SS54C
SS54C
    JUXING(钜兴)
    DO-214AB(SMC)
SS54C 数据手册
SS52~SS5200 Surface Mount Schottky Rectifiers Features ◇ 111 ◇ ◇ Plastic package has Underwriters Laborator Flammability Classification 94V-0 For surface mounted applications Low profile package ◇ Built-in strain relief ◇ Metal silicon junction, majority carrier conduction ◇ High surge capability ◇ High current capability,low forward voltage drop ◇ ◇ 111 ◇ ◇ 11 Low power loss,high effciency For use in low voltage high frequency inverters,free wheeling and polarity protection applications Guardring for overvoltage protection High temperature soldering guaranteed:250oC/10 1 seconds at terminals Mechanical Data ◇ Case:JEDEC SMC,molded plastic 111 Color band denotes cathode end Polarity: ◇ Weight: 0.007 ounces, 0.21 gram ◇ MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS o Ratings at 25 C ambient temperature unless otherwise specified Items SS52 SS54 SS56 SS58 SS510 100 150 200 V 140 200 V UNITS Maximum recurrent peak reverse voltage VRRM 20 40 60 80 Maximum RMS voltage VRWS 14 28 42 56 70 105 Maximum DC blocking voltage VDC 60 80 100 150 Maximum average forw ord rectified current at c TL(SEE FIG.1) (NOTE 2) I(AV) 5.0 A Peak forw ard surge current 8.3ms single halfc sine-w ave superimposed on rated load(JEDEC c Method) IFSM 150 A Maximum instantaneous forw ard voltage at v 5.0A(NOTE.1) Maximum DC reverse current @TA=25oC at rated DC blockjing voltage(NOTE1) @TA=100oC Typical thermal resitance (NOTE2) Operating junction temperature range Storage temperature range VF IR 0.55 0.70 0.5 20 10 55 RθJL 17 V 0.95 0.85 RθJA V mA o C/W TJ -55--- +150 o TSTG -55--- +150 o 2. P.C.B.mounted with 0.55"X0.55"(14.0X14.0mm 2)copper pad areas http://www.trr-jx.com http://www.trr-jx.com 40 20 NOTE: 1.Pulse test:300μS pulse width,1%duty cy cle version: 02 SS5150 SS5200 C C SS52~SS5200 Surface Mount Schottky Rectifiers Characteristic Curves (TA=25 ℃ unless otherwise noted) FIG.2-- PEAK FORWARD SURGE CURRENT 175 5.0 Resistive or inductive Load PEAK FORWARD SURGE CURRENT,AMPERES AVERAGE FORWARD RECTIF IED CURRENT,AMPERES FIG.1 -- FORWARD DERATING CURVE 2.5 0 P.C.B.MOUNTED ON 0.2X0.2(5.0X5.0mm) COPPERPAD AREAS 50 60 70 80 90 100 110 120 130 140 150 160 170 140 105 70 35 0 1 AMBIENT TEMPERATURE ℃ 100 FIG.4 -- TYPICAL REVERSE CHARACTERISTICS 10 20 10 SS52-SS54 SS58-SS520 SS55-SS56 1 TJ =25 Pulse width=300 s 1% duty Cycle .1 .1 .3 .5 .7 .9 1.1 1.3 1.5 1.7 1.9 2.1 INSTANTANEOUS REVERSE CURRENT,MICROAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES 10 NUMBER OF CYCLES AT 60HZ FIG.3 -- TYPICAL FORWARD CHARACTERISTICS 5.0 INSTANTANEOUS FORWARD VOLTAGE,VOLTS http://www.trr-jx.com http://www.trr-jx.com TJ = 125 1.0 .5 .1 .05 TJ = 25 .01 0 version: 02 8.3ms Single Half Sine Wave TJ=125 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE,%
SS54C 价格&库存
很抱歉,暂时无法提供与“SS54C”相匹配的价格&库存,您可以联系我们找货
SS54C
    • 5+0.43389
    • 50+0.42384
    • 150+0.41718
    • 500+0.41051
    库存:770
