ES3DC
ES3DC
    HONGJIACHENG(宏嘉诚)
    DO-214AB(SMC)
ES3DC 数据手册
� �D� 宏迦橙 ES3AC THRU ES3JC SURFACE MOUNT SUPER FAST RECOVERY RECTIFIER www.ichjc.com Features DO-214AB(SMC) •Low profile package •Ideal for automated placement •Glass passivated pallet chip junction •Super fast reverse recovery time •Fast switching for high efficiency •High forward surge capability Applications For use in high frequency rectification and freewheeling application in switching mode converters and inverters for consumer, computer, automotive, and telecommunication. Mechanical Data •Case: DO-214AB(SMC) Molding compound meets UL 94V-0 flammability rating, RoHS-compliant, halogen-free •Terminals: Solder plated, solderable per MIL-STD-750,Method 2026 •Polarity: Cathode line denotes the cathode end Maximum Ratings (Ta=25℃ Unless otherwise specified) PARAMETER SYMBOL UNIT ES3AC ES3BC ES3CC ES3DC ES3EC ES3GC ES3JC Maximum RMS Voltage VRMS V 35 70 105 140 210 280 420 Maximum repetitive peak reverse voltage VRRM Maximum DC blocking Voltage V VDC Maximum Average Forward Rectified Current  @60Hz sinewave, Resistance load,TL (Fig.1) Non-repetitive Peak Forward Surge Current @ t=8.3ms Half-sine wave V Junction temperature 150 100 200 150 200 A Tstg ℃ -55 ~+150 RθJ-A(1) ℃ /W 47 A Tj Typical Thermal Resistance 50 100 IF(AV) IFSM Storage temperature 50 RθJ-L(1) 3.0 300 400 300 400 600 600 100 ℃ -55 ~+150 ℃ /W 12 Note : (1)Thermal resistance from junction to ambient and from junction tolead mounted on P.C.B.with 0.2"× 0.2"(5.0mm x5.0 mm) copper pad areas Electrical Characteristics (Ta=25℃ Unless otherwise specified) PARAMETER Maximum instantaneous forward voltage TEST CONDITIONS IF=3.0A Maxinum reverse recovery time IF=0.5A,IR=1.0A,Irr=0.25A Maximum DC reverse currentat rated DC blocking voltage Typical junction capacitance Revision:SFRD-May.2023-A0 VRM=VRRM Ta=25℃ Ta=125℃ 4.0V DC,1MHz SYMBOL UNIT ES3AC VF V Trr ns IR μA CJ pF 1 of 3 ES3BC ES3CC 1.0 Zhuhai Hongjiacheng Technology co., Ltd ES3DC 35 ES3EC ES3GC 1.3 ES3JC 1.7 2.0 200 65 www.ichjc.com � �D� 宏迦橙 ES3AC THRU ES3JC SURFACE MOUNT SUPER FAST RECOVERY RECTIFIER www.ichjc.com Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified) 140 4.0 3.5 PEAKFORWARDSURGECURRENT(A) AVERAGEFORWARDOUTPUTCURRENT(A) 120 3.0 100 2.5 80 2.0 60 1.5 40 1.0 20 0.5 0.0 0 20 40 60 80 100 120 140 0 160 Fig. 1 Forward Current Derating Curve 10 1 Fig.2 Maximum Non-Repetitive Peak Forward Surge Current ��� Tj=25℃ Pulsewidth=300us 1%DutyCycle �� 1 Tj=125℃ �.� 0.1 0.01 0.2 100 10 NUMBEROFCYCLES INSTANTANEOUSREVERSECURRENT(μA) 20  INSTANTANEOUSFORWARDCURRENT(A) 8.3msSingleHalfSineWave (JEDECMethod) Tj=25℃ �.� 0.6 1.0 1.4 ES3AC-ES3DC ES3FC-ES3GC ES3JC INSTANTANEOUSFORWARDVOLTAGE(V) 1.8 �.�� 2.0 Fig.3 Typical Forward Voltage Revision:SFRD-May.2023-A0 ��� PERCENTOFRATEDPEAKREVERSEVOLTAGE(%) ��� Fig.4 Typical Reverse Characteristics 2 of 3 Zhuhai Hongjiacheng Technology co., Ltd www.ichjc.com � �D� 宏迦橙 ES3AC THRU ES3JC SURFACE MOUNT SUPER FAST RECOVERY RECTIFIER www.ichjc.com Ordering Information PACKAGE PACKAGE CODE UNIT WEIGHT(g) REEL(pcs) BOX(pcs) CARTON(pcs) DELIVERY MODE SMC R3 0.257 3000 6000 48000 13'' Package Outline Dimensions (SMC/DO-214AB) Symbol A C A B B C H D E D E G F F G H Suggested Pad Layout J K J Symbol M M J K Revision:SFRD-May.2023-A0 3 of 3 Dimensions Millimeters Min. Max. 6.60 7.11 2.85 5.59 1.99 0.76 - 7.75 0.15 0.112 0.129 6.22 0.221 0.246 2.61 1.52 0.20 8.13 0.31 Max. 3.03 - Zhuhai Hongjiacheng Technology co., Ltd 0.261 0.281 0.078 0.103 0.030 0.060 - 0.008 0.306 0.321 0.006 Dimensions Min. - Max. 3.27 Millimeters 3.82 Min. Inches Min. - 0.151 3.84 - 0.120 0.012 Inches Max. - 0.152 www.ichjc.com
ES3DC 价格&库存
很抱歉,暂时无法提供与“ES3DC”相匹配的价格&库存,您可以联系我们找货
ES3DC
    • 1+0.32109
    • 10+0.25845
    • 30+0.22713
    • 100+0.20358
    • 500+0.18479
    • 1000+0.17540
    库存:2115
