SS10200
SS10200
    YFW(佑风微)
    DO-214AB(SMC)
SS10200 数据手册
SS1045 THRU SS10200 SMC Surface Mount Schottky Barrier Rectifier Pinning Reverse Voltage - 45 to 200 V 1.Cathode Forward Current - 10 A FEATURES  Metal silicon junction, majority carrier conduction  For surface mounted applications  Low power loss, high efficiency 1 2.Anode 2 DO-214AB/SMC  High forward surge current capability Marking Code  For use in low voltage, high frequency inverters, SS1045 SS1045 SS1060 SS1060  Lead free in comply with EU RoHS 2011/65/EU directives SS10100 SS10100 MECHANICAL DATA  Case: DO-214AB/SMC  Terminals: Solderable per MIL-STD-750, Method 2026 SS10200 SS10200 free wheeling, and polarity protection applications  Approx. Weight: 0.22g / 0.0077oz Absolute Maximum Ratings and Electrical characteristics Ratings at 25 ° ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,for capacitive load, derate by 20 % Symbols SS1045 SS1060 SS10100 SS10200 Units Maximum Repetitive Peak Reverse Voltage VRRM 45 60 100 200 V Maximum RMS voltage VRMS 32 42 70 140 V Maximum DC Blocking Voltage VDC 45 60 100 200 V Maximum Average Forward Rectified Current IF(AV) Parameter Peak Forward Surge Current, 8.3ms Single Half Sinewave Superimposed On Rated Load (JEDEC method) IFSM Maximum Instantaneous Forward Voltage at 8 A VF Maximum Instantaneous Reverse Current TA = 25°C at Rated DC Reverse Voltage T A = 100°C IR Typical Thermal Resistance (2) Storage Temperature Range A 200 0.55 0.75 0.90 0.5 50 RθJA Operating Junction Temperature Range A 10.0 20 V mA °C/W Tj -55 ~ +150 °C Tstg -55 ~ +150 °C (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. www.yfwdiode.com Rve:2023J1 1/3 GuangDongYoufengMicroelectronicsCo,Ltd. SS1045 THRU SS10200 SMC Fig.2 Typical Reverse Characteristics Instaneous Reverse Current ( mA) Fig.1 Forward Current Derating Curve Average Forward Current (A) 12.0 10.0 8.0 6.0 4.0 2.0 0.0 25 50 75 100 125 150 1000 100 T J =25°C 1 0 0 Case Temperature (°C) Transient Thermal Impedance( °C /W) Instaneous Forward Current (A) 20 10 1 SS1045C SS1060C SS10100C 0.1 0.5 1.0 20 40 60 80 100 Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic 0 T J =100°C 10 1.5 2.0 Instaneous Forward Voltage (V) Fig.4- Typical Transient Thermal Impedance 100 10 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) Peak Forward Surage Current (A) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 180 175 150 125 100 75 50 25 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles at 60Hz www.yfwdiode.com Rve:2023J1 2/3 GuangDongYoufengMicroelectronicsCo,Ltd. SS1045 THRU SS10200 SMC DO-214AB SMC Package Outline Plastic surface mounted package; 2 leads E A A1 A C b D L E1 VM A A E D E1 A1 C L b max 2.62 7.0 6.2 8.0 0.21 0.31 1.6 3.25 min 2.00 6.5 5.6 7.6 0.05 0.15 0.9 2.75 max 103 276 244 315 8.3 12 63 128 min 79 256 220 299 2.0 5.9 35 108 UNIT mm mil The recommended mounting pad size 4.1 (160) 3.8 (150) 4.3 (170) 4.1 (160) mm Unit : (mil) Summary of Packing Options Package DO-214AB SMC www.yfwdiode.com Packing Description Packing Quantity Industry Standard Tape/Reel,13”reel 3000 EIA-481-1 Rve:2023J1 3/3 GuangDongYoufengMicroelectronicsCo,Ltd.
SS10200 价格&库存
很抱歉,暂时无法提供与“SS10200”相匹配的价格&库存,您可以联系我们找货
SS10200
    • 5+1.02978
    • 50+0.83657
    • 150+0.75374
    • 500+0.65049
    • 3000+0.56366
    • 6000+0.53601
    库存:2390
