� �D�
宏迦橙
ES8AC THRU ES8JC
SURFACE MOUNT SUPER FAST RECOVERY RECTIFIER
www.ichjc.com
Features
DO-214AB(SMC)
•Low reverse leakage
•Ideal for automated placement
•Glass passivated pallet chip junction
•Super fast reverse recovery time
•Fast switching for high efficiency
•High forward surge capability
Applications
For use in high frequency rectification and free wheeling application in switching
mode converters and inverters for consumer, computer, automotive, and
telecommunication.
Mechanical Data
•Case: DO-214AB(SMC)
Molding compound meets UL 94V-0 flammability rating, RoHS-compliant,
halogen-free
•Terminals: Solder plated, solderable per MIL-STD-750,Method 2026
•Polarity: Cathode line denotes the cathode end
Maximum Ratings (Ta=25℃ Unless otherwise specified)
PARAMETER
SYMBOL
UNIT
ES8AC
ES8BC
ES8CC
ES8DC
ES8EC
ES8GC
ES8JC
Maximum RMS Voltage
VRMS
V
35
70
105
140
210
280
420
Maximum repetitive peak reverse voltage
VRRM
Maximum DC blocking Voltage
V
VDC
Maximum Average Forward Rectified Current
@60Hz sinewave, Resistance load,TL (Fig.1)
Non-repetitive Peak Forward Surge Current
@ t=8.3ms Half-sine wave
V
Junction temperature
150
100
200
150
200
A
Tstg
-55 ~+150
RθJ-A
℃ /W
47
Tj
Typical Thermal Resistance
50
100
IF(AV)
IFSM
Storage temperature
50
RθJ-L
A
8.0
Maximum instantaneous
forward voltage
TEST CONDITIONS
IF=8.0A
Maxinum reverse recovery time IF=0.5A,IR=1.0A,Irr=0.25A
Maximum DC reverse currentat
rated DC blocking voltage
Typical junction capacitance
Revision:SFRD-May.2023-A0
VRM=VRRM
Ta=25℃
Ta=125℃
4.0V DC,1MHz
300
400
600
600
-55 ~+150
℃ /W
SYMBOL UNIT ES8AC
VF
400
175
15
Electrical Characteristics (Ta=25℃ Unless otherwise specified)
PARAMETER
300
V
Trr
ns
IR
μA
CJ
pF
1 of 3
ES8BC
ES8CC
1.0
Zhuhai Hongjiacheng Technology co., Ltd
ES8DC
35
ES8EC
ES8GC
1.3
ES8JC
1.7
2.0
200
82
www.ichjc.com
� �D�
宏迦橙
ES8AC THRU ES8JC
www.ichjc.com
Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified)
210
7
180
6
150
5
120
4
90
3
60
2
30
1
60
80
100
LEADTEMPERATURE(℃)
120
140
Fig. 1 Forward Current Derating Curve
10
1
Fig.2 Maximum Non-Repetitive Peak Forward Surge Current
Tj=25℃
Pulsewidth=300us
1%DutyCycle
1
Tj=125℃
0.1
0.01
0.2
100
10
NUMBEROFCYCLES
INSTANTANEOUSREVERSECURRENT(μA)
INSTANTANEOUSFORWARDCURRENT(A)
8.3msSingleHalfSineWave
(JEDECMethod)
PEAKFORWARDSURGECURRENT(A)
AVERAGEFORWARDOUTPUTCURRENT(A)
8
Tj=25℃
0.6
1.0
1.4
ES8AC-ES8DC
ES8FC-ES8GC
ES8JC
INSTANTANEOUSFORWARDVOLTAGE(V)
1.8
2.0
Fig.3 Typical Forward Voltage
PERCENTOFRATEDPEAKREVERSEVOLTAGE(%)
Fig.4 Typical Reverse Characteristics
2 of 3
www.ichjc.com
� �D�
宏迦橙
ES8AC THRU ES8JC
www.ichjc.com
Ordering Information
PACKAGE
PACKAGE CODE
UNIT WEIGHT(g)
REEL(pcs)
BOX(pcs)
CARTON(pcs)
DELIVERY MODE
SMC
R3
0.257
3000
6000
48000
13''
Package Outline Dimensions (SMC/DO-214AB)
Symbol
A C
A
B
B
C
H
D
E
D
E
F
F
G
G
H
Suggested Pad Layout
J
K
J
Symbol
M
M
J
K
3 of 3
Dimensions
Millimeters
Min.
Max.
6.60
7.11
2.85
5.59
1.99
0.76
7.75
0.15
0.112
0.129
6.22
0.221
0.246
2.61
1.52
0.20
8.13
0.31
Max.
3.03
0.261
0.281
0.078
0.103
0.030
0.060
0.008
0.306
0.321
0.006
Dimensions
Min.
Max.
3.27
Millimeters
3.82
Min.
Inches
Min.
0.151
3.84
0.120
0.012
Inches
Max.
0.152
www.ichjc.com
很抱歉,暂时无法提供与“ES8JC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.49896
- 50+0.43438
- 150+0.40209
- 500+0.37790
- 3000+0.35208
- 6000+0.34236
