S8M
S8M
    LJ(朗捷)
    DO-214AB(SMC)
S8M 数据手册
SURFACE MOUNT FAST SWITCHING RECTIFIER VOLTAGE RANGE S8A THRU S8M 50 to 1000 Volts CURRENT 8.0 Ampere Features  Plastic package has underwrites laboratory flammability Classification 94V-0  For surface mounted applications  Low profile package  Built-in strain relief, ideal for automated placement  Glass Passivated chip junction  High temperature soldering: 250℃/10 second at terminals Mechanical Data  Case: JEDED SMC (DO-214AB) molded plastic  Terminals: Plated axial lead solderable per MIL-STD-750, method 2026  Polarity: Color band denotes cathode end  Weight: 0.007 ounce, 0.21 gram Maximum Ratings and Electrical Characteristics  Ratings at 25℃ ambient temperature unless otherwise specified  Single Phase, half wave, 60Hz, resistive or inductive load  For capacitive load derate current by 20% TYPE NUMBER SYMBOLS S8A S8B S8D S8G S8J S8K S8M UNIT Maximum Reverse Peak Repetitive Voltage VRRM 50 100 200 400 600 800 1000 Volts Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 Volts Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 Volts Maximum Average Forward Rectified Output Current, 0.06”(1.5mm) lead length at TC=110℃ Peak Forward Surge Current 8.3ms single half sine wave superimposed on rated load (JEDEC Method) Maximum Instantaneous Forward Voltage drop Per Bridge element 8.0A Maximum Reverse Current at rated DC blocking voltage per element Typical junction capacitance (NOTE 1) Typical Thermal Resistance (NOTE 2) Operating and Storage Temperature Range TA=25℃ TA=125℃ I(AV) 8.0 Amps IFSM 220 Amps VF 1.1 Volts IR 5 50 µAmps CJ 30 pF RΘJL 48 ℃/W RΘJA 15 ℃/W TJ ,TSTG (-55 to +150) ℃ Notes: 1. Measured at 1.0MHz and applied reverse voltage of 4.0 Volts. 2. Unit mounted on P.C.B. with 0.3×0.3″(8.0 × 8.0mm) copper pads. Sep-03, Rev A CHANGZHOU LANGJIE ELECTRONICS CO.,LTD SURFACE MOUNT FAST SWITCHING RECTIFIER VOLTAGE RANGE S8A THRU S8M 50 to 1000 Volts CURRENT 8.0 Ampere Ratings and Characteristic Curves (TA=25℃ unless otherwise noted) F IG .2-M A X IM U M N O N -R E P E T IT IV E P E A K 10 8 .0 6 .0 (A) AVERAGE FORWARD CURRENT, D E R A T IN G C U R V E 4 .0 0.3× 0.3″(8.0 × 8.0m m ) 2 .0 C opper P ads 0 25 0 50 1 00 75 1 50 1 25 1 75 A M B IE N T TE M P E R A T U R E , (°C ) PEAK FORWARD SURGE CURRENT, (A) F IG .1-T Y P IC A L FO R W A R D C U R R E N T FORW ARD SURGE CURRENT 2 40 2 00 8.3m s S ingle H alf S ine-W ave (JE D E C M ethod) T j = Tjm ax 1 60 1 20 80 40 0 1 C ycle 1 2 4 6 8 10 40 20 60 1 00 N U M B E R O F C Y C LE S A T 60 H z F IG .3-T Y P IC A L IN S TA N TA N E O U S F O R W A R D C H A R A C TE R IS TIC S F IG .4-T Y P IC A L R E V E R S E C H A R A C TE R IS TIC S 0 .1 TJ =25°C P ulse W idth=300us 1% D uty C ycle 1 00 10 (μA) INSTANTANEOUS REVERSE CURRENT, 1 .0 (A) INSTANTANEOUS FORWARD CURRENT, 10 TJ =125°C 1 .0 TJ =25°C 0 .1 0 0 .01 0 .2 0 .4 0 .6 0 .8 1 .0 1 .2 1 .4 1 .6 20 40 60 80 1 00 1 20 1 40 