SS84C
SS84C
    HONGJIACHENG(宏嘉诚)
    DO-214AB(SMC)
SS84C 数据手册
� �D� 宏迦橙 SS82C THRU SS820C SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER www.ichjc.com Features DO-214AB(SMC) •Low profile package •Ideal for automated placement •Guardring for overvoltage protection •Low power losses, high efficiency •Meets MSL level 1, per J-STD-020, LF maximum peak of 260℃ Applications For use in low voltage high frequency inverters, free wheeling,DC/DC converters, and polarity protection applications. Mechanical Data •Case: DO-214AB(SMC) Molding compound meets UL 94V-0 flammability rating, RoHS-compliant, halogen-free •Terminals: Solder plated, solderable per MIL-STD-750,Method 2026 •Polarity: Cathode line denotes the cathode end Maximum Ratings (Ta=25℃ Unless otherwise specified) PARAMETER SYMBOL Device marking code UNIT Maximum Repetitive Peak Reverse Voltage VRRM V Maximum DC blocking Voltage VDC V Maximum RMS Voltage Maximum Average Forward Rectified Current  @60Hz sinewave, Resistance load,TL (Fig.1) Non-repetitive Peak Forward Surge Current @ t=8.3ms Half-sine wave Storage temperature Junction temperature VRMS SS84C SS86C SS88C SS810C SS815C SS820C SS82C SS84C SS86C SS88C SS810C SS815C SS820C 14 28 42 56 70 105 140 20 V 40 20 60 40 60 Maximum instantaneous forward voltage Maximum DC reverse currentat rated DC blocking voltage VRM=VDC Typical junction capacitance Revision:SBD-May.2023-A0 Ta=25℃ Ta=100℃ 4.0V DC,1MHz 80 ℃ -55 ~ +150 RθJ-A ℃ /W 47 RθJ-L A IR mA CJ pF 150 200 -55 ~ +150 ℃ /W V 8.0 200 150 ℃ VF 150 100 Tstg IFSM TEST CONDITIONS SYMBOL UNIT IF=8.0A 100 A Electrical Characteristics (Ta=25℃ Unless otherwise specified) PARAMETER 80 IF(AV) Tj Typical Thermal Resistance SS82C SS82C SS84C 0.55 880 1 of 3 0.5 SS86C 0.70 50 Zhuhai Hongjiacheng Technology co., Ltd 15 SS88C SS810C 0.85 SS815C 0.05 720 SS820C 0.95 10 www.ichjc.com � �D� 宏迦橙 SS82C THRU SS820C SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER www.ichjc.com Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified) 210 7.0 6.0 150 5.0 120 4.0 3.0 2.0 0 20 40 60 80 100 LEADTEMPERATURE(℃) 120 140 60 0 160 Fig. 1 Forward Current Derating Curve 1000 100 Tj=25℃ Pulsewidth=300us 1%DutyCycle 10 100 NUMBEROFCYCLES SS82C-SS86C SS88C-SS820C 10 INSTANTANEOUSREVERSECURRENT(mA)  INSTANTANEOUSFORWARDCURRENT(A) 1 Fig.2 Maximum Non-Repetitive Peak Forward Surge Current 100 10 Tj=100℃ 1 0.1 1.0 0.1 90 30 1.0 0 8.3msSingleHalfSineWave (JEDECMethod) 180 PEAKFORWARDSURGECURRENT(A) AVERAGERECTIFIELDOUTPUTCURRENT(A) 8.0 0 0.2 0.4 0.6 0.8 1.0 SS82C-SS84C SS86C SS88C-SS810C SS815C-SS820C 1.2 INSTANTANEOUSFORWARDVOLTAGE(V) 1.4 0.001 1.6 Fig.3 Typical Forward Voltage Revision:SBD-May.2023-A0 Tj=25℃ 0.01 0 20 40 60 80 PERCENTOFRATEDPEAKREVERSEVOLTAGE(%) 100 Fig.4 Typical Reverse Characteristics 2 of 3 Zhuhai Hongjiacheng Technology co., Ltd www.ichjc.com � �D� 宏迦橙 SS82C THRU SS820C SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER www.ichjc.com Ordering Information PACKAGE PACKAGE CODE UNIT WEIGHT(g) REEL(pcs) BOX(pcs) CARTON(pcs) DELIVERY MODE SMC R3 0.257 3000 6000 48000 13'' Package Outline Dimensions (SMC/DO-214AB) Symbol A C A B B C H D E D E F F G G H Suggested Pad Layout J K J Symbol M M J K Revision:SBD-May.2023-A0 3 of 3 Dimensions Millimeters Min. Max. 6.60 7.11 2.85 5.59 1.99 0.76 - 7.75 0.15 0.112 0.129 6.22 0.221 0.246 2.61 1.52 0.20 8.13 0.31 Max. 3.03 - Zhuhai Hongjiacheng Technology co., Ltd 0.261 0.281 0.078 0.103 0.030 0.060 - 0.008 0.306 0.321 0.006 Dimensions Min. - Max. 3.27 Millimeters 3.82 Min. Inches Min. - 0.151 3.84 - 0.120 0.012 Inches Max. - 0.152 www.ichjc.com
SS84C 价格&库存
很抱歉,暂时无法提供与“SS84C”相匹配的价格&库存,您可以联系我们找货
SS84C
    • 1+0.78095
    • 10+0.65654
    • 30+0.59433
    • 100+0.54767
    • 600+0.38157
    • 1200+0.36288
    库存:6061
