SS510C
SS510C
    JUXING(钜兴)
    DO-214AB(SMC)
SS510C 数据手册
Test Report. (SVHC) No. CANEC2220698301   . Date: 08 Oct 2022 . Page 1 of 22. Client Name : GUANGDONG JUXING ELECTRONICE TECHNOLOGY CO., LTD. . Client Address : RONGJING 1 ROAD 4 HAO YUSHAN GUOJI YONGNING STREET ZENGCHENG DISTRICT, . Sample Name : Diode. Model No. :. SMA. Client Ref. Info. : . HBS, DO-214AC/AA/AB(SMA/SMB/SMC), R-1/3/6, DO-41, DO-15, DO-27, SMAF, SMBF, SOD-123/323/523(FL), SOT-23, SOT-323, SOT-89, MBS, MBF, MBF-S, MBM, ABS, DB-1, DB-S, DBF(UMSB), ULBF, DBL-S, SOF2-4F/S/J, . KBP, KBPC, KBL, KBU, KBJ, GBP, GBU, GBPC, GBL, GBJ, D3K, JA, WOM, TO-251, TO-252, TO-277, TO-263, TO-220(AB/AC) ITO-220(AB/AC), TO-247, TO-3P, MELF, MINIMELF . The above sample(s) and information were provided by the client. ----------------------------------------------------------------------------------------------------------------------------------------------------------. SGS Job No. : CP22-052394 - GZ . Date of Sample Received : . 26 Sep 2022. Testing Period : . 26 Sep 2022 - 30 Sep 2022 . Test Requested : . As requested by client, SVHC screening is performed according to: (i) Two hundred and twenty-four (224) substances in the Candidate List of Substances of Very High Concern (SVHC) for authorization published by European Chemicals Agency (ECHA) on and before Jun 10, 2022 regarding Regulation (EC) No 1907/2006 concerning the REACH. (ii) Nine (9) substances in the Public Consultation List of potential Substances of Very High Concern (SVHC) published by European Chemicals Agency (ECHA) on and before Sep 2, 2022 regarding Regulation (EC) No 1907/2006 concerning the REACH. (iii) One (1) potential Substances of Very High Concern (SVHC) in the notification of WTO on Jun 1, 2021. . Test Result(s) : . Please refer to next page(s). Summary :. According to the specified scope and evaluation screening, the test results of SVHC are > 0.1% (w/w) in the submitted sample. See SGS Sample ID 001. . See remark 2 for obligation under REACH Test Report. (SVHC) No. CANEC2220698301   . Date: 08 Oct 2022 . Signed for and on behalf of SGS-CSTC Standards Technical Services Co., Ltd. Guangzhou Branch. Coral Qiu . Approved Signatory . . . Page 2 of 22. Test Report. (SVHC) SGS Sample ID. No. CANEC2220698301   . Date: 08 Oct 2022 . The test results of SVHC over limit in the submitted sample summary Description Substance Name CAS No. Page 3 of 22. Concentration (%) 001 “Diode”. Lead cyanamidate* . 20837-86-9. 1.425. 001 “Diode”. Lead dinitrate*. 10099-74-8. 1.893. 001 “Diode”. Lead monoxide* . 1317-36-8. 1.276. 001 “Diode”. Lead oxide sulfate* . 12036-76-9. 1.505. 001 “Diode”. Lead tetroxide (orange lead)*. 1314-41-6. 1.307. 001 “Diode”. Pyrochlore, antimony lead yellow*. 8012-00-8. 1.008. 001 “Diode”. Sulfurous acid, lead salt, dibasic*. 62229-08-7. 1.511. 001 “Diode”. Tetralead trioxide sulphate*. 12202-17-4. 1.390. 001 “Diode”. Trilead bis(carbonate)dihydroxid e (basic lead carbonate)* . 1319-46-6. 1.478. 001 “Diode”. Lead di(acetate)* . 301-04-2. 1.860. 001 “Diode”. Lead. 7439-92-1. 1.184. Test Report. (SVHC) Remark :. No. CANEC2220698301   . Date: 08 Oct 2022 . Page 4 of 22. 1. The chemical analysis of specified SVHC is performed by means of currently available analytical techniques against the following SVHC related documents published by ECHA: http://echa.europa.eu/web/guest/candidate-list-table These lists are under evaluation by ECHA and may subject to change in the future. 