SS36C
SS36C
    HONGJIACHENG(宏嘉诚)
    DO-214AB(SMC)
SS36C 数据手册
� �D� 宏迦橙 SS32C THRU SS320C SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER www.ichjc.com Features DO-214AB(SMC) •Low profile package •Ideal for automated placement •Guardring for overvoltage protection •Low power losses, high efficiency •Meets MSL level 1, per J-STD-020, LF maximum peak of 260℃ Applications For use in low voltage high frequency inverters, free wheeling,DC/DC converters, and polarity protection applications. Mechanical Data •Case: DO-214AB(SMC) Molding compound meets UL 94V-0 flammability rating, RoHS-compliant, halogen-free •Terminals: Solder plated, solderable per MIL-STD-750,Method 2026 •Polarity: Cathode line denotes the cathode end Maximum Ratings (Ta=25℃ Unless otherwise specified) PARAMETER SYMBOL UNIT SS32C SS33C SS34C SS35C SS36C SS38C SS310C SS315C SS320C Device marking code Maximum Repetitive Peak Reverse Voltage VRRM V Maximum DC blocking Voltage VDC V Maximum RMS Voltage Maximum Average Forward Rectified Current  @60Hz sinewave, Resistance load,TL (Fig.1) Non-repetitive Peak Forward Surge Current @ t=8.3ms Half-sine wave Storage temperature Junction temperature VRMS 20 30 40 50 60 80 100 150 200 20 30 40 50 60 80 100 150 200 14 21 28 35 A Tstg ℃ -55 ~ +150 RθJ-A ℃ /W 47 IFSM RθJ-L A Maximum instantaneous forward voltage Maximum DC reverse currentat rated DC blocking voltage 3.0 56 70 105 140 80 ℃ -55 ~ +150 ℃ /W 17 Electrical Characteristics (Ta=25℃ Unless otherwise specified) PARAMETER 42 IF(AV) Tj Typical Thermal Resistance V SS32C SS33C SS34C SS35C SS36C SS38C SS310C SS315C SS320C TEST CONDITIONS SYMBOL UNIT SS32C SS33C SS34C SS35C SS36C SS38C SS310C SS315C SS320C IF=3.0A VRM=VDC Typical junction capacitance Revision:SBD-May.2023-A0 Ta=25℃ Ta=100℃ 4.0V DC,1MHz VF V IR mA CJ pF 0.55 0.5 50 450 1 of 3 Zhuhai Hongjiacheng Technology co., Ltd 0.70 0.85 0.05 0.95 10 350 www.ichjc.com � �D� 宏迦橙 SS32C THRU SS320C SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER www.ichjc.com Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified) 140 120 4 100 3 80 60 2 40 1 0 20 0 40 80 LEADTEMPERATURE(℃) 120 0 160 Fig. 1 Forward Current Derating Curve 100 100 Tj=25℃ Pulsewidth=300us 1%DutyCycle 10 100 NUMBEROFCYCLES SS32C-SS36C SS38C-SS320C 10 INSTANTANEOUSREVERSECURRENT(mA)  INSTANTANEOUSFORWARDCURRENT(A) 1 Fig.2 Maximum Non-Repetitive Peak Forward Surge Current 10 1.0 Tj=100℃ 1 0.1 0.1 0.01 8.3msSingleHalfSineWave (JEDECMethod) PEAKFORWARDSURGECURRENT(A) AVERAGERECTIFIELDOUTPUTCURRENT(A) 5 0 0.2 0.4 0.6 0.8 1.0 SS32C-SS34C SS35C-SS36C SS38C-SS310C SS315C-SS320C 1.2 INSTANTANEOUSFORWARDVOLTAGE(V) 1.4 0.001 1.6 Fig.3 Typical Forward Voltage Revision:SBD-May.2023-A0 Tj=25℃ 0.01 0 20 40 60 80 PERCENTOFRATEDPEAKREVERSEVOLTAGE(%) 100 Fig.4 Typical Reverse Characteristics 2 of 3 Zhuhai Hongjiacheng Technology co., Ltd www.ichjc.com � �D� 宏迦橙 SS32C THRU SS320C SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER www.ichjc.com Ordering Information PACKAGE PACKAGE CODE UNIT WEIGHT(g) REEL(pcs) BOX(pcs) CARTON(pcs) DELIVERY MODE SMC R3 0.257 3000 / 48000 13'' Package Outline Dimensions (SMC/DO-214AB) A C Symbol A B B C H D E D E F G F G H Suggested Pad Layout J K J Symbol M M J K Revision:SBD-May.2023-A0 3 of 3 Dimensions Millimeters Min. Max. 6.60 7.11 2.85 5.59 1.99 0.76 - 7.75 0.15 0.112 0.129 6.22 0.221 0.246 2.61 1.52 0.20 8.13 0.31 Max. 3.03 - Zhuhai Hongjiacheng Technology co., Ltd 0.261 0.281 0.078 0.103 0.030 0.060 - 0.008 0.306 0.321 0.006 Dimensions Min. - Max. 3.27 Millimeters 3.82 Min. Inches Min. - 0.151 3.84 - 0.120 0.012 Inches Max. - 0.152 www.ichjc.com
SS36C 价格&库存
很抱歉,暂时无法提供与“SS36C”相匹配的价格&库存,您可以联系我们找货
SS36C
    • 1+0.34050
    • 10+0.27581
    • 30+0.24347
    • 100+0.21917
    • 500+0.19978
    • 1000+0.19004
    库存:2727
