� �D�
宏迦橙
SS32C THRU SS320C
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
www.ichjc.com
Features
DO-214AB(SMC)
•Low profile package
•Ideal for automated placement
•Guardring for overvoltage protection
•Low power losses, high efficiency
•Meets MSL level 1, per J-STD-020, LF maximum peak of 260℃
Applications
For use in low voltage high frequency inverters, free wheeling,DC/DC converters,
and polarity protection applications.
Mechanical Data
•Case: DO-214AB(SMC)
Molding compound meets UL 94V-0 flammability rating, RoHS-compliant,
halogen-free
•Terminals: Solder plated, solderable per MIL-STD-750,Method 2026
•Polarity: Cathode line denotes the cathode end
Maximum Ratings (Ta=25℃ Unless otherwise specified)
PARAMETER
SYMBOL UNIT SS32C SS33C SS34C SS35C SS36C SS38C SS310C SS315C SS320C
Device marking code
Maximum Repetitive Peak Reverse Voltage
VRRM
V
Maximum DC blocking Voltage
VDC
V
Maximum RMS Voltage
Maximum Average Forward Rectified Current
@60Hz sinewave, Resistance load,TL (Fig.1)
Non-repetitive Peak Forward Surge Current
@ t=8.3ms Half-sine wave
Storage temperature
Junction temperature
VRMS
40
50
60
80
100
150
200
40
50
60
80
100
150
200
14
21
28
35
A
Tstg
-55 ~ +150
RθJ-A
℃ /W
47
IFSM
RθJ-L
A
Maximum instantaneous
forward voltage
Maximum DC reverse
currentat rated DC
blocking voltage
3.0
56
70
105
140
80
-55 ~ +150
℃ /W
17
Electrical Characteristics (Ta=25℃ Unless otherwise specified)
PARAMETER
42
IF(AV)
Tj
Typical Thermal Resistance
V
TEST CONDITIONS SYMBOL UNIT SS32C SS33C SS34C SS35C SS36C SS38C SS310C SS315C SS320C
IF=3.0A
VRM=VDC
Typical junction
capacitance
Revision:SBD-May.2023-A0
Ta=25℃
Ta=100℃
4.0V DC,1MHz
VF
V
IR
mA
CJ
pF
0.55
0.5
50
450
1 of 3
Zhuhai Hongjiacheng Technology co., Ltd
0.70
0.85
0.05
0.95
10
350
www.ichjc.com
� �D�
宏迦橙
SS32C THRU SS320C
www.ichjc.com
Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified)
140
120
4
100
3
80
60
2
40
1
80
LEADTEMPERATURE(℃)
120
Fig. 1 Forward Current Derating Curve
100
100
Tj=25℃
Pulsewidth=300us
1%DutyCycle
10
100
NUMBEROFCYCLES
SS32C-SS36C
SS38C-SS320C
10
INSTANTANEOUSREVERSECURRENT(mA)
INSTANTANEOUSFORWARDCURRENT(A)
1
Fig.2 Maximum Non-Repetitive Peak Forward Surge Current
10
1.0
Tj=100℃
1
0.1
0.1
0.01
8.3msSingleHalfSineWave
(JEDECMethod)
PEAKFORWARDSURGECURRENT(A)
AVERAGERECTIFIELDOUTPUTCURRENT(A)
5
0.4
0.6
0.8
1.0
SS32C-SS34C
SS35C-SS36C
SS38C-SS310C
SS315C-SS320C
1.2
INSTANTANEOUSFORWARDVOLTAGE(V)
1.4
0.001
1.6
Fig.3 Typical Forward Voltage
Tj=25℃
0.01
60
80
PERCENTOFRATEDPEAKREVERSEVOLTAGE(%)
100
Fig.4 Typical Reverse Characteristics
2 of 3
www.ichjc.com
� �D�
宏迦橙
SS32C THRU SS320C
www.ichjc.com
Ordering Information
PACKAGE
PACKAGE CODE
UNIT WEIGHT(g)
REEL(pcs)
BOX(pcs)
CARTON(pcs)
DELIVERY MODE
SMC
R3
0.257
3000
48000
13''
Package Outline Dimensions (SMC/DO-214AB)
A C
Symbol
A
B
B
C
H
D
E
D
E
F
G
F
G
H
Suggested Pad Layout
J
K
J
Symbol
M
M
J
K
3 of 3
Dimensions
Millimeters
Min.
Max.
6.60
7.11
2.85
5.59
1.99
0.76
7.75
0.15
0.112
0.129
6.22
0.221
0.246
2.61
1.52
0.20
8.13
0.31
Max.
3.03
0.261
0.281
0.078
0.103
0.030
0.060
0.008
0.306
0.321
0.006
Dimensions
Min.
Max.
3.27
Millimeters
3.82
Min.
Inches
Min.
0.151
3.84
0.120
0.012
Inches
Max.
0.152
www.ichjc.com
很抱歉,暂时无法提供与“SS310C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.29938
- 10+0.23890
- 30+0.20866
- 100+0.18598
- 500+0.16784
- 1000+0.15876
