� �D�
宏迦橙
SK102C THRU SK1010C
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
www.ichjc.com
Features
DO-214AB(SMC)
•Low profile package
•Ideal for automated placement
•Guardring for overvoltage protection
•High forward surge current capability
•Meets MSL level 1, per J-STD-020, LF maximum peak of 260℃
Applications
For use in low voltage high frequency inverters, freewheeling,DC/DC converters,
and car lighting.
Mechanical Data
•Case: DO-214AB(SMC)
Molding compound meets UL 94V-0 flammability rating, RoHS-compliant,
halogen-free
•Terminals: Solder plated, solderable per MIL-STD-750,Method 2026
•Polarity: Cathode line denotes the cathode end
Maximum Ratings (Ta=25℃ Unless otherwise specified)
PARAMETER
SYMBOL UNIT SK102C SK104C SK1045C SK106C SK108C SK1010C SK1015C SK1020C
Device marking code
Maximum Repetitive Peak Reverse Voltage
VRRM
V
Maximum DC blocking Voltage
VDC
V
Maximum RMS Voltage
Maximum Average Forward Rectified Current
@60Hz sinewave, Resistance load,TL (Fig.1)
Non-repetitive Peak Forward Surge Current
@ t=8.3ms Half-sine wave
Storage temperature
Junction temperature
VRMS
14
28
45
60
80
100
150
200
45
60
80
100
150
200
31.5
42
A
Tstg
-55 ~ +150
RθJ-A
℃ /W
47
IFSM
RθJ-L
A
Maximum instantaneous
forward voltage
Maximum DC reverse
currentat rated DC
blocking voltage
10
70
105
140
175
-55 ~ +150
℃ /W
14
Electrical Characteristics (Ta=25℃ Unless otherwise specified)
PARAMETER
56
IF(AV)
Tj
Typical Thermal Resistance
V
TEST CONDITIONS SYMBOL UNIT SK102C SK104C SK1045C SK106C SK108C SK1010C SK1015C SK1020C
IF=10A
VRM=VDC
Typical junction
capacitance
Revision:SBD-May.2023-A0
Ta=25℃
Ta=125℃
4.0V DC,1MHz
VF
V
IR
mA
CJ
pF
0.55
0.5
50
1 of 3
Zhuhai Hongjiacheng Technology co., Ltd
0.70
0.85
500
0.05
0.95
10
www.ichjc.com
� �D�
宏迦橙
SK102C THRU SK1010C
www.ichjc.com
Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified)
210
16
12
150
10
120
8
6
4
60
80
100
LEADTEMPERATURE(℃)
120
140
60
Fig. 1 Forward Current Derating Curve
1000
100
Tj=25℃
Pulsewidth=300us
1%DutyCycle
10
100
NUMBEROFCYCLES
SK102C-SK106C
SK108C-SK1020C
10
INSTANTANEOUSREVERSECURRENT(mA)
INSTANTANEOUSFORWARDCURRENT(A)
1
Fig.2 Maximum Non-Repetitive Peak Forward Surge Current
100
10
Tj=100℃
1
0.1
1.0
0.1
90
30
2
8.3msSingleHalfSineWave
(JEDECMethod)
180
PEAKFORWARDSURGECURRENT(A)
AVERAGERECTIFIELDOUTPUTCURRENT(A)
14
0.4
0.6
0.8
1.0
SK102C-SK104C
SK106C
SK108C-SK1010C
SK1015C-SK1020C
1.2
INSTANTANEOUSFORWARDVOLTAGE(V)
1.4
0.001
1.6
Fig.3 Typical Forward Voltage
Tj=25℃
0.01
60
80
PERCENTOFRATEDPEAKREVERSEVOLTAGE(%)
100
Fig.4 Typical Reverse Characteristics
2 of 3
www.ichjc.com
� �D�
宏迦橙
SK102C THRU SK1010C
www.ichjc.com
Ordering Information
PACKAGE
PACKAGE CODE
UNIT WEIGHT(g)
REEL(pcs)
BOX(pcs)
CARTON(pcs)
DELIVERY MODE
SMC
R3
0.257
3000
48000
13''
Package Outline Dimensions (SMC/DO-214AB)
Symbol
A C
A
B
B
C
H
D
E
D
E
F
F
G
G
H
Suggested Pad Layout
J
K
J
Symbol
M
M
J
K
3 of 3
Dimensions
Millimeters
Min.
Max.
6.60
7.11
2.85
5.59
1.99
0.76
7.75
0.15
0.112
0.129
6.22
0.221
0.246
2.61
1.52
0.20
8.13
0.31
Max.
3.03
0.261
0.281
0.078
0.103
0.030
0.060
0.008
0.306
0.321
0.006
Dimensions
Min.
Max.
3.27
Millimeters
3.82
Min.
Inches
Min.
0.151
3.84
0.120
0.012
Inches
Max.
0.152
www.ichjc.com
很抱歉,暂时无法提供与“SK1010C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.09739
- 50+0.88150
- 150+0.78894
- 500+0.67349
- 3000+0.60664
- 6000+0.57586