2. REACH obligation: 2.1 Concerning article(s): Communication: Article 33 of Regulation (EC) No 1907/2006 requires supplier of an article containing a substance meeting the criteria in Article 57 and identified in accordance with Article 59(1) in a concentration above 0.1% weight by weight (w/w) shall provide the recipient of the article with sufficient information, available to the supplier, to allow safe use of the article including, as a minimum, the name of that substance in the Candidate List. Notification: In accordance with Regulation (EC) No 1907/2006, any EU producer or importer of articles shall notify ECHA, in accordance with paragraph 4 of Article 7, if a substance meets the criteria in Article 57 and is identified in accordance with Article 59(1) of the Regulation, if (a) the substance in the Candidate List is present in those articles in quantities totaling over one tonne per producer or importer per year; and (b) the substance in the Candidate List is present in those articles above a concentration of 0.1% weight by weight (w/w). SGS adopts the ruling of the Court of Justice of the European Union on the definition of an article under REACH unless indicated otherwise. Detail explanation is available at the following link: http://www.sgs.com/-/media/global/documents/technical-documents/technical-bulletins/sgs-crsposition-statement-on-svhc-in-articles-a4-en-16-06.pdf?la=en 2.2 Concerning material(s): Test results in this report are based on the tested sample. This report refers to testing result of tested sample submitted as homogenous material(s). In case such material is being used to compose an article, the results indicated in this report may not represent SVHC concentration in such article. If this report refers to testing result of composite material group by equal weight proportion, the material in each composite test group may come from more than one article. If the sample is a substance or mixture, and it directly exports to EU, client has the obligation to comply with the supply chain communication obligation under Article 31 of Regulation (EC) No. 1907/2006 and the conditions of Authorization of substance of very high concern included in the Annex XIV of the Regulation (EC) No. 1907/2006. 2.3 Concerning substance and preparation: If a SVHC is found over 0.1% (w/w) and/or the specific concentration limit which is set in Regulation (EC) No 1272/2008 and its amendments, client is suggested to prepare a Safety Test Report. (SVHC) No. CANEC2220698301   . Date: 08 Oct 2022 . Page 5 of 22. Data Sheet (SDS) against the SVHC to comply with the supply chain communication obligation under Regulation (EC) No 1907/2006, in which: - a substance that is classified as hazardous under the CLP Regulation (EC) No 1272/2008. - a mixture that is classified as hazardous under the CLP Regulation (EC) No 1272/2008, when it contains a substance with concentration equal to, or greater than the classification limit as set in Regulation (EC) No. 1272/2008; or - a mixture is not classified as hazardous under the CLP Regulation (EC) No 1272/2008, but contains either: (a) a substance posing human health or environmental hazards in an individual concentration of ≥ 1 % by weight for mixtures that are solid or liquids (i.e., non-gaseous mixtures) or ≥ 0.2 % by volume for gaseous mixtures; or (b) a substance that is PBT, or vPvB in an individual concentration of ≥ 0.1 % by weight for mixtures that are solid or liquids (i.e., non-gaseous mixtures); or (c) a substance on the SVHC candidate list (for reasons other than those listed above), in an individual concentration of ≥ 0.1 % by weight for non-gaseous mixtures; or (d) a substance for which there are Europe-wide workplace exposure limits. 