SS310
SS310
    ZHIDE(志得)
    DO-214AB(SMC)
SS310 数据手册
SS32-SS320 表面安装肖特基二极管 Surface Mounted Schottky Barrier Rectifiers 反向电压 20 ~ 200 V 正向电流 3.0 A Reverse Voltage 20 ~ 200 V Forward Current 3.0 A 特征 Features DO-214AB/SMC ● 反向漏电流低 Low reverse leakage ● 正向浪涌承受能力强 High forward surge capability ● 高信赖性 High reliability ● 高温焊接保证 High temperature soldering guaranteed: 260℃/10 秒 260℃/10seconds ● 引线和管体皆符合RoHS标准 Lead and body according with RoHS standard ● 型号后缀“-F”标记无卤素产品 Green compound with suffix "-F" on Marking 机械数据 Mechanical Data ● 封装外形:DO-214AB塑封 Case:DO-214AB Molded plastic ● 环氧树脂:UL易燃等级:94V-0 Unit: inch (mm) Epoxy: UL 94V-0 rate flame retardant ● 引脚:镀锡,无铅 Lead: Pure tin plated, lead free 最大值和特性 TA = 25℃ 除非另有规定。 Maximum Ratings & Characteristics 参数 Parameter Ratings at 25℃ ambient temperature unless otherwise specified. 符号 Symbols SS32 SS33 SS34 SS35 SS36 SS38 SS310 SS315 SS320 VRRM 20 30 40 50 60 80 100 150 200 V VRMS 14 21 28 35 42 56 70 105 140 V VDC 20 30 40 50 60 80 100 150 200 V 最大可重复峰值反向电压 Maximum repetitive peak reverse voltage 最大均方根电压 Maximum RMS voltage 最大直流阻断电压 单位 Unit Maximum DC blocking voltage 最大正向平均整流电流 Maximum average forward rectified current IF(AV) 3.0 A IFSM 100 A 正向不重复浪涌电流 8.3 ms单一正弦半波 Non-repetitive peak forward surge current 8.3 ms singlehalf sine-wave 最大正向电压 @IF=3.0A VF 0.55 0.70 0.85 0.95 V Maximum forward voltage 最大反向电流 @VDC TA= 25℃ Maximum reverse current TA= 100℃ IR 典型热阻 Typical thermal resistance (Note 1) 典型结电容 VR=4.0V,f=1MHz Type junction capacitance 工作结温 0.5 0.1 20 10 RθJA 60 RθJL 15 CJ 180 TJ -55 --- +125 mA ℃/W pF -55 --- +150 ℃ Operating junction 存储温度 TSTG Storage temperature rang -55 --- +150 ℃ 备注 Note: 1) 安装在PCB板上,从PN结到周围环境的热阻。 1) Thermal resistance from junction to ambient , PCB mounted. REV.1.1,2019-03 Changzhou zhide Electronics CO.,LTD www.cz-zhide.com SS32-SS320 特性曲线 Characteristic Curves 正向特性曲线(典型值) 正向电流降额曲线 IF(AV) (A) 10 1 0.1 0.1 0.5 0.9 1.3 IF(A) Average Forward Rectified Current (A) FORWARD CURRENT DERATING CURVE 平均正向电流 IF Instantaneous Forward Current (A) 正向电流 IF(A) TYPICAL FORWARD CHARACTERISTIC 3 2.5 2 1.5 1 0.5 0 1.7 0 正向电压 VF(V) VF Instantaneous Forward Voltage (V) 25 50 75 100 125 150 175 环境温度 Ta(°C) Tamb, ambient temperature (°C) 浪涌特性曲线(最大值) 反向特性曲线 MAXIMUM NON REPETITIVE Typical Reverse Characteristics PEAK FORWARD SURGE CURRENT 1000 60 40 Reverse Current(uA) 80 反向电流IR(uA) IFSM Peak Forward Surge Current (A) 峰值正向浪涌电流 IFSM(A) 100 100 10 20 0 1 1 10 100 0% 20% 40% 60% 80% 通过电流的周期 额定峰值反向电压% Number of Cycles at 60 Hz. Percent Of Rated Peak Reverse voltage % REV.1.1,2019-03 Changzhou zhide Electronics CO.,LTD 100% www.cz-zhide.com
SS310 价格&库存
很抱歉,暂时无法提供与“SS310”相匹配的价格&库存,您可以联系我们找货
SS310
    • 5+0.26160
    • 50+0.25583
    • 150+0.25201
    • 500+0.24812
    库存:72
