电子发烧友
开通电子发烧友VIP会员 尊享10大特权
海量资料免费下载
精品直播免费看
优质内容免费畅学
课程9折专享价
SM4007
SM4007
    YFW(佑风微)
    MELF(DO-213AB)
    整流二极管 1KV 1A MELF(DO-213AB)
SM4007 数据手册
SM4001 THRU SM4007 DO-213AB Standard Surface Mounted Rectifiers Reverse Voltage - 50 to 1000 V Forward Current - 1.0 A FEATURES  The plastic package carries Underwriters Laboratory Flammability Classification 94V-0  Idea for surface mounted application  Glass passivated junction chip  Low reverse leakage  High forward surge current capability  High temperature soldering guaranteed260℃/10 seconds at terminals MECHANICAL DATA  Case : Molded plastic body  Terminals : Solder plated, solderable per MIL-STD-750,Method 2026  Polarity : Polarity symbol marking on body  Mounting Position : Any  Weight : 0.0045 ounce, 0.1296 grams Maximum Ratings And Electrical Characteristics Ratings at 25°C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load, for capacitive load current derate by 20%. Parameter Symbols SM4001 SM4002 SM4003 SM4004 SM4005 SM4006 SM4007 Units Maximum Repetitive Peak Reverse Voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS voltage VRMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current at TL=100°C I(AV) 1.0 A Peak Forward Surge Current, 8.3ms Single Half Sine-wave Superimposed On Rated Load IFSM 30 A Maximum Instantaneous Forward Voltage at 1.0 A VF 1.0 V Maximum DC reverse current at rated DC blocking voltage IR 2 200 uA CJ 15 pF RθJA 75 °C/W Operating Junction Temperature Range TJ -55 ~ +150 °C Storage Temperature Range Tstg -55 ~ +150 °C TA = 25°C TA = 125°C Typical junction capacitance (Note1) Typical Thermal Resistance Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. www.yfwdiode.com Rev:BDX1 1/3 GuangDong Youfeng MicroelectronicsCo,Ltd. SM4001 THRU SM4007 DO-213AB Ratings And Characteristic Curves FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT PERLEG 35 Peak Forward Surage Current Amperes 1.0 0.9 0.8 Amperes Average Forward Rectified Current FIG. 1- DERATING CURVE OUTPUT RECTIFIED CURRENT 0.7 0.6 0.5 0.4 0.3 0.2 0 20 40 60 80 100 120 140 30 25 20 15 f=60Hz 10 5 1Cycle 0 160 1 100 FIG. 3-TYPICAL FORWARD VOLTAGE CHARACTERISTICS FIG. 4-TYPICAL REVERSE LEAKAGE CHARACTERISTICS Amperes 1 0.1 TJ=25 Pulse Width=300us 1% Duty Cycle 0.01 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 100 Micro Amperes Instantaneous Reverse Leakage Current Lead Temperature 10 Instantneous Forward Current 10 Number of cycles Volts Instantaneou Foward Voltage Tj = 125°C 10 1.0 Tj = 25°C 0.1 0.01 0 20 40 60 80 100 120 140 Percent Of Rated Peak Reverse Voltage(%) Suggested Pad Layout www.yfwdiode.com Rev:BDX1 Symbol Unit (mm) Unit (inch) A 0.118 B 3.00 1.52 C 4.50 0.177 D 3.00 0.118 E 6.00 0.236 2/3 0.060 GuangDong Youfeng MicroelectronicsCo,Ltd. SM4001 THRU SM4007 DO-213AB www.yfwdiode.com Rev:BDX1 3/3 GuangDong Youfeng MicroelectronicsCo,Ltd.
SM4007 价格&库存
很抱歉,暂时无法提供与“SM4007”相匹配的价格&库存,您可以联系我们找货