3. If a SVHC is found over the reporting limit, client is suggested to identify the composite component which contains the SVHC and the exact concentration of the SVHC by requesting further quantitative analysis from the laboratory. Test Sample :. Sample Description :. Specimen No.. SN1. SGS Description. Sample ID. CAN22-206983.001 “Diode”. Test Method :. SGS In-House method- SGS-CCL-TOP-092-01, SGS-CCL-TOP-092-02, Analyzed by ICP-OES, UV-VIS, GC-MS, HPLC-DAD/MS and Colorimetric Method. . Test Report. (SVHC) No. CANEC2220698301   . Date: 08 Oct 2022 . Page 6 of 22. Test Result: (Substances in the Candidate List of SVHC) Batch Substance Name CAS No. 001 Concentration (%) RL (%) VIII Lead cyanamidate* . 20837-86-9. 1.425. 0.005. VIII Lead dinitrate*. 10099-74-8. 1.893. 0.005. VIII Lead monoxide* . 1317-36-8. 1.276. 0.005. VIII Lead oxide sulfate* . 12036-76-9. 1.505. 0.005. VIII Lead tetroxide (orange lead)* . 1314-41-6. 1.307. 0.005. VIII Pyrochlore, antimony lead yellow* . 8012-00-8. 1.008. 0.005. VIII Sulfurous acid, lead salt, dibasic* . 62229-08-7. 1.511. 0.005. VIII Tetralead trioxide sulphate* . 12202-17-4. 1.390. 0.005. VIII Trilead bis(carbonate)dihydroxide (basic lead carbonate)*. 1319-46-6. 1.478. 0.005. Lead di(acetate)* . 301-04-2. 1.860. 0.005. Lead. 7439-92-1. 1.184. 0.005. - ND - CAS No. 001 Concentration (%) RL (%) - ND - X XIX - Other tested SVHC in candidate list Test Result: (Potential SVHC) Batch Substance Name - All tested Potential SVHC Test Report. (SVHC) No. CANEC2220698301   . Date: 08 Oct 2022 . Page 7 of 22. Notes :. 1.The table above only shows detected SVHC, and SVHC that below RL are not reported. Please refer to Appendix for the full list of tested SVHC. 2.RL = Reporting Limit (Test data will be shown if it ≥ RL. RL is not regulatory limit.) ND = Not detected (lower than RL),   ND is denoted on the SVHC substance. 3.* The test result is based on the calculation of selected element(s) and to the worst-case scenario. ** The test result is based on the calculation of selected marker(s) and to the worst-case scenario. 4. RL = 0.005% is evaluated for element (i.e. cobalt, arsenic, lead, chromium (VI), aluminum, zirconium, boron, strontium, zinc, antimony, titanium, barium, cadmium respectively), except molybdenum RL=0.0005%, boron RL=0.0025% (only for Lead bis(tetrafluoroborate)), fluorine RL=0.050%. . 5. Calculated concentration of boric compounds are based on water extractive boron detected by ICP-OES.    Calculated concentration of Barium diboron tetraoxide is based on water extractive boron and barium detected by ICP-OES. . 6. § The substance is proposed for the identification as SVHC only where it contains Michler’s ketone (CAS Number: 90-94-8) or Michler’s base (CAS Number: 101-61-1) ≥0.1% (w/w). 7. / = Potential SVHC . Unless otherwise stated, the decision rule for conformity reporting is based on Binary Statement for Simple Acceptance Rule ( w =0) stated in ILAC-G8:09/2019. . Test Report. (SVHC) No. CANEC2220698301   . Date: 08 Oct 2022 . Page 8 of 22. Appendix Full list of tested SVHC: Batch No. I 1 I Substance Name CAS No. RL (%) 4,4' -Diaminodiphenylmethane(MDA) . 101-77-9. 0.050. 2 5-tert-butyl-2,4,6-trinitro-m-xylene (musk xylene) . 81-15-2. 0.050. I 3 Alkanes, C10-13, chloro (Short Chain Chlorinated Paraffins) . 85535-84-8. 0.050. I 4 Anthracene. 120-12-7. 0.050. I 5 Benzyl butyl phthalate (BBP) . 85-68-7. 0.050. I 6 Bis (2-ethylhexyl)phthalate (DEHP) . 117-81-7. 0.050. I 7 Bis(tributyltin)oxide (TBTO) . 56-35-9. 0.050. I 8 Cobalt dichloride* . 7646-79-9. 0.005. I 9 Diarsenic pentaoxide* . 1303-28-2. 0.005. I 10 Diarsenic trioxide* . 1327-53-3. 