SS82 - SS810
SURFACE MOUNT SCHOTTKY BARRIER DIODES
VOLTAGE RANGE: 20 - 100V
CURRENT: 8 .0 A
Features
Schottky Barrier Chip
Ideally Suited for Automatic Assembly
Low Power Loss, High Efficiency
For Use in Low Voltage Application
Guard Ring Die Construction
Plastic Case Material has UL Flammability
Classification Rating 94V-O
B
SMC/DO-214AB
Dim
Min
Max
A
5.59
6.22
B
6.60
7.11
C
2.75
3.18
D
0.15
0.31
E
7.75
8.13
Mechanical Data
A
Case: SMC/DO-214AB, Molded Plastic
Terminals: Solder Plated, Solderable
per MIL-STD-750, Method 2026
C
D
Polarity: Cathode Band or Cathode Notch
Marking: Type Number
Weight: 0.21 grams (approx.)
J
H
G
E
G
0.10
0.20
H
0.76
1.52
J
2.00
2.62
All Dimensions in mm
Maximum Ratings and Electrical Characteristics
TA = 25C unless otherwise specified
Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%.
Characteristic
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
RMS Reverse Voltage
Average Rectified Output Current @TL = 90°C
SS83 SS835
Symbol
SS82
VRRM
VRWM
VR
VR(RMS)
14
21
SS84
SS85
SS86
SS88
SS810
Unit
35
40
50
60
80
100
V
24.5
28
35
42
56
70
V
IO
8.0
A
Non-Repetitive Peak Forward Surge Current
8.3ms Single half sine-wave superimposed on
rated load (JEDEC Method)
IFSM
200.0
A
@IF = 8.0A
V FM
@TA = 25°C
@TA = 100°C
IRM
1.0
mA
Typical junction capacitance (Note1)
CJ
400
pF
Typical Thermal Resistance (Note 2)
RJA
18
°C/W
Forward Voltage
Peak Reverse Current
At Rated DC Blocking Voltage
Operating Temperature Range
Storage Temperature Range
0.85
0.65
V
Tj
-65 to +125
°C
TSTG
-65 to +150
°C
Note: 1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.2x0.2 ”(5.0x5.0mm) copper pad areas
1 of 2
www.sunmate.tw
01
2
3
4
5
1
34576>7?;
89:
@8;3
很抱歉,暂时无法提供与“SS84”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.83584
- 50+0.67254
- 150+0.60256
- 500+0.51521
- 2500+0.47633
- 5000+0.45300
