S8M
S8M
    JUXING(钜兴)
    DO-214AB(SMC)
    普通整流二极管
S8M 数据手册
S8K THRU S8M Surface Mount Standard Rectifiers PINNING PIN FEATURES • For surface mounted applications • Low profile package • Glass Passivated Chip Junction • Easy to pick and place • Lead free in comply with EU RoHS 2011/65/EU directives DESCRIPTION 1 Cathode 2 Anode 2 MECHANICAL DATA • Case: SMC • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 0.22g / 0.0077oz 1 Top View Marking Code: S8K~S8M Simplified outline SMC and symbol Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols S8K S8M Units Maximum Repetitive Peak Reverse Voltage V RRM 800 1000 V Maximum RMS voltage V RMS 560 700 V Maximum DC Blocking Voltage V DC 800 1000 V Maximum Average Forward Rectified Current I F(AV) 8 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load I FSM 200 A Maximum Instantaneous Forward Voltage at 8 A VF 0.985 V IR 10 250 μA Cj 40 pF RθJA RθJC 35 13 °C/W T j , T stg -55 ~ +150 °C Parameter Maximum DC Reverse Current T a = 25 °C at Rated DC Blocking Voltage T a =125 °C Typical Junction Capacitance (1) Typical Thermal Resistance (2) Operating and Storage Temperature Range (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. version: 02 http://www.trr-jx.com S8K THRU S8M Surface Mount Standard Rectifiers Fig.2 Typical Reverse Characteristics 9.6 8.0 6.4 4.8 3.2 1.6 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 175 Instaneous Reverse Current(μ A) Average Forward Current (A) Fig.1 Forward Current Derating Curve 100 T J =125°C 10 1.0 T J =25°C 0.1 00 Case Temperature (°C) Junction Capacitance ( pF) Instaneous Forward Current (A) 10 1.0 60 80 100 120 140 T J =25°C 100 10 T J =25°C 0.1 0.4 1 0.6 0.8 1.0 1.2 1.4 1.6 1.8 Fig.6 Maximum Non-Repetitive Peak Forward Surage Current 300 250 200 150 100 50 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 Number of Cycles http://www.trr-jx.com 0.1 1.0 10 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surage Current (A) 40 Fig.4 Typical Junction Capacitance Fig.3 Typical Forward Characteristic version: 02 20 percent of Rated Peak Reverse Voltage (%) 100 100 S8K THRU S8M Surface Mount Standard Rectifiers SMC Plastic surface mounted package; 2 leads E A A1 A C b D L E1 VM A SMC mechanical data A E D E1 A1 C L b max 2.62 7.0 6.2 8.0 0.21 0.31 1.6 3.25 min 2.00 6.5 5.6 7.6 0.05 0.15 0.9 2.75 max 103 276 244 315 8.3 12 63 128 min 79 256 220 299 2.0 5.9 35 108 UNIT mm mil The recommended mounting pad size 3.8 (150) 4.1 (160) 4.3 (170) 4.1 (160) mm Unit : (mil) version: 02 http://www.trr-jx.com
很抱歉,暂时无法提供与“S8M”相匹配的价格&库存,您可以联系我们找货
S8M
    • 5+0.34515
    • 50+0.33694
    • 150+0.33151
    • 500+0.32607
    库存:51
