� �D�
宏迦橙
SS52C THRU SS520C
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
www.ichjc.com
Features
DO-214AB(SMC)
•For surface mounted applications
• High forward surge current capability
•Guardring for overvoltage protection
•Low power losses, high efficiency
•Meets MSL level 1, per J-STD-020, LF maximum peak of 260℃
Applications
For use in low voltage high frequency inverters, free wheeling,DC/DC converters,
and polarity protection applications.
Mechanical Data
•Case: DO-214AB(SMC)
Molding compound meets UL 94V-0 flammability rating, RoHS-compliant,
halogen-free
•Terminals: Solder plated, solderable per MIL-STD-750,Method 2026
•Polarity: Cathode line denotes the cathode end
Maximum Ratings (Ta=25℃ Unless otherwise specified)
PARAMETER
SYMBOL UNIT SS52C SS53C SS54C SS55C SS56C SS58C SS510C SS515C SS520C
Device marking code
Maximum Repetitive Peak Reverse Voltage
VRRM
V
Maximum DC blocking Voltage
VDC
V
Maximum RMS Voltage
VRMS
Maximum Average Forward Rectified Current
@60Hz sinewave, Resistance load,TL (Fig.1)
Forward Surge Current (Nonrepetitive)
@60HzHalf-sine wave,1 cycle, T=25℃
Storage temperature
Junction temperature
IF(AV)
IFSM
Tstg
Tj
Typical Thermal Resistance
V
RθJ-A
RθJ-L
A
40
50
60
80
100
150
200
40
50
60
80
100
150
200
14
21
28
35
A
42
5.0
TEST
CONDITIONS
Maximum instantaneous
forward voltage
Maximum DC reverse
currentat rated DC
blocking voltage
IF=5.0A
VRM=VDC
Typical junction
capacitance
Revision:SBD-May.2023-A0
Ta=25℃
Ta=125℃
4.0V DC,1MHz
70
105
140
120
-55 ~ +150
℃ /W
45
-55 ~ +150
℃ /W
15
Electrical Characteristics (Ta=25℃ Unless otherwise specified)
PARAMETER
56
VF
V
IR
mA
CJ
pF
0.55
550
1 of 3
0.15
50
Zhuhai Hongjiacheng Technology co., Ltd
0.68
0.85
450
0.05
0.95
10
www.ichjc.com
� �D�
宏迦橙
SS52C THRU SS520C
www.ichjc.com
Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified)
AVERAGERECTIFIELDOUTPUTCURRENT(A)
5
160
8.3msSingleHalfSineWave
(JEDECMethod)
140
PEAKFORWARDSURGECURRENT(A)
4
120
100
3
80
2
60
40
1
LEADTEMPERATURE(℃)
120
Fig. 1 Forward Current Derating Curve
100
100
Tj=25℃
Pulsewidth=300us
1%DutyCycle
100
SS52C-SS56C
SS58C-SS520C
10
INSTANTANEOUSREVERSECURRENT(mA)
INSTANTANEOUSFORWARDCURRENT(A)
10
NUMBEROFCYCLES
Fig.2 Maximum Non-Repetitive Peak Forward Surge Current
10
1.0
Tj=100℃
1
0.1
0.1
0.01
1
0.4
0.6
0.8
1.0
SS52C-SS54C
SS55C-SS56C
SS58C-SS510C
SS515C-SS520C
1.2
INSTANTANEOUSFORWARDVOLTAGE(V)
1.4
0.001
1.6
Fig.3 Typical Forward Voltage
Tj=25℃
0.01
60
80
PERCENTOFRATEDPEAKREVERSEVOLTAGE(%)
100
Fig.4 Typical Reverse Characteristics
2 of 3
www.ichjc.com
� �D�
宏迦橙
SS52C THRU SS520C
www.ichjc.com
Ordering Information
PACKAGE
PACKAGE CODE
UNIT WEIGHT(g)
REEL(pcs)
BOX(pcs)
CARTON(pcs)
DELIVERY MODE
SMC
R3
0.257
3000
6000
48000
13''
Package Outline Dimensions (SMC/DO-214AB)
Symbol
A C
A
B
B
C
H
D
E
D
E
G
F
F
G
H
Suggested Pad Layout
J
K
J
Symbol
M
M
J
K
3 of 3
Dimensions
Millimeters
Min.
Max.
6.60
7.11
2.85
5.59
1.99
0.76
7.75
0.15
0.112
0.129
6.22
0.221
0.246
2.61
1.52
0.20
8.13
0.31
Max.
3.03
0.261
0.281
0.078
0.103
0.030
0.060
0.008
0.306
0.321
0.006
Dimensions
Min.
Max.
3.27
Millimeters
3.82
Min.
Inches
Min.
0.151
3.84
0.120
0.012
Inches
Max.
0.152
www.ichjc.com
很抱歉,暂时无法提供与“SS510C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.34258
- 50+0.29765
- 150+0.27519
- 500+0.25834
- 3000+0.24495
- 6000+0.23814