0.005. I 11 Dibutyl phthalate (DBP) . 84-74-2. 0.050. I 12 Hexabromocyclododecane (HBCDD) and all major diastereoisomers identified (α-HBCDD, β-HBCDD, γ-HBCDD). -. 0.050. I 13 Lead hydrogen arsenate* . 7784-40-9. 0.005. I 14 Sodium dichromate* . 7789-12-0, 10588-01-9. 0.005. I 15 Triethyl arsenate* . 15606-95-8. 0.005. II 16 2,4-Dinitrotoluene . 121-14-2. 0.050. II 17 Acrylamide. 79-06-1. 0.050. II 18 Anthracene oil** . 90640-80-5. 0.050. II 19 Anthracene oil, anthracene paste** . 90640-81-6. 0.050. II 20 Anthracene oil, anthracene paste, anthracene fraction** . 91995-15-2. 0.050. Test Report. (SVHC) No. CANEC2220698301   . Date: 08 Oct 2022 . Page 9 of 22. Appendix Full list of tested SVHC: Batch No. II 21 II Substance Name CAS No. RL (%) Anthracene oil, anthracene paste, distn. lights** . 91995-17-4. 0.050. 22 Anthracene oil, anthracene-low** . 90640-82-7. 0.050. II 23 Diisobutyl phthalate . 84-69-5. 0.050. II 24 Lead chromate molybdate sulphate red (C.I. Pigment Red 104)*. 12656-85-8. 0.005. II 25 Lead chromate* . 7758-97-6. 0.005. II 26 Lead sulfochromate yellow (C.I. Pigment Yellow 34)* . 1344-37-2. 0.005. II 27 Pitch, coal tar, high temp.** . 65996-93-2. 0.050. II 28 Tris(2-chloroethyl)phosphate . 115-96-8. 0.050. III 29 Ammonium dichromate* . 7789-09-5. 0.005. III 30 Boric acid*. -. 0.005. III 31 Disodium tetraborate, anhydrous* . 1303-96-4, 1330-43-4, 12179-04-3. 0.005. III 32 Potassium chromate* . 7789-00-6. 0.005. III 33 Potassium dichromate* . 7778-50-9. 0.005. III 34 Sodium chromate* . 7775-11-3. 0.005. III 35 Tetraboron disodium heptaoxide, hydrate* . 12267-73-1. 0.005. III 36 Trichloroethylene . 79-01-6. 0.050. IV 37 2-Ethoxyethanol . 110-80-5. 0.050. IV 38 2-Methoxyethanol . 109-86-4. 0.050. IV 39 Chromic acid, Oligomers of chromic acid and dichromic acid, Dichromic acid* . -. 0.005. Test Report. (SVHC) No. CANEC2220698301   . Date: 08 Oct 2022 . Page 10 of 22. Appendix Full list of tested SVHC: Batch No. IV 40 IV Substance Name CAS No. RL (%) Chromium trioxide* . 1333-82-0. 0.005. 41 Cobalt(II) carbonate* . 513-79-1. 0.005. IV 42 Cobalt(II) diacetate* . 71-48-7. 0.005. IV 43 Cobalt(II) dinitrate* . 10141-05-6. 0.005. IV 44 Cobalt(II) sulphate* . 10124-43-3. 0.005. V 45 1,2,3-trichloropropane . 96-18-4. 0.050. V 46 1,2-Benzenedicarboxylic acid, di-C6-8-branched alkyl esters, C7-rich. 71888-89-6. 0.050. V 47 1,2-Benzenedicarboxylic acid, di-C7-11-branched and linear alkyl esters. 68515-42-4. 0.050. V 48 1-methyl-2-pyrrolidone . 872-50-4. 0.050. V 49 2-ethoxyethyl acetate . 111-15-9. 0.050. V 50 Hydrazine. 7803-57-8, 302-01-2. 0.050. V 51 Strontium chromate* . 7789-06-2. 0.005. VI 52 1,2-Dichloroethane . 107-06-2. 0.050. VI 53 2,2'-dichloro-4,4'-methylenedianiline . 101-14-4. 0.050. VI 54 2-Methoxyaniline; o-Anisidine . 90-04-0. 0.050. VI 55 4-(1,1,3,3-tetramethylbutyl)phenol . 140-66-9. 0.050. VI 56 Aluminosilicate Refractory Ceramic Fibres * . -. 0.005. VI 57 Arsenic acid*. 7778-39-4. 0.005. VI 58 Bis(2-methoxyethyl) ether . 111-96-6. 0.050. VI 59 Bis(2-methoxyethyl) phthalate . 117-82-8. 0.050. Test Report. (SVHC) No. CANEC2220698301   . Date: 08 Oct 2022 . Page 11 of 22. Appendix Full list of tested SVHC: Batch No. VI 60 VI Substance Name CAS No. RL (%) Calcium arsenate* . 7778-44-1. 0.005. 61 Dichromium tris(chromate) * . 24613-89-6. 0.005. VI 62 Formaldehyde, oligomeric reaction products with aniline . 25214-70-4. 0.050. VI 63 Lead diazide, Lead azide* . 13424-46-9. 0.005. VI 64 Lead dipicrate*. 6477-64-1. 0.005. VI 65 Lead styphnate* . 15245-44-0. 0.005. VI 66 N,N-dimethylacetamide . 127-19-5. 0.050. VI 67 Pentazinc chromate octahydroxide* . 