ES3K
ES3K
    JUXING(钜兴)
    DO-214AB(SMC)
ES3K 数据手册
ES3K Surface Mount Superfast Rectifiers Features ● ● ● ● ● ● ● Glass passivated chip junctions Ideal for automated placement Ultrafast reverse recovery time for high efficiency Low profile package High forward surge capability High temperature soldering: 260℃/10 seconds at terminals Component in accordance to RoHS 2002/95/1 and WEEE 2002/96/EC Mechanical Date ● ● ● Case: JEDEC DO-214AB molded plastic body over passivated chip Terminals: Solder plated, solderable per J-STD-002B and JESD22-B102D Polarity: Laser band denotes cathode end Maximum Ratings and Electrical Characteristics o Rating at 25 C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20% Symbols ES3K Units Maximum Repetitive Peak Reverse Voltage V RRM 800 V Maximum RMS voltage V RMS 560 V Maximum DC Blocking Voltage V DC 800 V Maximum Average Forward Rectified Current at T c = 125 °C I F(AV) 3 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load I FSM 90 A Maximum Forward Voltage at 3 A VF 1.7 V IR 5 100 μA Cj 40 pF t rr 35 ns RθJA RθJC 40 16 °C/W T j , T stg -55 ~ +150 °C Parameter Maximum DC Reverse Current T a = 25 °C at Rated DC Blocking Voltage T a =125 °C Typical Junction Capacitance at V R =4V, f=1MHz Maximum Reverse Recovery Time (1) Typical Thermal Resistance (2) Operating and Storage Temperature Range (1)Measured with I F = 0.5 A , I R = 1 A , I rr = 0.25 A . (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. version: 02 http://www.trr-jx.com ES3K Surface Mount Superfast Rectifiers Characteristic Curves (TA=25 ℃ unless otherwise noted) Fig.1 Reverse Recovery Time Characteristic And Test Circuit Diagram 50 ohm Noninductive t rr 10 ohm Noninductive +0.5 D.U.T + PULSE GENERATOR Note 2 25Vdc approx 0 - -0.25 1 ohm NonInductive OSCILLOSCOPE Note 1 -1.0 Note:1.Rise Time = 7ns, max. Input Impedance = 1megohm,22pF. 2. Ries Time =10ns, max. Source Impedance = 50 ohms. 10ns/div Set time Base for 10ns/div Fig.3 Typical Reverse Characteristics 3.5 300 3.0 100 I R - Reverse Current ( μ A) Average Forward Current (A) Fig.2 Maximum Average Forward Current Rating 2.5 2.0 1.5 1.0 0.5 Single phase half-wave 60 Hz resistive or inductive load T J =125°C 10 T J =75°C 1.0 T J =25°C 0.1 0.0 25 50 75 100 125 150 0 175 20 40 Case Temperature (°C) Junction Capacitance ( pF) Instaneous Forward Current (A) T J =25°C 1.0 0.1 0.01 0.001 1.0 1.5 2.0 2.5 Instaneous Forward Voltage (V) Peak Forward Surage Current (A) 126 108 90 72 54 36 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 Number of Cycles version: 02 http://www.trr-jx.com T J =25°C 100 10 T J=25°C f = 1.0MHz V sig = 50mV p-p 1 0.1 1.0 10 Reverse Voltage (V) Fig.6 Maximum Non-Repetitive Peak Forward Surage Current 18 100 Fig.5 Typical Junction Capacitance 10 0.5 80 % of PIV.VOLTS Fig.4 Typical Forward Characteristics 0 60 100 100
很抱歉,暂时无法提供与“ES3K”相匹配的价格&库存,您可以联系我们找货
ES3K
    • 10+0.35603
    • 100+0.28759
    • 300+0.25333
    • 3000+0.22767
    • 6000+0.20716
    • 9000+0.19689
    库存:1085
