www.msksemi.com
ES5A THRU ES5J
Semiconductor
Compiance
FEATURES
* Ideal for surface mount applications
* Easy pick and place
* Built-in strain relief
* Super fast recovery time for high speed switching
MECHANICAL DATA
* Case: Molded plastic
* Epoxy: UL 94V-0 rate flame retardant
* Metallurgically bonded construction
* Polarity: Color band denotes cathode end
* Mounting position: Any
* Weight: 0.21 grams
SMC
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
P/N(MARK)
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
ES5A
ES5B
ES5C
ES5D
ES5E
ES5G
50
35
50
100
70
100
150
105
150
200
140
200
300
210
300
400
280
400
at TL=100 C
Peak Forward Surge Current, 8.3 ms single half sine-wave
superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage at 5.0A
Maximum DC Reverse Current
Ta=25 C
at Rated DC Blocking Voltage
Ta=100 C
Maximum Reverse Recovery Time (Note 1)
Typical Junction Capacitance (Note 2)
Operating and Storage Temperature Range TJ, TSTG
ES5J UNITS
600
600
600
A
5.0
120
5
A
V
A
500
35
A
nS
1.25
0.95
1.75
25
40
-65
V
V
V
+150
pF
C
NOTES:
1. Reverse Recovery Time test condition: IF=0.5A, IR=1.0A, IRR=0.25A
2. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
www.msksemi.com
ES5A THRU ES5J
Semiconductor
Compiance
RATING AND CHARACTERISTIC CURVES (ES5A THRU ES5J)
FIG.2-TYPICAL FORWARD CURRENT
DERATING CURVE
FIG.1- TEST CIRCUIT DIAGRAM AND REVERSE RECOVERY TIME CHARACTERISTIC
trr
10W
NONINDUCTIVE
D.U.T.
25Vdc
(approx.)
+0.5A
PULSE
GENERATOR
(NOTE 2)
AVERAGE FORWARD CURRENT,(A)
50W
NONINDUCTIVE
-0.25A
1W
NONINDUCTIVE
OSCILLISCOPE
(NOTE 1)
-1.0A
NOTES: 1. Rise Time= 7ns max., Input Impedance= 1 megohm.22pF.
1cm
2. Rise Time= 10ns max., Source Impedance= 50 ohms.
6
5
4
Single Phase
3
Half Wave 60Hz
Resistive Or Inductive Load
2
0.375"(9.5mm) Lead Length
1
SET TIME BASE FOR
50
FIG.4-TYPICAL REVERSE
CHARACTERISTICS
CHARACTERISTICS
10
10
REVERSE LEAKAGE CURRENT, ( A)
50
S5
ES
ES
5E
5J
-E
A-
1.0
G
ES5
D
3.0
ES5
INSTANTANEOUS FORWARD CURRENT,(A)
FIG.3-TYPICAL FORWARD
50
Tj=25 C
Pulse Width 300us
1% Duty Cycle
0.1
.01
.4
.6
.8
1.0
1.2
1.4
1.6
100
125
150
175
3.0
1.0
Tj=100 C
Tj=25 C
0.1
1.8
60
80
100 120 140
PERCENT OF RATED PEAK REVERSE VOLTAGE,(%)
FORWARD VOLTAGE,(V)
FIG.6-TYPICAL JUNCTION CAPACITANCE
FIG.5-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
175
120
JUNCTION CAPACITANCE,(pF)
PEAK FORWARD SURGE CURRENT,(A)
75
AMBIENT TEMPERATURE,( C)
50 / 10ns / cm
90
60
Tj=25 C
8.3ms Single Half
Sine Wave
JEDEC method
30
150
125
100
ES
5A
-E
75
S5
G
50
ES5
E-E
25
S5J
5
10
NUMBER OF CYCLES AT 60Hz
50
100
.01
.05
.1
.5
1
5
10
50
100
REVERSE VOLTAGE,(V)
www.msksemi.com
ES5A THRU ES5J
Semiconductor
Compiance
PACKAGE MECHANICAL DATA
B
Dimensions
H
F
A
C
Ref.
D
K
J
L
J
G
E
Millimeters
Inches
Min.
Max.
Min.
Max.
A
5.75
6.25
0.226
0.246
B
6.90
7.40
0.272
0.291
C
2.75
3.25
0.108
0.128
D
0.95
1.52
0.037
0.060
E
7.70
8.20
0.303
0.323
F
0.051
0.203
0.002
0.008
G
0.15
0.31
0.006
0.012
H
2.15
2.62
0.085
0.103
J
2.40
0.165
4.20
K
L
0.094
3.30
0.130
SMC
REEL SPECIFICATION
P/N
ES5A THRU ES5J
PKG
QTY
SMC
3000
www.msksemi.com
ES5A THRU ES5J
Semiconductor
Compiance
Attention
■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications
that can handle applications that require extremely high levels of reliability, such as life-support systems,
aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious
physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you
before using any MSKSEMI Semiconductor products described or contained herein in such applications.
■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products
at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or
other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described
orcontained herein.
■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the
performance, characteristics, and functions of the described products in the independent state, and are not
guarantees of the performance, characteristics, and functions of the described products as mounted in the
customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent
device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment.
■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all
semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to
accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause
damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents
or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention
circuitsfor safedesign, redundant design, and structural design.
■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described
or contained herein are controlled under any of applicable local export control laws and regulations, such
products must not be exported without obtaining the export license from theauthorities concerned in
accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or
mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise,
without the prior written permission of MSKSEMI Semiconductor.
■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not
guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and
reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property
rights or other rightsof third parties.
■ Any and all information described or contained herein are subject to change without notice due to
product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the
MSKSEMI Semiconductor productthat you intend to use.
www.msksemi.com
