SURFACE MOUNT SUPER FAST RECTIFIER
VOLTAGE RANGE
ES3A THRU ES3K
50 to 800 Volts
CURRENT
3.0 Ampere
Features
Glass passivated chip
Plastic package has underwrites laboratory flammability
Classification 94V-0
For surface mounted applications
Low profile package
Built-in strain relief, ideal for automated placement
Glass Passivated chip junction
High temperature soldering:250℃/10 second at terminals
Mechanical Data
Case: JEDED DO-214AA molded plastic over glass passivated chip
Terminals: Solder plated, Solderable per MIL-STD-750, method 2026
Polarity: Color band denotes cathode end
Weight: 0.003ounce, 0.093 gram
Maximum Ratings and Electrical Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified.
Single phase, half wave, 60Hz, resistive or inductive load.
For capacitive load derate current by 20%.
SYMBOL
S
ES
3A
ES
3B
ES
3C
ES
3D
ES
3E
ES
3G
ES
3J
ES
3K
UNIT
Maximum Repetitive Peak Reverse Voltage
VRRM
50
100
150
200
300
400
600
800
Volts
Maximum RMS Voltage
VRMS
35
70
105
140
210
280
420
560
Volts
Maximum DC Blocking Voltage
VDC
50
100
150
200
300
400
600
800
Volts
TYPE NUMBER
I(AV)
3.0
Amps
Peak Forward Surge Current 8.3ms single half sine wave
superimposed on rated load (JEDEC Method)
IFSM
80
Amps
Maximum Instantaneous Forward Voltage at 3.0A
VF
Maximum Average Forward Rectified Current At TA=100℃
Maximum DC Reverse Current at rated DC blocking
voltage at
(NOTE 1)
TA = 25℃
TA = 125℃
TRR
Typical Junction Capacitance
CJ
(NOTE 2)
(NOTE 1)
1.70
µA
100
nS
35
60
Volts
45
pF
RθJA
RθJL
75
TJ
(-55 to +150)
TSTG
(-55 to +150)
Operating Junction Temperature
Storage Temperature Range
1.25
5.0
IR
Maximuml Reverse Recovery Time (NOTE 3)
Typical Thermal Resistance
0.95
30
℃/W
Notes:
1. Thermal resistance from Junction to ambient and from junction to lead mounted on P.C.B.with0.3×0.3″(8.0 × 8.0mm) copper
pad areas.
2. Measured at 1.0MHz and applied reverse voltage of 4.0V
3. Test conditions IF =0.5A, IR =1.0A, IRR =0.25A
Sep-03, Rev A
CHANGZHOU LANGJIE ELECTRONICS CO.,LTD
VOLTAGE RANGE
ES3A THRU ES3K
50 to 800 Volts
CURRENT
3.0 Ampere
Ratings and Characteristic Curves (T =25℃ unless otherwise noted)
A
FIG.2-MAXIMUM NON-REPETITIVE PEAK
FIG.1-TYPICAL FORWARD CURRENT
AVERAGE FORWARD CURRENT,
(A)
3.0
2.5
2.0
1.5
Single Phase Half Wave
60Hz Inductive or Resistive Load
1.0
0.375″(9.5mm) Lead Length
0.5
100
75
50
125
175
150
FORWARD SURGE CURRENT
PEAK FORWARD SURGE CURRENT, (A)
DERATING CURVE
AMBIENT TEMPERATURE, (°C)
105
90
8.3ms Single Half Sine-Wave
(JEDEC Method) T j = Tjmax
75
60
45
30
15
1 Cycle
1
2
4
6
8
10
40
100
NUMBER OF CYCLES AT 60 Hz
FIG.3-TYPICAL INSTANTANEOUS
FORWARD CHARACTERISTICS
FIG.4-TYPICAL REVERSE
CHARACTERISTICS
TJ =25°C
Pulse Width=300us
0.1
1% Duty Cycle
0.01
10
1.0
(μA)
INSTANTANEOUS REVERSE CURRENT,
3J
-E
S3
K
3E
ES
ES
ES
3A-
3D
-3 G
1.0
(A)
INSTANTANEOUS FORWARD CURRENT,
10
TJ =125°C
0.1
TJ =25℃
0.01
0.001
0.4
0.6
0.8
1.0
1.2
1.6
1.4
40
60
100
80
120
140
PERCENT OF RATED PEAK
REVERSE VOLTAGE,(%)
INSTANTANEOUS FORWARD VOLTAGE,(V)
FIG.5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE,(pF)
100
F1G.6-TEST CIRCUIT DIAGRAM AND
REVERSE RECOVERY TIME CHARACTERISTIC
TRR
50Ω
10Ω
NONINDUCTIVE NONINDUCTIVE
+0.5A
10
25 Vdc
(approx.)
