GS15M
GS15M
15.0AMPS . GLASS PASSIVATED RECTIFIERS
SMC(DO-214AB)
FEATURE
.High current capability
.Low forward voltage drop
.Low power loss, high efficiency
.High surge capability
.High temperature soldering guaranteed:
260℃/10 seconds at terminals.
.For surface mounted application.
.Easy pick and place.
.128(3.25)
.108(2.75)
.280(7.11)
.260(6.60)
.320(8.13)
.305(7.75)
.103(2.62)
.079(2.00)
MECHANICAL DATA
.060((1.52)
.030(0.76)
.Terminal: Solder plated
.Case: Molded with UL-94 Class V-0 recognized
Flame Retardant Epoxy(free halogen)
.Polarity: color band denotes cathode
.008(0.203)
.002(0.051)
.245(6.22)
.220(5.59)
.012(0.305)
.006(0.152)
.01182(0.3)
.00788(0.2)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25℃ ambient temperature unless otherwise specified.
Single phase, half wave, 60Hz,resistive or inductive load.
For capacitive load, derate current by 20%
SYM
BOL
Type Number
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC blocking Voltage
Maximum Average Forward Rectified Current
VRRM
VRMS
VDC
IF(AV)
GS15M
units
1000
V
700
V
1000
V
15.0
A
Peak Forward Surge Current 8.3ms single half
sine-wave superimposed on rate load (JEDEC
IFSM
280
A
method)
Maximum Forward Voltage at 7.5 A DC
Maximum DC Reverse Current
at rated DC blocking voltage
@TJ=25°C
@TJ =125°C
Typical Junction Capacitance (Note1)
Typical Thermal Resistance (Note 2)
Storage Temperature
Operation Junction Temperature
VF
1.1
5.0
IR
200.0
CJ
R(JA)
R(JC)
R(JL)
TSTG
TJ
80
V
µA
pF
50
15
°C /W
12
Note:
1. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc
2. Measured on P.C.Board with 0.6×0.6”(15.0×15.0mm)Copper Pad Areas.
-1-
-55 to +150
°C
-55 to +150
°C
GS15M
RATING AND CHARACTERISTIC CURVES
FIG.2-TYPICAL INSTANTENOUS FORWORD
CHATACTERISTICS
FIG.1-TYPICAL FORWORD CURRENT
BERATING CURVE
INSTANTENOUS
FORWORD CURRENT,(A)
AVERGE FORWORD
RECTIED CURRENT,(A)
10
15.0
Tj=25℃,Single Phase Half Wave
60Hz Resistive or Inductive Load
15mm x 15mm x 1.6mm Cu Plate
Heatsink
100
150
FIG.3-MAXIMUN NON-REPEITIVE
FORWORD SURGE CURRENT
INSTANTENOUS REVERSE CURRENT,(uA)
150
100
50
Pulse Width
=300uS 1%
Duty Cycle
0.6
0.8
1.0
1.2
INSTANTENOUS FORWORD VOLTAGE,(V)
Tj=125℃
10
Tj=100℃
1.0
0.1
Tj=25℃
.01
FIG.5-TYPIAL JUNCTION CAPACITANCE
1000
100
10
1
60
80
100
PERCENT OF RATED PEAK REVERSE
VOLTAGE,(%)
NUMBER OF CYCLES AT 60HZ
JUNCTION CAPACITANCE,(pF)
PEAK FORWORD SURGE CURRENT,(A)
Tj=125℃
0.1
100
8.3mS Single Half
Sine-Wave(JEDEC
Method)
10
Tj=25℃
FIG.5-TYPICAL REVERSE CHATACTERISTICS
250
1
1.0
.01
0.4
200
LEAD TEMPERTURE,(℃)
200
Tj=100℃
1
10
REVERSE VOLTAGE,(V)
-2-
100
GS15M
Marking and packaging illustration
1、Marking
SYMBOL
GS15M
A
B
C
B
C
A
XXX
Explanation
Color Band Denotes Cathode
Product Name
Date Code
2、Packaging
d
Top cover tape thickness
0.10mm(0.004") max.thick
W1
Embossed
carrier tape
°MAX
°MAX
A
SPECIFICATIONS
Embossed cavity
SPECIFICATIONS
mm(inch)
PACKAGE
mm(inch)
Carrier width
SYM
BOL
A
SYM
BOL
K
6.15(0.242)Max
Carrier depth
2.54(0.100)Typ
Carrier length
B
8.41(0.331)Max
Punch hole pitch
P
8.00(0.315)Typ
Sprocket hole
d
ø1.55(0.061)Typ
Sprocket hole pitch
P0
4.00(0.157)Typ
Reel outer diameter
D
330.0(13.0)Typ
Embossment center
P1
2.00(0.079)Typ
Reel inner diameter
D1
74.0(2.913)Min
Overall tape thickness
T
0.25(0.010)Typ
Feed hole diameter
D2
13.0(0.512)Typ
Tape width
W
16.0(0.430)Typ
Sprocket hole position
J
1.75(0.069)Typ
Reel width
W1
16.5(0.650)Min
Punch hole position
H
7.50(0.295)Typ
ITEM
SMC
(DO-214AB)
PACKAGE
ITEM
-3-
SMC
(DO-214AB)
很抱歉,暂时无法提供与“GS15M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.36904
- 50+0.36040
- 150+0.35478
- 500+0.34906
