ES5D
ES5D
    MSKSEMI(美森科)
    DO-214AB(SMC)
ES5D 数据手册
www.msksemi.com ES5A THRU ES5J Semiconductor Compiance FEATURES * Ideal for surface mount applications * Easy pick and place * Built-in strain relief * Super fast recovery time for high speed switching MECHANICAL DATA * Case: Molded plastic * Epoxy: UL 94V-0 rate flame retardant * Metallurgically bonded construction * Polarity: Color band denotes cathode end * Mounting position: Any * Weight: 0.21 grams SMC MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. P/N(MARK) Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current ES5A ES5B ES5C ES5D ES5E ES5G 50 35 50 100 70 100 150 105 150 200 140 200 300 210 300 400 280 400 at TL=100 C Peak Forward Surge Current, 8.3 ms single half sine-wave superimposed on rated load (JEDEC method) Maximum Instantaneous Forward Voltage at 5.0A Maximum DC Reverse Current Ta=25 C at Rated DC Blocking Voltage Ta=100 C Maximum Reverse Recovery Time (Note 1) Typical Junction Capacitance (Note 2) Operating and Storage Temperature Range TJ, TSTG ES5J UNITS 600 600 600 A 5.0 120 5 A V A 500 35 A nS 1.25 0.95 1.75 25 40 -65 V V V +150 pF C NOTES: 1. Reverse Recovery Time test condition: IF=0.5A, IR=1.0A, IRR=0.25A 2. Measured at 1MHz and applied reverse voltage of 4.0V D.C. www.msksemi.com ES5A THRU ES5J Semiconductor Compiance RATING AND CHARACTERISTIC CURVES (ES5A THRU ES5J) FIG.2-TYPICAL FORWARD CURRENT DERATING CURVE FIG.1- TEST CIRCUIT DIAGRAM AND REVERSE RECOVERY TIME CHARACTERISTIC trr 10W NONINDUCTIVE ( ) D.U.T. 25Vdc (approx.) | | | | | | | | +0.5A (+) PULSE GENERATOR (NOTE 2) ( ) AVERAGE FORWARD CURRENT,(A) 50W NONINDUCTIVE 0 -0.25A (+) 1W NONINDUCTIVE OSCILLISCOPE (NOTE 1) -1.0A NOTES: 1. Rise Time= 7ns max., Input Impedance= 1 megohm.22pF. 1cm 2. Rise Time= 10ns max., Source Impedance= 50 ohms. 6 5 4 Single Phase 3 Half Wave 60Hz Resistive Or Inductive Load 2 0.375"(9.5mm) Lead Length 1 0 SET TIME BASE FOR 0 25 50 FIG.4-TYPICAL REVERSE CHARACTERISTICS CHARACTERISTICS 10 10 REVERSE LEAKAGE CURRENT, ( A) 50 S5 ES ES 5E 5J -E A- 1.0 G ES5 D 3.0 ES5 INSTANTANEOUS FORWARD CURRENT,(A) FIG.3-TYPICAL FORWARD 50 Tj=25 C Pulse Width 300us 1% Duty Cycle 0.1 .01 .4 .6 .8 1.0 1.2 1.4 1.6 100 125 150 175 3.0 1.0 Tj=100 C Tj=25 C 0.1 1.8 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) FORWARD VOLTAGE,(V) FIG.6-TYPICAL JUNCTION CAPACITANCE FIG.5-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT 175 120 JUNCTION CAPACITANCE,(pF) PEAK FORWARD SURGE CURRENT,(A) 75 AMBIENT TEMPERATURE,( C) 50 / 10ns / cm 90 60 Tj=25 C 8.3ms Single Half Sine Wave JEDEC method 30 150 125 100 ES 5A -E 75 S5 G 50 ES5 E-E 25 S5J 0 0 1 5 10 NUMBER OF CYCLES AT 60Hz 50 100 .01 .05 .1 .5 1 5 10 50 100 REVERSE VOLTAGE,(V) www.msksemi.com ES5A THRU ES5J Semiconductor Compiance PACKAGE MECHANICAL DATA B Dimensions H F A C Ref. D K J L J G E Millimeters Inches Min. Max. Min. Max. A 5.75 6.25 0.226 0.246 B 6.90 7.40 0.272 0.291 C 2.75 3.25 0.108 0.128 D 0.95 1.52 0.037 0.060 E 7.70 8.20 0.303 0.323 F 0.051 0.203 0.002 0.008 G 0.15 0.31 0.006 0.012 H 2.15 2.62 0.085 0.103 J 2.40 0.165 4.20 K L 0.094 3.30 0.130 SMC REEL SPECIFICATION P/N ES5A THRU ES5J PKG QTY SMC 3000 www.msksemi.com ES5A THRU ES5J Semiconductor Compiance Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. www.msksemi.com
很抱歉,暂时无法提供与“ES5D”相匹配的价格&库存,您可以联系我们找货
ES5D
    • 10+0.24553
    • 100+0.19888
    • 300+0.17555
    • 3000+0.15805
    • 6000+0.14405
    • 9000+0.13706
    库存:392