49663-84-5. 0.005. VI 68 Phenolphthalein. 77-09-8. 0.050. VI 69 Potassium hydroxyoctaoxodizincatedichromate* . 11103-86-9. 0.005. VI 70 Trilead diarsenate* . 3687-31-8. 0.005. VI 71 Zirconia Aluminosilicate Refractory Ceramic Fibres* . -. 0.005. VII 72 [4-[[4-anilino-1-naphthyl][4(dimethylamino)phenyl]methylene]cyclohexa-2,5-dien-1-ylide ne] dimethylammonium chloride (C.I. Basic Blue 26)§ . 2580-56-5. 0.050. VII 73 [4-[4,4'-bis(dimethylamino) benzhydrylidene]cyclohexa-2,5-dien-1-ylidene]dimethylamm onium chloride (C.I. Basic Violet 3)§ . 548-62-9. 0.050. VII 74 1,2-bis(2-methoxyethoxy)ethane (TEGDME; triglyme) . 112-49-2. 0.050. VII 75 1,2-dimethoxyethane; ethylene glycol dimethyl ether (EGDME). 110-71-4. 0.050. VII 76 4,4'-bis(dimethylamino) benzophenone (Michler’s Ketone) . 90-94-8. 0.050. VII 77 4,4'-bis(dimethylamino)-4''-(methylamino)trityl alcohol§ . 561-41-1. 0.050. VII 78 Diboron trioxide* . 1303-86-2. 0.005. Test Report. (SVHC) No. CANEC2220698301   . Date: 08 Oct 2022 . Page 12 of 22. Appendix Full list of tested SVHC: Batch No. Substance Name CAS No. RL (%) VII 79 Formamide. 75-12-7. 0.050. VII 80 Lead(II) bis(methanesulfonate)* . 17570-76-2. 0.005. VII 81 N,N,N',N'-tetramethyl-4,4'-methylenedianiline (Michler’s base). 101-61-1. 0.050. VII 82 TGIC (1,3,5-tris(oxiranylmethyl)-1,3,5-triazine-2,4,6(1H,3H,5H)-trio ne). 2451-62-9. 0.050. VII 83 α,α-Bis[4-(dimethylamino)phenyl]-4 (phenylamino)naphthalene-1-methanol (C.I. Solvent Blue 4) §. 6786-83-0. 0.050. VII 84 β-TGIC (1,3,5-tris[(2S and 2R)-2,3-epoxypropyl]-1,3,5-triazine-2,4,6-(1H,3H,5H)-trione) . 59653-74-6. 0.050. VIII 85 [Phthalato(2-)]dioxotrilead* . 69011-06-9. 0.005. VIII 86 1,2-Benzenedicarboxylic acid, dipentylester, branched and linear. 84777-06-0. 0.050. VIII 87 1,2-Diethoxyethane . 629-14-1. 0.050. VIII 88 1-Bromopropane . 106-94-5. 0.050. VIII 89 3-Ethyl-2-methyl-2-(3-methylbutyl)-1,3-oxazolidine . 143860-04-2. 0.050. VIII 90 4-(1,1,3,3-tetramethylbutyl)phenol, ethoxylated . -. 0.050. VIII 91 4,4'-Methylenedi-o-toluidine . 838-88-0. 0.050. VIII 92 4,4'-Oxydianiline and its salts . 101-80-4. 0.050. VIII 93 4-Aminoazobenzene . 60-09-3. 0.050. VIII 94 4-Methyl-m-phenylenediamine . 95-80-7. 0.050. VIII 95 4-Nonylphenol, branched and linear . -. 0.050. VIII 96 6-Methoxy-m-toluidine . 120-71-8. 0.050. VIII 97 Acetic acid, lead salt, basic* . 51404-69-4. 0.005. Test Report. (SVHC) No. CANEC2220698301   . Date: 08 Oct 2022 . Page 13 of 22. Appendix Full list of tested SVHC: Batch No. Substance Name CAS No. RL (%) VIII 98 Biphenyl-4-ylamine . 92-67-1. 0.050. VIII 99 Bis(pentabromophenyl) ether (DecaBDE) . 1163-19-5. 0.050. VIII 100 Cyclohexane-1,2-dicarboxylic anhydride, cis-cyclohexane-1,2-dicarboxylic anhydride, trans-cyclohexane-1,2-dicarboxylic anhydride . -. 0.050. VIII 101 Diazene-1,2-dicarboxamide (C,C'-azodi(formamide)) . 123-77-3. 0.050. VIII 102 Dibutyltin dichloride (DBTC) . 683-18-1. 0.050. VIII 103 Diethyl sulphate . 64-67-5. 0.050. VIII 104 Diisopentylphthalate . 605-50-5. 0.050. VIII 105 Dimethyl sulphate . 77-78-1. 0.050. VIII 106 Dinoseb. 88-85-7. 0.050. VIII 107 Dioxobis(stearato)trilead* . 12578-12-0. 0.005. VIII 108 Fatty acids, C16-18, lead salts* . 91031-62-8. 0.005. VIII 109 Furan. 110-00-9. 0.050. VIII 110 Henicosafluoroundecanoic acid . 2058-94-8. 0.050. VIII 111 Heptacosafluorotetradecanoic acid . 376-06-7. 0.050. VIII 112 Hexahydromethylphathalic anhydride, Hexahydro-4-methylphathalic anhydride, Hexahydro-1-methylphathalic anhydride, Hexahydro-3-methylphathalic anhydride . -. 0.050. VIII 113 Lead bis(tetrafluoroborate)* . 13814-96-5. 0.005. VIII 114 Lead cyanamidate* . 