� �D�
宏迦橙
SK82C THRU SK810C
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
www.ichjc.com
Features
DO-214AB(SMC)
•Low profile package
•Ideal for automated placement
•Guardring for overvoltage protection
•Low power losses, high efficiency
•Meets MSL level 1, per J-STD-020, LF maximum peak of 260℃
Applications
For use in low voltage high frequency inverters, free wheeling,DC/DC converters,
and reverse battery protection.
Mechanical Data
•Case: DO-214AB(SMC)
Molding compound meets UL 94V-0 flammability rating, RoHS-compliant,
halogen-free
•Terminals: Solder plated, solderable per MIL-STD-750,Method 2026
•Polarity: Cathode line denotes the cathode end
Maximum Ratings (Ta=25℃ Unless otherwise specified)
PARAMETER
SYMBOL
Device marking code
UNIT
Maximum Repetitive Peak Reverse Voltage
VRRM
V
Maximum DC blocking Voltage
VDC
V
Maximum RMS Voltage
Maximum Average Forward Rectified Current
@60Hz sinewave, Resistance load,TL (Fig.1)
Non-repetitive Peak Forward Surge Current
@ t=8.3ms Half-sine wave
Storage temperature
Junction temperature
VRMS
SK84C
SK86C
SK88C
SK810C SK815C SK820C
SK82C
SK84C
SK86C
SK88C
SK810C
SK815C
SK820C
14
28
42
56
70
105
140
V
40
40
60
Maximum instantaneous
forward voltage
Maximum DC reverse
currentat rated DC
blocking voltage
VRM=VDC
Typical junction
capacitance
Revision:SBD-May.2023-A0
Ta=25℃
Ta=125℃
4.0V DC,1MHz
80
-55 ~ +150
RθJ-A
℃ /W
47
RθJ-L
A
IR
mA
CJ
pF
150
200
-55 ~ +150
℃ /W
V
8.0
200
150
VF
150
100
Tstg
IFSM
TEST CONDITIONS SYMBOL UNIT
IF=8.0A
100
A
Electrical Characteristics (Ta=25℃ Unless otherwise specified)
PARAMETER
80
IF(AV)
Tj
Typical Thermal Resistance
SK82C
SK82C
SK84C
0.55
900
1 of 3
0.5
SK86C
0.70
50
Zhuhai Hongjiacheng Technology co., Ltd
14
SK88C
SK810C
0.85
SK815C
0.05
600
SK820C
0.95
10
www.ichjc.com
� �D�
宏迦橙
SK82C THRU SK810C
www.ichjc.com
Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified)
210
16
12
150
10
120
8
6
4
60
80
100
LEADTEMPERATURE(℃)
120
140
60
Fig. 1 Forward Current Derating Curve
1000
100
Tj=25℃
Pulsewidth=300us
1%DutyCycle
10
100
NUMBEROFCYCLES
SS82C-SS86C
SS88C-SS820C
10
INSTANTANEOUSREVERSECURRENT(mA)
INSTANTANEOUSFORWARDCURRENT(A)
1
Fig.2 Maximum Non-Repetitive Peak Forward Surge Current
100
10
Tj=100℃
1
0.1
1.0
0.1
90
30
2
8.3msSingleHalfSineWave
(JEDECMethod)
180
PEAKFORWARDSURGECURRENT(A)
AVERAGERECTIFIELDOUTPUTCURRENT(A)
14
0.4
0.6
0.8
1.0
SS82C-SS84C
SS86C
SS88C-SS810C
SS815C-SS820C
1.2
INSTANTANEOUSFORWARDVOLTAGE(V)
1.4
0.001
1.6
Fig.3 Typical Forward Voltage
Tj=25℃
0.01
60
80
PERCENTOFRATEDPEAKREVERSEVOLTAGE(%)
100
Fig.4 Typical Reverse Characteristics
2 of 3
www.ichjc.com
� �D�
宏迦橙
SK82C THRU SK810C
www.ichjc.com
Ordering Information
PACKAGE
PACKAGE CODE
UNIT WEIGHT(g)
REEL(pcs)
BOX(pcs)
CARTON(pcs)
DELIVERY MODE
SMC
R3
0.257
3000
6000
48000
13''
Package Outline Dimensions (SMC/DO-214AB)
Symbol
A C
A
B
B
C
H
D
E
D
E
F
F
G
G
H
Suggested Pad Layout
J
K
J
Symbol
M
M
J
K
3 of 3
Dimensions
Millimeters
Min.
Max.
6.60
7.11
2.85
5.59
1.99
0.76
7.75
0.15
0.112
0.129
6.22
0.221
0.246
2.61
1.52
0.20
8.13
0.31
Max.
3.03
0.261
0.281
0.078
0.103
0.030
0.060
0.008
0.306
0.321
0.006
Dimensions
Min.
Max.
3.27
Millimeters
3.82
Min.
Inches
Min.
0.151
3.84
0.120
0.012
Inches
Max.
0.152
www.ichjc.com
很抱歉,暂时无法提供与“SK86C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.76346
- 10+0.60923
- 30+0.53212
- 100+0.47434
- 500+0.42801
- 1000+0.40490
