SS56C
SS56C
    HONGJIACHENG(宏嘉诚)
    DO-214AB(SMC)
SS56C 数据手册
� �D� 宏迦橙 SS52C THRU SS520C SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER www.ichjc.com Features DO-214AB(SMC) •For surface mounted applications • High forward surge current capability •Guardring for overvoltage protection •Low power losses, high efficiency •Meets MSL level 1, per J-STD-020, LF maximum peak of 260℃ Applications For use in low voltage high frequency inverters, free wheeling,DC/DC converters, and polarity protection applications. Mechanical Data •Case: DO-214AB(SMC) Molding compound meets UL 94V-0 flammability rating, RoHS-compliant, halogen-free •Terminals: Solder plated, solderable per MIL-STD-750,Method 2026 •Polarity: Cathode line denotes the cathode end Maximum Ratings (Ta=25℃ Unless otherwise specified) PARAMETER SYMBOL UNIT SS52C SS53C SS54C SS55C SS56C SS58C SS510C SS515C SS520C Device marking code Maximum Repetitive Peak Reverse Voltage VRRM V Maximum DC blocking Voltage VDC V Maximum RMS Voltage VRMS Maximum Average Forward Rectified Current  @60Hz sinewave, Resistance load,TL (Fig.1) Forward Surge Current (Nonrepetitive) @60HzHalf-sine wave,1 cycle, T=25℃ Storage temperature Junction temperature IF(AV) IFSM Tstg Tj Typical Thermal Resistance V RθJ-A RθJ-L A SS52C SS53C SS54C SS55C SS56C SS58C SS510C SS515C SS520C 20 30 40 50 60 80 100 150 200 20 30 40 50 60 80 100 150 200 14 21 28 35 A 42 5.0 TEST CONDITIONS Maximum instantaneous forward voltage Maximum DC reverse currentat rated DC blocking voltage IF=5.0A VRM=VDC Typical junction capacitance Revision:SBD-May.2023-A0 Ta=25℃ Ta=125℃ 4.0V DC,1MHz 70 105 140 120 ℃ -55 ~ +150 ℃ /W 45 ℃ -55 ~ +150 ℃ /W 15 Electrical Characteristics (Ta=25℃ Unless otherwise specified) PARAMETER 56 SYMBOL UNIT SS52C SS53C SS54C SS55C SS56C SS58C SS510C SS515C SS520C VF V IR mA CJ pF 0.55 550 1 of 3 0.15 50 Zhuhai Hongjiacheng Technology co., Ltd 0.68 0.85 450 0.05 0.95 10 www.ichjc.com � �D� 宏迦橙 SS52C THRU SS520C SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER www.ichjc.com Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified) AVERAGERECTIFIELDOUTPUTCURRENT(A) 5 160 8.3msSingleHalfSineWave (JEDECMethod) 140 PEAKFORWARDSURGECURRENT(A) 4 120 100 3 80 2 60 40 1 0 20 40 0 80 LEADTEMPERATURE(℃) 120 0 160 Fig. 1 Forward Current Derating Curve 100 100 Tj=25℃ Pulsewidth=300us 1%DutyCycle 100 SS52C-SS56C SS58C-SS520C 10 INSTANTANEOUSREVERSECURRENT(mA)  INSTANTANEOUSFORWARDCURRENT(A) 10 NUMBEROFCYCLES Fig.2 Maximum Non-Repetitive Peak Forward Surge Current 10 1.0 Tj=100℃ 1 0.1 0.1 0.01 1 0 0.2 0.4 0.6 0.8 1.0 SS52C-SS54C SS55C-SS56C SS58C-SS510C SS515C-SS520C 1.2 INSTANTANEOUSFORWARDVOLTAGE(V) 1.4 0.001 1.6 Fig.3 Typical Forward Voltage Revision:SBD-May.2023-A0 Tj=25℃ 0.01 0 20 40 60 80 PERCENTOFRATEDPEAKREVERSEVOLTAGE(%) 100 Fig.4 Typical Reverse Characteristics 2 of 3 Zhuhai Hongjiacheng Technology co., Ltd www.ichjc.com � �D� 宏迦橙 SS52C THRU SS520C SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER www.ichjc.com Ordering Information PACKAGE PACKAGE CODE UNIT WEIGHT(g) REEL(pcs) BOX(pcs) CARTON(pcs) DELIVERY MODE SMC R3 0.257 3000 6000 48000 13'' Package Outline Dimensions (SMC/DO-214AB) Symbol A C A B B C H D E D E G F F G H Suggested Pad Layout J K J Symbol M M J K Revision:SBD-May.2023-A0 3 of 3 Dimensions Millimeters Min. Max. 6.60 7.11 2.85 5.59 1.99 0.76 - 7.75 0.15 0.112 0.129 6.22 0.221 0.246 2.61 1.52 0.20 8.13 0.31 Max. 3.03 - Zhuhai Hongjiacheng Technology co., Ltd 0.261 0.281 0.078 0.103 0.030 0.060 - 0.008 0.306 0.321 0.006 Dimensions Min. - Max. 3.27 Millimeters 3.82 Min. Inches Min. - 0.151 3.84 - 0.120 0.012 Inches Max. - 0.152 www.ichjc.com
SS56C 价格&库存
很抱歉,暂时无法提供与“SS56C”相匹配的价格&库存,您可以联系我们找货
SS56C
    • 1+0.32897
    • 10+0.28815
    • 30+0.26774
    • 100+0.25240
    • 500+0.24020
    • 1000+0.23404
    库存:8082
