S6M
S6M
    YFW(佑风微)
    DO-214AB(SMC)
S6M 数据手册
S6A THRU S6M SMC Surface Mount General Purpose Silicon Rectifiers Pinning Reverse Voltage - 50 to 1000 V 1.Cathode Forward Current - 6 A 2.Anode         1 FEATURES  For surface mounted applications  Low profile package  Glass Passivated Chip Junction   2     DO-214AB/SMC  Easy to pick and place Marking Code  Lead free in comply with EU RoHS 2011/65/EU directives MECHANICAL DATA  Case: DO-214AB/SMC  Terminals: Solderable per MIL-STD-750, Method 2026  Approx. Weight: 0.22g / 0.0077oz Maximum Ratings and Electrical characteristics S6A S6A S6B S6B S6D S6D S6G S6G S6J S6J S6K S6K S6M S6M Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols S6A S6B S6D S6G S6J S6K S6M Units Maximum Repetitive Peak Reverse Voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS voltage VRMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current at Tc = 115 °C IF(AV) 6 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load IFSM 150 A Maximum Instantaneous Forward Voltage at 6A VF 1.1 V Maximum DC Reverse Current Ta = 25 °C IR 5 100 μA Typical Junction Capacitance(1) Cj 100 pF Typical Thermal Resistance (2) RθJA/ RθJC 35/13 °C/W Tj, Tstg -55 ~ +150 °C Parameter at Rated DC Blocking Voltage Ta=125 °C Operating and Storage Temperature Range (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. www.yfwdiode.com 1/3 G uangDong YFW Electronics Co, Ltd. S6A THRU S6M SMC Fig.1 Forward Current Derating Curve Instaneous Reverse Current(μ A) Fig.2 Typical Reverse Characteristics Average Forward Current (A) 7.0 6.0 5.0 4.0 3.0 2.0 1.0 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 175 100 T J =125°C 10 1.0 T J =25°C 0.1 00 Case Temperature (°C) 40 60 80 100 120 140 Fig.4 Typical Junction Capacitance Fig.3 Typical Forward Characteristic 10 Junction Capacitance ( pF) Instaneous Forward Current (A) 20 percent of Rated Peak Reverse Voltage (%) 1.0 T J =25°C 100 10 T J =25°C 0.1 0.4 1 0.6 0.8 1.0 1.2 1.4 1.6 1.8 0.1 1.0 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surage Current (A) Fig.6 Maximum Non-Repetitive Peak Forward Surage Current 180 150 120 90 60 30 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles www.yfwdiode.com 2/3 G uangDong YFW Electronics Co, Ltd. S6A THRU S6M SMC DO-214AB SMC Package Outline Plastic surface mounted package; 2 leads E A A1 A C b D L E1 VM A A E D E1 A1 C L b max 2.62 7.0 6.2 8.0 0.21 0.31 1.6 3.25 min 2.00 6.5 5.6 7.6 0.05 0.15 0.9 2.75 max 103 276 244 315 8.3 12 63 128 min 79 256 220 299 2.0 5.9 35 108 UNIT mm mil The recommended mounting pad size 4.1 (160) 3.8 (150) 4.3 (170) 4.1 (160) mm Unit : (mil) Summary of Packing Options Package DO-214AB SMC www.yfwdiode.com Packing Description Packing Quantity Industry Standard Tape/Reel,13”reel 3000 EIA-481-1 3/3 G uangDong YFW Electronics Co, Ltd.
很抱歉,暂时无法提供与“S6M”相匹配的价格&库存,您可以联系我们找货
S6M
    • 10+0.39668
    • 100+0.32475
    • 300+0.28879
    • 3000+0.22590
    • 6000+0.20432
    • 9000+0.19353
    库存:2144
