SS52 THRU SS520
Forward Current - 5.0 Ampere
Reverse Voltage - 20 to 200 Volts
PINNING
1
Cathode
Features
2
Anode
Metal silicon junction,majority carrier conduction
PIN
DESCRIPTION
For surface mounted applications
Low power loss,high efficiency
DO-214AB/SMC
High forward surge current capability
For use in low voltage,high frequency inverters,
free wheeling,and polarity protection applications
2
1
Mechanical Data
Case: SMC
Terminals: Solderable per MIL-STD-750, Method 2026
A pprox. Weight: 0.22g / 0.0077oz
Unipolar
Absolute Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,
for capacitive load, derate by 20 %
Unlts
Units
Parameter
Symbols
SS52
SS54
SS56
SS58
SS510
SS512
SS5150
SS520
Maximum Repetitive Peak Reverse Voltage
V RRM
60
80
100
120
150
200
V
Maximum RMS voltage
V RMS
14
28
42
56
70
84
105
140
V
Maximum DC Blocking Voltage
V DC
60
80
100
120
150
200
V
Maximum Average Forward Rectified Current
I F(AV)
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
I FSM
Max Instantaneous Forward Voltage at 5 A
Maximum DC Reverse Current
T a = 25°C
at Rated DC Reverse Voltage
T a =100°C
Typical Junction Capacitance
(1)
Typical Thermal Resistance
(2)
Operating Junction Temperature Range
Storage Temperature Range
VF
175
0.55
0.45
Cj
0.70
1.0
50
IR
150
A
0.85
V
mA
400
600
pF
RθJA
35
°C/W
Tj
-55 ~ +150
°C
T stg
-55 ~ +150
°C
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
www.tw-gmc.com
A
5.0
1
SS52 THRU SS520
Typical Characteristics
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
Average Forward Current (A)
6.0
5.0
4.0
3.0
2.0
1.0
0.0
25
50
75
100
125
150
10 4
T J =100°C
10 3
10 1
T J =25°C
10 0
Case Temperature (°C)
60
100
80
Fig.4 Typical Junction Capacitance
T J =25°C
Junction Capacitance ( pF)
1
SS52
SS54
SS56~SS58
SS510~SS520
0.1
1.0
1.5
100
SS52~SS54
SS56~SS520
0.1
10
1
100
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.6- Typical Transient Thermal Impedance
SS52~SS58
175
SS510~SS520
150
125
100
75
50
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
500
Instaneous Forward Voltage (V)
180
25
1000
2.0
Transient Thermal Impedance( °C /W)
Instaneous Forward Current (A)
Peak Forward Surage Current (A)
40
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
10
100
Number of Cycles at 60Hz
www.tw-gmc.com
T J =75°C
10 2
100
10
1
0.01
0.1
1
10
t, Pulse Duration(sec)
2
100
SS52 THRU SS520
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
E
SMC
A
A1
A
C
b
D
L
E1
VM
A
SMC mechanical data
A
E
D
E1
A1
C
L
b
max
2.62
7.0
6.2
8.0
0.21
0.31
1.6
3.25
min
2.00
6.5
5.6
7.6
0.05
0.15
0.9
2.75
max
103
276
244
315
8.3
12
63
128
min
79
256
220
299
2.0
5.9
35
108
UNIT
mm
mil
The recommended mounting pad size
4.1
(160)
3.8
(150)
4.3
(170)
4.1
(160)
mm
Unit :
(mil)
www.tw-gmc.com
3
很抱歉,暂时无法提供与“SS510(SMC)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.42623
- 100+0.33748
- 300+0.29316
- 3000+0.25797
- 6000+0.23134
- 9000+0.21802
