SB1045L-SB10100L
10A LOW VF SURFACE MOUNT SCHOTTKY RECTIFIERS
Features
! EXTREMELY LOW VF
! LOW STORED CHARGE, MAJORITY CARRIER CONDUCTION
! LOW POWER LOSS / HIGH EFFICIENCY
! UL 94V0 FLAME RETARDANT EPOXY MOLDING COMPOUND
! HALOGEN FREE
Mechanical Data
! CASE:TRANSFER MOLDED
! LEADS:
! POLARITY:AS MARKED
! WEIGHT:0.095 GRAMS (APPROXIMATELY)
Maximum Ratings and Electrical Characteristics
RATING S
Maximum recurrent peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL(see fig.1)
Peak forward surge current 8.3ms single half
sine-wave superimposed on rated load per leg
Storage temperature range
Operating junction temperature range
TA = 25C unless otherwise specified
Symbol
SB1045L
SB1060L
SB10100L
UNITS
VRRM
VRMS
VDC
45
31.5
45
60
42
60
100
70
100
V
V
V
IO
10
A
IFSM
200
A
TSTG
TJ
- 65 TO + 175
- 55 TO + 150
1 of 3
www.sunmate.tw
Characteristics
Maximum forward voltage
Typical forward voltage
AT IF= 10A
AT IF= 1A
SYMBOL
TJ =25℃
TJ =125℃
TJ =125℃
AT IF= 3A
TJ =125℃
AT IF= 5A
TJ =125℃
Typical reverse current AT25 C perleg(NOTE1)
Typical reverse current AT125 C perleg(NOTE1)
VF
SB1045L
SB1060L
SB10100L
0.55
0.65
0.75
0.45
0.55
0.70
0.30
0.40
0.50
0.37
0.45
0.58
0.43
0.52
0.62
IR
IR
0.5
UNITS
V
mA
mA
Thermal Characteristics (Tc=25°C unless otherwise noted)
PARAMETER
Typical thermal resistance junction to case perleg
SYMBOL
Rjc
SB1045L
SB1060L
23
SB10100L
UNITS
℃/W
NOTES︰ 1. PULSE TEST: 300µS PULSE WIDTH, 1% DUTY CYCLE.
2 of 3
www.sunmate.tw
Ratings and Characteristic Curves TA =25°C unless otherwise noted
FIG. 1-FORWARD CURRENT DERATING CURVE
FIG. 2-MAXIMUM NON-REPETITIVE
PEAK FORWARD SURGE RATING
180
PEAK FORWARD SURGE CURRENT AMPERES
10
8
CURRENT AMPERES
AVERAGE FORWARD CURRENT RECTIFIED
15
6
4
2
50
100
125
150
175
200
8.3 ms Single Half Sine Wave
150
(JEDEC Method)
120
90
60
30
AMBIENT TEMPERATURE, oC
1
5
10
50
100
FIG. 3- TYPICAL REVERSE
FIG. 4- TYPICAL INSTANTANEOUS
CHARACTERISTICS
FORWARD CHARCTERISTICS
100
Tj=125℃
10.0
Tj=100℃
1.0
Tj=25℃
0.1
60
80
100
INSTANTANEOUS FORWARD CURRENT ,AMPERES
INSTANTANEOUS REVERSE CURRENT,MILLIAMPERES
NUMBER OF CYCLES AT 60 Hz
100
10
SB10100L
1.0
SB1060L
SB1045L
Pulse Width = 300uS
1% Duty Cycle
0.1
0.1
0.3
0.5
0.7
0.9
1.1
1.3
1.5
INSTANTANEOUS FORWARD VOLTAGE VOLTS
( 25℃)
PERCENT OF RATED VOLTAGE PEAK
REVERSE VOLTAGE (%)
3 of 3
www.sunmate.tw
很抱歉,暂时无法提供与“SS10100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.65336
- 50+0.52203
- 150+0.45637
- 500+0.40712
- 3000+0.36772
- 6000+0.34802