20837-86-9. 0.005. VIII 115 Lead dinitrate*. 10099-74-8. 0.005. VIII 116 Lead monoxide* . 1317-36-8. 0.005. Test Report. (SVHC) No. CANEC2220698301   . Date: 08 Oct 2022 . Page 14 of 22. Appendix Full list of tested SVHC: Batch No. VIII 117 VIII Substance Name CAS No. RL (%) Lead oxide sulfate* . 12036-76-9. 0.005. 118 Lead tetroxide (orange lead)* . 1314-41-6. 0.005. VIII 119 Lead titanium trioxide* . 12060-00-3. 0.005. VIII 120 Lead titanium zirconium oxide* . 12626-81-2. 0.005. VIII 121 Methoxyacetic acid . 625-45-6. 0.050. VIII 122 Methyloxirane (Propylene oxide) . 75-56-9. 0.050. VIII 123 N,N-dimethylformamide . 68-12-2. 0.050. VIII 124 N-Methylacetamide . 79-16-3. 0.050. VIII 125 N-Pentyl-isopentylphthalate . 776297-69-9. 0.050. VIII 126 o-Aminoazotoluene . 97-56-3. 0.050. VIII 127 o-Toluidine. 95-53-4. 0.050. VIII 128 Pentacosafluorotridecanoic acid . 72629-94-8. 0.050. VIII 129 Pentalead tetraoxide sulphate* . 12065-90-6. 0.005. VIII 130 Pyrochlore, antimony lead yellow* . 8012-00-8. 0.005. VIII 131 Silicic acid, barium salt, lead-doped* . 68784-75-8. 0.005. VIII 132 Silicic acid, lead salt* . 11120-22-2. 0.005. VIII 133 Sulfurous acid, lead salt, dibasic* . 62229-08-7. 0.005. VIII 134 Tetraethyllead* . 78-00-2. 0.005. VIII 135 Tetralead trioxide sulphate* . 12202-17-4. 0.005. VIII 136 Tricosafluorododecanoic acid . 307-55-1. 0.050. VIII 137 Trilead bis(carbonate)dihydroxide (basic lead carbonate)* . 1319-46-6. 0.005. Test Report. (SVHC) No. CANEC2220698301   . Date: 08 Oct 2022 . Page 15 of 22. Appendix Full list of tested SVHC: Batch No. Substance Name CAS No. RL (%) VIII 138 Trilead dioxide phosphonate* . 12141-20-7. 0.005. IX 139 4-Nonylphenol, branched and linear, ethoxylated . -. 0.050. IX 140 Ammonium pentadecafluorooctanoate (APFO)** . 3825-26-1. 0.050. IX 141 Cadmium oxide* . 1306-19-0. 0.005. IX 142 Cadmium. 7440-43-9. 0.005. IX 143 Dipentyl phthalate (DPP) . 131-18-0. 0.050. IX 144 Pentadecafluorooctanoic acid (PFOA) . 335-67-1. 0.050. X 145 Cadmium sulphide* . 1306-23-6. 0.005. X 146 Dihexyl phthalate . 84-75-3. 0.050. X 147 Disodium 3,3'[[1,1'-biphenyl]-4,4'-diylbis(azo)]bis(4-aminonaphthalene-1-su lphonate) (C.I. Direct Red 28) . 573-58-0. 0.050. X 148 Disodium 4-amino-3-[[4'-[(2,4-diaminophenyl)azo] [1,1'-biphenyl]-4-yl]azo] -5-hydroxy-6(phenylazo)naphthalene-2,7-disulphonate (C.I. Direct Black 38). 1937-37-7. 0.050. X 149 Imidazolidine-2-thione; (2-imidazoline-2-thiol) . 96-45-7. 0.050. X 150 Lead di(acetate)* . 301-04-2. 0.005. X 151 Trixylyl phosphate . 25155-23-1. 0.050. XI 152 1,2-Benzenedicarboxylic acid, dihexyl ester, branched and linear. 68515-50-4. 0.050. XI 153 Cadmium chloride* . 10108-64-2. 0.005. XI 154 Sodium perborate; perboric acid, sodium salt* . -. 0.005. XI 155 Sodium peroxometaborate* . 7632-04-4. 0.005. Test Report. (SVHC) No. CANEC2220698301   . Date: 08 Oct 2022 . Page 16 of 22. Appendix Full list of tested SVHC: Batch No. XII 156 XII Substance Name CAS No. RL (%) 2-(2H-Benzotriazol-2-yl)-4,6-ditertpentylphenol (UV-328) . 25973-55-1. 0.050. 157 2-benzotriazol-2-yl-4,6-di-tert-butylphenol (UV-320) . 3846-71-7. 0.050. XII 158 2-Ethylhexyl 10-ethyl-4,4-dioctyl-7-oxo-8-oxa-3,5-dithia-4-stannatetradeca noate; DOTE. 15571-58-1. 0.050. XII 159 Cadmium fluoride* . 7790-79-6. 0.005. XII 160 Cadmium sulphate* . 10124-36-4, 31119-53-6. 0.005. XII 161 Reaction mass of 2-ethylhexyl 10-ethyl-4,4-dioctyl-7-oxo-8-oxa-3,5-dithia-4-stannatetradeca noate & 2-ethylhexyl 10-ethyl-4-[[2[(2-ethylhexyl)oxy]-2-oxoethyl]thio]-4-octyl-7-oxo-8-oxa-3,5-di thia-4-stannatetradecanoate (reaction mass of DOTE & MOTE). -. 