山东晶导微电子股份有限公司
Jingdao Microelectronics co.LTD
Surface Mount Schottky Barrier Rectifier
Reverse Voltage - 45 to 100V
Forward Current - 10.0A
SS1045C THRU SS10100C
PINNING
PIN
FEATURES
• Metal silicon junction, majority carrier conduction
Cathode
2
Anode
• For surface mounted applications
• Low power loss, high efficiency
• High forward surge current capability
• For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
MECHANICAL DATA
• Case: SMC
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.22g / 0.0077oz
DESCRIPTION
1
2
1
Top View
Marking Code: S1045 ~ S10100
Simplified outline SMC and symbol
Absolute Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,
for capacitive load, derate by 20 %
Parameter
Symbols
SS1045C
SS1060C
SS10100C
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
45
60
100
V
Maximum RMS voltage
V RMS
32
42
70
V
Maximum DC Blocking Voltage
V DC
45
60
100
V
Maximum Average Forward Rectified Current
I F(AV)
10.0
A
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
I FSM
150
A
Max Instantaneous Forward Voltage @10.0 A
Maximum DC Reverse Current
T a = 25°C
at Rated DC Reverse Voltage
T a =100°C
Operating Junction Temperature Range
Storage Temperature Range
2021.10
VF
0.55
0.75
0.90
V
IR
0.5
50
mA
Tj
-55 ~ +125
°C
T stg
-55 ~ +150
°C
SMC-S-SS1045C~SS10100C-10A100V
Page 1 of 3
山东晶导微电子股份有限公司
Fig.2 Typical Reverse Characteristics
Average Forward Current (A)
12.0
10.0
8.0
6.0
4.0
2.0
0.0
25
50
75
100
125
150
Instaneous Reverse Current ( mA)
Fig.1 Forward Current Derating Curve
1000
100
T J =100°C
10
1
T J =25°C
Case Temperature (°C)
Peak Forward Surage Current (A)
Instaneous Forward Current (A)
40V
60V
100V
0.1
80
100
180
175
150
125
100
75
50
25
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0
1
10
100
Number of Cycles at 60Hz
Instaneous Forward Voltage (V)
2021.10
40
Fig.4 Maximum Non-Repetitive Peak
Fig.3 Typical Forward Characteristic
1
Percent of Rated Peak Reverse Voltage(%)
www.sdjingdao.com
Page 2 of 3
山东晶导微电子股份有限公司
PACKAGE OUTLINE
SMC
Plastic surface mounted package; 2 leads
E
A
A1
A
C
b
D
L
E1
VM
A
SMC mechanical data
A
E
D
E1
A1
C
L
b
max
2.62
7.0
6.2
8.0
0.21
0.31
1.6
3.25
min
2.00
6.5
5.6
7.6
0.05
0.15
0.9
2.75
max
103
276
244
315
8.3
12
63
128
min
79
256
220
299
2.0
5.9
35
108
UNIT
mm
mil
Marking
The recommended mounting pad size
Type number
3.8
(150)
4.1
(160)
SS1045C
S1045
SS 1060 C
S1060
SS 10100 C
S10100
4.3
(170)
4.1
(160)
Marking code
mm
Unit :
(mil)
2021.10
2110148A8
Page 3 of 3
很抱歉,暂时无法提供与“SS1045C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.98570
- 100+0.73720
- 800+0.57160
- 3000+0.41420
- 15000+0.37280
- 国内价格
- 5+0.72954
- 50+0.57834
- 150+0.50274
- 500+0.44604
- 3000+0.40068
- 6000+0.37800
