S6MCG
S6MCG
    SK(台湾时科)
    DO-214AB(SMC)
S6MCG 数据手册
S6ACG THRU S6MCG Surface Mount General Purpose Silicon Rectifiers Reverse Voltage - 50 to 1000 V Forward Current - 6 A PINNING PIN FEATURES • For surface mounted applications • Low profile package • Glass Passivated Chip Junction • Easy to pick and place • Lead free in comply with EU RoHS 2011/65/EU directives DESCRIPTION 1 Cathode 2 Anode 2 1 MECHANICAL DATA • Case: SMC • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 0.22g / 0.0077oz Top View Marking Code: S6A~S6M Simplified outline SMC and symbol Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols S6ACG S6BCG Maximum Repetitive Peak Reverse Voltage V RRM 50 100 200 Maximum RMS voltage V RMS 35 70 Maximum DC Blocking Voltage V DC 50 100 Maximum Average Forward Rectified Current I F(AV) 6 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load I FSM 150 A Maximum Instantaneous Forward Voltage at 6 A VF 1.15 V IR 5 100 μA Cj 100 pF RθJA RθJC 35 13 °C/W T j , T stg -55 ~ +150 °C Parameter Maximum DC Reverse Current T a = 25 °C at Rated DC Blocking Voltage T a =125 °C Typical Junction Capacitance (1) Typical Thermal Resistance (2) Operating and Storage Temperature Range (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. REV.08 1 of 3 S6JCG S6KCG S6MCG Units 400 600 800 1000 V 140 280 420 560 700 V 200 400 600 800 1000 V S6DCG S6GCG S6ACG THRU S6MCG Fig.1 Forward Current Derating Curve Instaneous Reverse Current(μ A) Fig.2 Typical Reverse Characteristics Average Forward Current (A) 7.0 6.0 5.0 4.0 3.0 2.0 1.0 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 175 100 T J =125°C 10 1.0 T J =25°C 0.1 00 Case Temperature (°C) Junction Capacitance ( pF) Instaneous Forward Current (A) 10 1.0 60 80 100 120 140 T J =25°C 100 10 T J =25°C 0.1 0.4 1 0.6 0.8 1.0 1.2 1.4 1.6 1.8 0.1 Fig.6 Maximum Non-Repetitive Peak Forward Surage Current 180 150 120 90 60 30 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 1.0 10 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surage Current (A) 40 Fig.4 Typical Junction Capacitance Fig.3 Typical Forward Characteristic 100 Number of Cycles REV.08 20 percent of Rated Peak Reverse Voltage (%) 2 of 3 100 S6ACG THRU S6MCG PACKAGE OUTLINE SMC Plastic surface mounted package; 2 leads E A A1 A C b D L E1 VM A SMC mechanical data A E D E1 A1 C L b max 2.62 7.0 6.2 8.0 0.21 0.31 1.6 3.25 min 2.00 6.5 5.6 7.6 0.05 0.15 0.9 2.75 max 103 276 244 315 8.3 12 63 128 min 79 256 220 299 2.0 5.9 35 108 UNIT mm mil Marking The recommended mounting pad size Type number 3.8 (150) 4.1 (160) 4.3 (170) 4.1 (160) mm Unit : (mil) REV.08 3 of 3 Marking code S6ACG S6A S6BCG S6B S6DCG S6D S6GCG S6G S6JCG S6J S6KCG S6K S6MCG S6M
S6MCG 价格&库存
很抱歉,暂时无法提供与“S6MCG”相匹配的价格&库存,您可以联系我们找货
S6MCG
    • 10+0.41071
    • 100+0.33263
    • 300+0.29365
    • 3000+0.26441
    • 6000+0.24101
    • 9000+0.22932
    库存:294
