RS5A-RS5M
Surface Mount Rectifiers
Features
SMC/DO-214AB
Plastic package has underwriters laborator
flammability classification 94V-0
For surface mounted applications
Low profile package
Built-in strain relief,ideal for automated placement
Glass passivated chip junction
High temperature soldering:
250oC/10 seconds at terminals
111
Mechanical Data
Case:JEDEC DO-214AB,molded plastic over
passivated chip
Polarity: color band denotes cathode end
Weight: 0.007 ounces, 0.21 gram
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25oC ambient temperature unless otherwise specified
RS5A
RS5B RS5D
RS5G RS5J
RS5K RS5M
UNITS
Maximum recurrent peak reverse voltage
VRRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
VRWS
35
70
140
280
420
560
700
V
VDC
50
100
200
400
600
800
1000
V
Maximum DC blocking voltage
Maximum average forword rectified current at
c TL=90OC
I F(AV)
5.0
A
Peak forward surge current 8.3ms
c single half-sine-wave superimposed on rated
c load
IFSM
150
A
Maximum instantaneous forward voltage at 5.0A
VF
1.3
V
Maximum DC reverse current
at rated DC blockjing voltage
@TA=25oC
5.0
IR
@TA=125oC
200
Maximum reverse recovery time (NOTE 1)
trr
Typical junction capacitance (NOTE 2)
CJ
Typical thermal resitance (NOTE 3)
R
Operating junction and storage temperature range
250
150
500
ns
32
JA
TJTSTG
22
-55--------+150
pF
o
C/W
o
C
NOTE: 1.Reverse recovery time test conditions:IF=0.5A,IR=1.0A,Irr=0.25A
2. Measured at 1.0MHz and applied reverse voltage of 4.0 Volts
3. Thermal resistance from junction to ambient and junction to lead P.C.B.mounted on 0.2''X0.2''(5.0X5.0mm2) copper pad areas
ht t p : //
Revision:20170701-P1
www.lgesemi .c o m
mail:lge@lgesemi.com
RS5A-RS5M
Ratings AND Charactieristic Curves
FIG.1 -- FORWARD DERATING CURVE
FIG.2 PEAK FORWARD SURGE CURRENT
6.0
PEAK FORWARD SURGE
CURRENT,AMPERES
AVERAGE FORWARD
CURRENT,AMPERES
150
Resistive or inductive Load
4.0
2.0
P.C.B.MOUNTED ON
0.27''X0.27''(7.0X7.0mm)
COPPERPAND AREAS
90 100 110 120 130 140 150 160
O
8.3ms Single Half Sine-Wave
(JEDEC Method)
120
90
60
30
10
LEAD TEMPERATURE
NUMBER OF CYCLES AT 60Hz
FIG.4 -- TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE
CURRENT,MICROAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG.3 -- TYPICAL FORWARD CHARACTERISTICS
O
TJ=25 C
1
Puise Width=300 S
1%DUTY CYCLE
0.1
0.01
0.4
0.6
0.8
1.0
1.2
1.4
1.6
1.8
INSTANTANEOUS FORWARD VOLTAGE,VOLTS
,pF
100
100
TJ=125 C
10
1
TJ=25 C
0.1
60
80
100
PERCENT OF RATED PEAK REVERSE VOLTAGE,
FIG.5-TYPICAL JUNCTION CAPACITANCE
100
60
40
4
TJ=25
f=1MHz
2
1
.1
.2
.4
1.0
2 4
10 20
40
100
REVERSE VOLTAGE,VOLTS
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
SMC
3000/REEL
42000
36X36X36.5
18.50
15.50
ht t p : //
www.lgesemi .c o m
很抱歉,暂时无法提供与“RS5M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.42313
- 100+0.33448
- 300+0.29016
- 3000+0.25691
- 6000+0.23034
- 9000+0.21700
