SS510C
SS510C
    MSKSEMI(美森科)
    DO-214AB(SMC)
SS510C 数据手册
SS52C THRU SS510C Product specification SS52C THRU SS510C Features MECHANICAL DATA  Ideal for surface mount applications  Case: Molded plastic  Easy pick and place  Epoxy: UL 94V-0 rate flame retardant  Built-in strain relief  Metallurgically bonded construction  Low forward voltage drop  Polarity: Color band denotes cathode end  Mounting position: Any  Weight: 0.21 grams Reference News PACKAGE OUTLINE Pin Configuration SMC Copyright© Msksemi Incorporated www.msksemi.com SS52C THRU SS510C MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 ℃ ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. P/N(MARK) UNITS Maximum Recurrent Peak Reverse Voltage 20 30 40 50 60 80 90 100 V Maximum RMS Voltage 14 21 28 35 42 56 63 70 V Maximum DC Blocking Voltage 20 30 40 50 60 80 90 100 V Maximum Average Forward Rectified Current at TL=90 C 5.0 A 150 A Peak Forward Surge Current, 8 . 3 ms single half sine- wave superimposed on rated load ( JEDEC method) Maximum Instantaneous Forward Voltage at 5 . 0 A Maximum DC Reverse Current Ta=25 C at Rated DC Blocking Voltage Ta=100 C 0.55 0.70 0.85 V 0.1 0.02 mA 5 2 mA Typical Junction Capacitance (Note1) 300 pF Typical Thermal Resistance R JL (Note 2) 10 C/W Operating Temperature Range TJ -65 +150 ℃ Storage Temperature Range TSTG -65 +150 ℃ NOTES: 1. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2. Thermal Resistance Junction to Lead. Copyright© Msksemi Incorporated www.msksemi.com SS52C THRU SS510C RATING AND CHARACTERISTIC CURVES (SS52C THRU SS510C) Copyright© Msksemi Incorporated www.msksemi.com SS52C THRU SS510C PACKAGE MECHANICAL DATA Dimensions Ref. Inches Millimeters Min. Max. Min. Max. A 5.75 6.25 0.226 0.246 B 6.90 7.40 0.272 0.291 C 2.75 3.25 0.108 0.128 D 0.95 1.52 0.037 0.060 E 7.70 8.20 0.303 0.323 F 0.051 0.203 0.002 0.008 G 0.15 0.31 0.006 0.012 H 2.15 2.62 0.085 0.103 J 2.40 4.20 K L 0.094 3.30 0.165 0.130 DO-214AB (SMC) REEL SPECIFICATION P/N SS52C THRU SS510C Copyright© Msksemi Incorporated PKG SMC QTY 3000 www.msksemi.com SS52C THRU SS510C Copyright© Msksemi Incorporated www.msksemi.com SS52C THRU SS510C Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not handle applications that require extremely high levels of reliability, such as life-support have specifications that can systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. Copyright© Msksemi Incorporated www.msksemi.com
SS510C 价格&库存
很抱歉,暂时无法提供与“SS510C”相匹配的价格&库存,您可以联系我们找货
SS510C
    • 1+0.17723
    • 200+0.17556
    • 1500+0.17389
    • 3000+0.17270
    库存:3996
    SS510C
      • 10+0.28954
      • 100+0.23414
      • 300+0.20644
      • 3000+0.18561
      • 6000+0.16898
      • 9000+0.16068
      库存:2750