0.050. XIII 162 1,2-benzenedicarboxylic acid, di-C6-10-alkyl esters; 1,2-benzenedicarboxylic acid, mixed decyl and hexyl and octyl diesters with ≥ 0.3% of dihexyl phthalate . -. 0.050. XIII 163 5-sec-butyl-2(2,4-dimethylcyclohex-3-en-1-yl)-5-methyl-1,3-dioxane [1], 5-sec-butyl-2(4,6-dimethylcyclohex-3-en-1-yl)-5-methyl-1,3-dioxane [2] [covering any of the individual isomers of [1] and [2] or any combination thereof] . -. 0.050. XIV 164 1,3-propanesultone . 1120-71-4. 0.050. XIV 165 2,4-di-tert-butyl-6-(5-chlorobenzotriazol-2-yl)phenol (UV-327). 3864-99-1. 0.050. XIV 166 2-(2H-benzotriazol-2-yl)-4-(tert-butyl)-6-(sec-butyl)phenol (UV-350). 36437-37-3. 0.050. XIV 167 Nitrobenzene. 98-95-3. 0.050. XIV 168 Perfluorononan-1-oic-acid and its sodium and ammonium salts. -. 0.050. XV 169 Benzo[def]chrysene (Benzo[a]pyrene) . 50-32-8. 0.050. Test Report. (SVHC) No. CANEC2220698301   . Date: 08 Oct 2022 . Page 17 of 22. Appendix Full list of tested SVHC: Batch No. Substance Name CAS No. RL (%) XVI 170 4,4’-isopropylidenediphenol (bisphenol A) . 80-05-7. 0.050. XVI 171 4-Heptylphenol, branched and linear . -. 0.050. XVI 172 Nonadecafluorodecanoic acid (PFDA) and its sodium and ammonium salts . -. 0.050. XVI 173 p-(1,1-dimethylpropyl)phenol . 80-46-6. 0.050. XVII 174 Perfluorohexane-1-sulphonic acid and its salts . -. 0.050. XVIII 175 1,6,7,8,9,14,15,16,17,17,18,18-Dodecachloropentacyclo[12. 2.1.16,9.02,13.05,10]octadeca-7,15-diene (“Dechlorane Plus”™) [covering any of its individual anti- and syn-isomers or any combination thereof] . -. 0.050. XVIII 176 Benz[a]anthracene . 56-55-3. 0.050. XVIII 177 Cadmium nitrate* . 10325-94-7. 0.005. XVIII 178 Cadmium carbonate* . 513-78-0. 0.005. XVIII 179 Cadmium hydroxide* . 21041-95-2. 0.005. XVIII 180 Chrysene. 218-01-9. 0.050. XVIII 181 Reaction products of 1,3,4-thiadiazolidine-2,5-dithione, formaldehyde and 4-heptylphenol, branched and linear (RP-HP) [with ≥0.1% w/w 4-heptylphenol, branched and linear]. -. 0.050. XIX 182 Benzene-1,2,4-tricarboxylic acid 1,2-anhydride (trimellitic anhydride). 552-30-7. 0.050. XIX 183 Benzo[ghi]perylene . 191-24-2. 0.050. XIX 184 Decamethylcyclopentasiloxane (D5) . 541-02-6. 0.050. XIX 185 Dicyclohexyl phthalate (DCHP) . 84-61-7. 0.050. XIX 186 Disodium octaborate* . 12008-41-2. 0.005. XIX 187 Dodecamethylcyclohexasiloxane (D6) . 540-97-6. 0.050. Test Report. (SVHC) No. CANEC2220698301   . Date: 08 Oct 2022 . Page 18 of 22. Appendix Full list of tested SVHC: Batch No. XIX 188 XIX Substance Name CAS No. RL (%) Ethylenediamine . 107-15-3. 0.050. 189 Lead. 7439-92-1. 0.005. XIX 190 Octamethylcyclotetrasiloxane (D4) . 556-67-2. 0.050. XIX 191 Terphenyl hydrogenated . 61788-32-7. 0.050. XX 192 1,7,7-trimethyl-3(phenylmethylene)bicyclo[2.2.1]heptan-2-one (3-benzylidene camphor). 15087-24-8. 0.050. XX 193 2,2-bis(4'-hydroxyphenyl)-4- methylpentane . 6807-17-6. 0.050. XX 194 Benzo[k]fluoranthene . 207-08-9. 0.050. XX 195 Fluoranthene. 206-44-0. 0.050. XX 196 Phenanthrene. 85-01-8. 0.050. XX 197 Pyrene. 129-00-0. 0.050. XXI 198 2,3,3,3-tetrafluoro-2-(heptafluoropropoxy)propionic acid, its salts and its acyl halides (covering any of their individual isomers and combinations thereof) . -. 0.050. XXI 199 2-methoxyethyl acetate . 110-49-6. 0.050. XXI 200 4-tert-butylphenol (PTBP) . 98-54-4. 0.050. XXI 201 Tris(4-nonylphenyl,branched and linear) phosphite (TNPP) with ≥ 0.1% w/w of 4-nonylphenol, branched and linear (4-NP). -. 0.050. XXII 202 2-benzyl-2-dimethylamino-4'-morpholinobutyrophenone . 119313-12-1. 0.050. XXII 203 2-methyl-1-(4-methylthiophenyl)-2-morpholinopropan-1-one . 71868-10-5. 0.050. XXII 204 Diisohexyl phthalate . 71850-09-4. 