T J =25°C
f=1MHz
Vsig=50mVp-p
ES3A-ES3D
ES3E-ES3K
1.0
10
REVERSE VOLTAGE,(V)
Sep-03, Rev A
1Ω
NON
INDUCTIVE
PULSE
GENERATIOR
(NOTE 2)
OSCILLOSCOPE
(NOTE 1)
-0.25A
-1.0A
1cm
SET TIME BASE FOR
50/100ns/cm
1
0.1
D.U.T.
100
NOTES : 1.Rise Time=7ns max. Input Impedance=
1 megohm. 22pF
2.Rise time=10ns max. Source Impedance=
50 ohms
VOLTAGE RANGE
ES3A THRU ES3K
Package Outline Dimensions
Sep-03, Rev A
CURRENT
50 to 800 Volts
3.0 Ampere
in inches (millimeters)
VOLTAGE RANGE
ES3A THRU ES3K
50 to 800 Volts
CURRENT
3.0 Ampere
Package Reel Information
Specifications
Ao
Bo
Ko
Po
W
t1
SMC
6.05±0.10
8.31±0.10
2.54±0.10
4.00±0.1
16.0±0.30
0.30±0.02
13"Reel
DEVICE TYPE
Tape
Width
Q'TY/REEL(pcs)
SMC
16mm
3000
Sep-03, Rev A
07"Reel
BOX/CARTOON Q'TY/CARTON(pcs) Q'TY/REEL(pcs)
8
48000
800
REEL/BOX
BOX/CARTOON
Q'TY/CARTON(pcs)
3
8
19200
VOLTAGE RANGE
ES3A THRU ES3K
CURRENT
50 to 800 Volts
3.0 Ampere
Reflow Profile
Reflow Condition
Pre Heat
Temperature Min.
+150°C
Temperature Max.
+200°C
Time(Min to Max)
60-180 secs.
Average ramp up rate(Liquidus Temp(TL) to peak)
3°C/sec. Max.
TS(max) to TL - Ramp-up Rate
3°C/sec. Max.
Reflow
Sep-03, Rev A
Pb-Free Assembly
Temperature (TL)(Liquidus)
+217°C
Temperature (TL)
60-150 secs.
Peak Temp (TP)
+(260+0/-5 )°C
Time within 5°C of actual Peak Temp (TP)
25 secs.
Ramp-down Rate
6°C/sec. Max.
Time 25°C to peak Temp (TP)
8 min. Max.
Do not exceed
+260°C
ES3A THRU ES3K
VOLTAGE RANGE
CURRENT
50 to 800 Volts
3.0 Ampere
Disclaimer
The information presented in this document is for reference only. Chongqing changjie Electronic Technology Co., Ltd. reserves the
right to make changes without notice for the specification of the products displayed herein to improve reliability, function or
design or otherwise.
The product listed herein is designed to be used with ordinary electronic equipment or devices, and not designed to be used with
equipment or devices which require high level of reliability and the malfunction of with would directly endanger human life (such
as medical instruments, transportation equipment, aerospace machinery, nuclear-reactor controllers, fuel controllers and other
safety devices), Changjie or anyone on its behalf, assumes no responsibility or liability for any damages resulting from such
improper use of sale.
This publication supersedes & replaces all information previously supplied. For additional information, please visit our website
http:// www.czlangjie.com , or consult your nearest Langjie’s sales office for further assistance.
Sep-03, Rev A
很抱歉,暂时无法提供与“ES3J”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.36674
- 100+0.29598
- 300+0.26060
- 3000+0.23406
- 6000+0.21287
- 9000+0.20228