P E R C E N T O F R A TE D P E A K R E V E R S E V O LTA G E ,(% ) IN S TA N T A N E O U S F O R W A R D V O LTA G E ,(V ) F IG .5-T Y P IC A L JU N C T IO N C A P A C ITA N C E JUNCTION CAPACITANCE,(pF) 1 000 1 00 T J =25°C f=1M H z V sig=50m V p-p 10 0 .1 1 .0 10 1 00 R E V E R S E V O LTA G E ,(V ) Sep-03, Rev A CHANGZHOU LANGJIE ELECTRONICS CO.,LTD SURFACE MOUNT FAST SWITCHING RECTIFIER VOLTAGE RANGE S8A THRU S8M Package Outline Dimensions Sep-03, Rev A CURRENT 50 to 1000 Volts 8.0 Ampere in inches (millimeters) CHANGZHOU LANGJIE ELECTRONICS CO.,LTD SURFACE MOUNT FAST SWITCHING RECTIFIER VOLTAGE RANGE S8A THRU S8M 50 to 1000 Volts CURRENT 8.0 Ampere Package Reel Information Specifications Ao Bo Ko Po W t1 SMC 6.05±0.10 8.31±0.10 2.54±0.10 4.00±0.1 16.0±0.30 0.30±0.02 DEVICE TYPE SMC Sep-03, Rev A 13"Reel 07"Reel Tape Width Q'TY/REEL(p BOX/CARTO Q'TY/CARTO Q'TY/REEL(p REEL/BOX BOX/CARTO Q'TY/CARTO cs) ON N(pcs) cs) ON N(pcs) 16mm 3000 8 48000 800 3 8 19200 CHANGZHOU LANGJIE ELECTRONICS CO.,LTD SURFACE MOUNT FAST SWITCHING RECTIFIER VOLTAGE RANGE S8A THRU S8M CURRENT 50 to 1000 Volts 8.0 Ampere Reflow Profile Reflow Condition Pre Heat Temperature Min. +150°C Temperature Max. +200°C Time(Min to Max) 60-180 secs. Average ramp up rate(Liquidus Temp(TL) to peak) 3°C/sec. Max. TS(max) to TL - Ramp-up Rate 3°C/sec. Max. Reflow Sep-03, Rev A Pb-Free Assembly Temperature (TL)(Liquidus) +217°C Temperature (TL) 60-150 secs. Peak Temp (TP) +(260+0/-5 )°C Time within 5°C of actual Peak Temp (TP) 25 secs. Ramp-down Rate 6°C/sec. Max. Time 25°C to peak Temp (TP) 8 min. Max. Do not exceed +260°C CHANGZHOU LANGJIE ELECTRONICS CO.,LTD SURFACE MOUNT FAST SWITCHING RECTIFIER S8A THRU S8M VOLTAGE RANGE CURRENT 50 to 1000 Volts 8.0 Ampere Disclaimer The information presented in this document is for reference only. Chongqing changjie Electronic Technology Co., Ltd. reserves the right to make changes without notice for the specification of the products displayed herein to improve reliability, function or design or otherwise. The product listed herein is designed to be used with ordinary electronic equipment or devices, and not designed to be used with equipment or devices which require high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, transportation equipment, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), Changjie or anyone on its behalf, assumes no responsibility or liability for any damages resulting from such improper use of sale. This publication supersedes & replaces all information previously supplied. For additional information, please visit our website http:// www.czlangjie.com , or consult your nearest Langjie’s sales office for further assistance. Sep-03, Rev A CHANGZHOU LANGJIE ELECTRONICS CO.,LTD
很抱歉,暂时无法提供与“S8M”相匹配的价格&库存,您可以联系我们找货
S8M
    • 10+0.26808
    • 100+0.21637
    • 300+0.19052
    • 3000+0.17108
    • 6000+0.15552
    • 9000+0.14785
    库存:1984