0.050. XXII 205 Perfluorobutane sulfonic acid (PFBS) and its salts . -. 0.050. Test Report. (SVHC) No. CANEC2220698301   . Date: 08 Oct 2022 . Page 19 of 22. Appendix Full list of tested SVHC: Batch No. XXIII 206 XXIII Substance Name CAS No. RL (%) 1-vinylimidazole . 1072-63-5. 0.050. 207 2-methylimidazole . 693-98-1. 0.050. XXIII 208 Butyl 4-hydroxybenzoate . 94-26-8. 0.050. XXIII 209 Dibutylbis(pentane-2,4-dionato-O,O')tin** . 22673-19-4. 0.050. XXIV 210 bis(2-(2-methoxyethoxy)ethyl) ether . 143-24-8. 0.050. XXIV 211 Dioctyltin dilaurate, stannane, dioctyl-, bis(coco acyloxy) derivs., and any other stannane, dioctyl-, bis(fatty acyloxy) derivs. wherein C12 is the predominant carbon number of the fatty acyloxy moiety** . -. 0.050. XXV 212 1,4-dioxane. 123-91-1. 0.050. XXV 213 2,2-bis(bromomethyl)propane1,3-diol (BMP); 2,2-dimethylpropan-1-ol, tribromo derivative/3-bromo-2,2-bis(bromomethyl)-1-propanol (TBNPA); 2,3-dibromo-1-propanol (2,3-DBPA) . -. 0.050. XXV 214 2-(4-tert-butylbenzyl)propionaldehyde and its individual stereoisomers . -. 0.050. XXV 215 4,4'-(1-methylpropylidene)bisphenol (bisphenol B) . 77-40-7. 0.050. XXV 216 Glutaral. 111-30-8. 0.050. XXV 217 Medium-chain chlorinated paraffins (MCCP) [UVCB substances consisting of more than or equal to 80% linear chloroalkanes with carbon chain lengths within the range from C14 to C17] . -. 0.050. XXV 218 Orthoboric acid, sodium salt* . 13840-56-7. 0.005. XXV 219 Phenol, alkylation products (mainly in para position) with C12-rich branched alkyl chains from oligomerisation, covering any individual isomers and/ or combinations thereof (PDDP). -. 0.050. Test Report. (SVHC) No. CANEC2220698301   . Date: 08 Oct 2022 . Page 20 of 22. Appendix Full list of tested SVHC: Batch No. Substance Name CAS No. RL (%) XXVI 220 (±)-1,7,7-trimethyl-3[(4-methylphenyl)methylene]bicyclo[2.2.1]heptan-2-one covering any of the individual isomers and/or combinations thereof (4-MBC) . -. 0.050. XXVI 221 6,6'-di-tert-butyl-2,2'-methylenedi-p-cresol (DBMC) . 119-47-1. 0.050. XXVI 222 S-(tricyclo[5.2.1.0'2,6]deca-3-en-8(or 9)-yl) O-(isopropyl or isobutyl or 2-ethylhexyl) O-(isopropyl or isobutyl or 2-ethylhexyl) phosphorodithioate . 255881-94-8. 0.050. XXVI 223 Tris(2-methoxyethoxy)vinylsilane . 1067-53-4. 0.050. XXVII 224 N-(hydroxymethyl)acrylamide . 924-42-5. 0.050. / 225 1,1'-[ethane-1,2-diylbisoxy]bis[2,4,6-tribromobenzene] . 37853-59-1. 0.050. / 226 2,2',6,6'-tetrabromo-4,4'-isopropylidenediphenol . 79-94-7. 0.050. / 227 4,4'-sulphonyldiphenol . 80-09-1. 0.050. / 228 Barium diboron tetraoxide* . 13701-59-2. 0.005. / 229 Bis(2-ethylhexyl) tetrabromophthalate covering any of the individual isomers and/or combinations thereof . -. 0.050. / 230 Isobutyl 4-hydroxybenzoate . 4247-02-3. 0.050. / 231 Melamine. 108-78-1. 0.050. / 232 Perfluoroheptanoic acid and its salts . -. 0.050. / 233 reaction mass of 2,2,3,3,5,5,6,6-octafluoro-4(1,1,1,2,3,3,3-heptafluoropropan-2-yl)morpholine and 2,2,3,3,5,5,6,6-octafluoro-4-(heptafluoropropyl)morpholine . -. 0.050. / 234 Resorcinol. 108-46-3. 0.050. Test Report. (SVHC) No. CANEC2220698301   . ATTACHMENTS SVHC Testing Flow Chart Sample cutting/preparation Sample measurement Sample Pretreatment Instrumental Analysis DATA Date: 08 Oct 2022 . Page 21 of 22. Test Report. (SVHC) No. CANEC2220698301   . Date: 08 Oct 2022 . Sample photo: . CANEC2220698301 CAN22-206983.001 . SGS authenticate the photo on original report only . *** End of Report *** . Page 22 of 22.
SS510C 价格&库存
很抱歉,暂时无法提供与“SS510C”相匹配的价格&库存,您可以联系我们找货
SS510C
    • 5+0.47105
    • 50+0.45997
    • 150+0.45247
    • 500+0.44508
    库存:743
