Non-repetitive Peak Forward Surge Current @ t=8.3ms Half-sine wave V Junction temperature 140 ℃ -55 ~+150 RθJ-A ℃ /W 47 RθJ-L Maxinum reverse recovery time IF=0.5A,IR=1.0A,Irr=0.25A Typical junction capacitance Revision:HED-May.2023-A0 IF=3.0A VRM=VRRM Ta=25℃ Ta=125℃ 4.0V DC,1MHz 700 -55 ~+150 ℃ /W TEST CONDITIONS 3.0 560 100 ℃ PARAMETER Maximum DC reverse currentat rated DC blocking voltage 420 Tstg A 15 Electrical Characteristics (Ta=25℃ Unless otherwise specified) Maximum instantaneous forward voltage 280 A Tj Typical Thermal Resistance 70 IF(AV) IFSM Storage temperature 35 SYMBOL UNIT US3AC US3BC US3DC US3GC US3JC US3KC US3MC VF V Trr ns IR uA CJ pF 1 of 3 Zhuhai Hongjiacheng Technology co., Ltd 1.0 50 1.4 2.0 1.7 75 200 65 www.ichjc.com � �D� 宏迦橙 US3AC THRU US3MC SURFACE MOUNT HIGH EFFICIENT RECTIFIER www.ichjc.com Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified) 140 4.0 3.5 PEAKFORWARDSURGECURRENT(A) AVERAGEFORWARDOUTPUTCURRENT(A) 120 3.0 100 2.5 80 2.0 60 1.5 40 1.0 20 0.5 0.0 0 20 40 60 80 100 LEADTEMPERATURE(℃) 120 140 0 160 Fig. 1 Forward Current Derating Curve 10 1 Fig.2 Maximum Non-Repetitive Peak Forward Surge Current ��� Tj=25℃ Pulsewidth=300us 1%DutyCycle �� 1 Tj=125℃ �.� 0.1 0.01 0.2 100 10 NUMBEROFCYCLES INSTANTANEOUSREVERSECURRENT(μA) 20  INSTANTANEOUSFORWARDCURRENT(A) 8.3msSingleHalfSineWave (JEDECMethod) Tj=25℃ �.� 0.6 1.0 1.4 US3AC-US3DC US3GC US3JC-US3MC INSTANTANEOUSFORWARDVOLTAGE(V) 1.8 �.�� 2.0 Fig.3 Typical Forward Voltage Revision:HED-May.2023-A0 ��� PERCENTOFRATEDPEAKREVERSEVOLTAGE(%) ��� Fig.4 Typical Reverse Characteristics 2 of 3 Zhuhai Hongjiacheng Technology co., Ltd www.ichjc.com � �D� 宏迦橙 US3AC THRU US3MC SURFACE MOUNT HIGH EFFICIENT RECTIFIER www.ichjc.com Ordering Information PACKAGE PACKAGE CODE UNIT WEIGHT(g) REEL(pcs) BOX(pcs) CARTON(pcs) DELIVERY MODE SMC R3 0.257 3000 / 48000 13'' Package Outline Dimensions (SMC/DO-214AB) Symbol A C A B B C H D E D E G F F G H Suggested Pad Layout J K J Symbol M M J K Revision:HED-May.2023-A0 3 of 3 Dimensions Millimeters Min. Max. 6.60 7.11 2.85 5.59 1.99 0.76 - 7.75 0.15 0.112 0.129 6.22 0.221 0.246 2.61 1.52 0.20 8.13 0.31 Max. 3.03 - Zhuhai Hongjiacheng Technology co., Ltd 0.261 0.281 0.078 0.103 0.030 0.060 - 0.008 0.306 0.321 0.006 Dimensions Min. - Max. 3.27 Millimeters 3.82 Min. Inches Min. - 0.151 3.84 - 0.120 0.012 Inches Max. - 0.152 www.ichjc.com
US3MC 价格&库存
很抱歉,暂时无法提供与“US3MC”相匹配的价格&库存,您可以联系我们找货
US3MC
    • 1+0.28869
    • 10+0.23037
    • 30+0.20121
    • 300+0.17939
    • 600+0.16190
    • 900+0.15315
    库存:2492
