山东晶导微电子股份有限公司
S8KC THRU S8MC
Jingdao Microelectronics co.LTD
Surface Mount General Purpose Silicon Rectifiers
Reverse Voltage - 800 to 1000 V
Forward Current - 8 A
PINNING
PIN
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Easy to pick and place
• Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
2
1
MECHANICAL DATA
• Case: SMC
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.22g / 0.0077oz
Top View
Marking Code: S8K~S8M
Simplified outline SMC and symbol
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
S8KC
S8MC
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
800
1000
V
Maximum RMS voltage
V RMS
560
700
V
Maximum DC Blocking Voltage
V DC
800
1000
V
Maximum Average Forward Rectified Current
I F(AV)
8
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
200
A
Maximum Instantaneous Forward Voltage at 8 A
VF
0.985
V
IR
10
250
μA
Cj
40
pF
RθJA
RθJC
35
13
°C/W
T j , T stg
-55 ~ +150
°C
Parameter
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance (1)
Typical Thermal Resistance (2)
Operating and Storage Temperature Range
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2018.01
SMC-A-S8KC~S8MC-8A1KV
Page 1 of 3
山东晶导微电子股份有限公司
S8KC THRU S8MC
Fig.2 Typical Reverse Characteristics
9.6
8.0
6.4
4.8
3.2
1.6
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current(μ A)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
100
T J =125°C
10
1.0
T J =25°C
0.1
00
Case Temperature (°C)
40
60
80
100
120
140
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
10
Junction Capacitance ( pF)
Instaneous Forward Current (A)
percent of Rated Peak Reverse Voltage (%)
1.0
T J =25°C
100
10
T J =25°C
0.1
0.4
1
0.6
0.8
1.0
1.2
1.4
1.6
1.8
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
Fig.6 Maximum Non-Repetitive Peak
300
250
200
150
100
50
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
2018.01
www.sdjingdao.com
Page 2 of 3
山东晶导微电子股份有限公司
S8KC THRU S8MC
PACKAGE OUTLINE
SMC
Plastic surface mounted package; 2 leads
E
A
A1
A
C
b
D
L
E1
VM
A
SMC mechanical data
A
E
D
E1
A1
C
L
b
max
2.62
7.0
6.2
8.0
0.21
0.31
1.6
3.25
min
2.00
6.5
5.6
7.6
0.05
0.15
0.9
2.75
max
103
276
244
315
8.3
12
63
128
min
79
256
220
299
2.0
5.9
35
108
UNIT
mm
mil
Marking
The recommended mounting pad size
Type number
3.8
(150)
4.1
(160)
S8KC
S8K
S8MC
S8M
4.3
(170)
4.1
(160)
Marking code
mm
Unit :
(mil)
2018.01
JD801271B20
Page 3 of 3
很抱歉,暂时无法提供与“S8MC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.34668
- 100+0.27670
- 300+0.24171
- 3000+0.21536
